I took a chance and picked up this tv for $150 in the hopes that I can get it working and can upgrade my 55" plasma(which was also a tv I repaired). So let the games begin!
Anyways, I've read through all of the posts I could find on the 70" Sharp.
The blink code I am getting is 2 slow, 3 fast.
I am getting nothing on the screen, I've never been able to get any backlighting, not even a quick flash. Many times I've taken a flashlight to the screen, but I get nothing.
I have 2 ribbon cables that leave the TCON and go to the lcd. I've attempted disconnecting the ribbon cables individually as well as both at the same time, I get nothing on the screen and no backlighting either. I also noticed that I am not getting any 12V, which explains why the screen isn’t coming on. Since it seems in some posts that the TCON is shorting out the 12V signal, I also attempting completely disconnecting the TCON and still get no 12V reading. In fact, the pinout voltage information below was taken with the TCON completely disconnected. I purchased a replacement power board and the tv exhibits the same behavior and voltage readout info regardless of what board I use. I am not ruling out that the same issue exists on both boards, but doubtful.
Part Numbers for all boards in the tv
Power Board : DPS-228CP, RDENCA442WJQZ
TCON Board : DLNTKF778WE11/(A)
Main Board : QPWBXF733WJN2, KF733, FM24S
Address Board : DPS160WP(A), KA842WJZZ
Here is the pinout information as taken from the power board(DPS-228CP, RDENCA442WJQZ)
PD(V)
LA(V)
The next post will contain detailed pictures.
PD(V)
- 0 : PNL_12V
- 0 : PNL_12V
- 0 : SGND
- 0 : SGND
- 13.03 : UR13V
- 13.03 : UR13V
- 13.03 : UR13V
- 13.03 : UR13V
- 0 : SGND
- 0 : SGND
- 0 : SGND
- 0 : SGND
- 3.32 : AC_DET
- 2.85 : PS_ON
- 5.06 : BU+5V
- 0 : PNL_POW
- 0 : VSYNC
- 0 : SCL
- 0.15 : NC
- 0 : SDA
- 0 : OFL
- 0.3 : ERROR
- 0 : NC
- 0 : STB
LA(V)
- 0 : SGND
- 0 : STB
- 0 : OFL
- 0.3 : ERROR
- 0 : NC
- 0 : SDA
- 0 : VSYNC
- 0 : SCL
- 13.03 : UR13V
- 0 : PNL_POW
- 0 : SGND
- 0 : SGND
- 0 : SGND
- 0 : SGND
- 65.3 : LED_VCC
- 65.3 : LED_VCC
- 65.3 : LED_VCC
- 65.3 : LED_VCC
