Go Back   Badcaps Forums > Motherboards with Bad Capacitors > Major Manufacturers Boards
Old 10-23-2008, 03:00 PM   #1
Per Hansson
Per Hansson's Avatar
Send a message via ICQ to Per Hansson Send a message via MSN to Per Hansson
Default Dell Precision 470 Workstation
Hi, found this in the electric trash pallet at work
A Dell workstation, dual Xeon capable (Has a Nocona 2.8Ghz CPU installed) The system can accept the newer Dual Core Xeons I am told just by upgrading BIOS to atleast A06...
It does not POST, the front diagnostic LED's switch on only LED no 2 in amber, which is PSU fault according to Dell...
Pretty good diagnostic if you take into account what has happened to it's capacitors...
It has 31x bad Nichicon 2200µF 6.3v HN(M) capacitors Manufactured week 22 year 2004 rated 105°C
The rest of the caps are Rubycon and Matushita and they are fine...
I am going to replace the Nichicon caps with Samxon I think, but I heard that Dell changed the caps on this very mobo to solid polymers, does anyone know if they made any other design changes to accommodate for this?
If not I think I should go with solid caps instead, what's your take on it?
In any way I'll need to order the caps because I'm out of 2200µF 6.3v caps...
The PSU looks very nice, good caps and very overdesigned (it's rated 550W) Model is D550P-00 P/N DPS-550DB A DELL P/N D1257
Old 10-23-2008, 06:45 PM   #2
kc8adu
kc8adu's Avatar
Default Re: Dell Precision 470 Workstation
great score!
if it were my box it would use 820@2.5 solid polys which i have a ton of.
bet its fine once recapped.
kc8adu is offline   Reply With Quote
Old 10-23-2008, 08:01 PM   #3
Big Pope
Approved Vendor
Big Pope's Avatar
Send a message via ICQ to Big Pope Send a message via MSN to Big Pope
If possible, solid caps will be good choice, but cost will more expensive, because there is too many bad Nichicon HM 2200uF 6.3V D10mm.
If you want to costly, then replace with Samxon GC 2200uF 6.3v/10v is also OK.
My SAMXON Capacitors Database HERE!!
X-CON is a new brand for SAMXON's Polymer Capacitors.
Big Pope is offline   Reply With Quote
Old 10-24-2008, 08:52 AM   #4
Per Hansson
Ok, thanks Big Pope, I think I will go with the "cheap" alternative of GC caps... (Since I can't be sure it will work after a recap seeing as it doesn't POST)
Also considering I don't know what else Dell redesigned in the layout... Maybe other coils and mosfets where used for the solid caps aswell?
Old 10-24-2008, 11:47 AM   #5
Big Pope
Approved Vendor
Big Pope's Avatar
No need, if you want costly.
Old 10-29-2008, 10:58 AM   #6
dood
n00b Super Moderator
man... I've never seen so many blown caps on one board. I wonder how long it was working with partial blown caps before it finally died...
dood is offline   Reply With Quote
Old 10-29-2008, 03:01 PM   #7
Per Hansson
dood; yea, especially seeing how it's an dual CPU board but to my knowledge only one CPU was installed!
Old 10-29-2008, 04:26 PM   #8
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
What diameter are those bad Nichicon 2200?
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 10-29-2008, 07:42 PM   #9
Big Pope
Approved Vendor
Big Pope's Avatar
Diameter should be 10mm in the photo.
Old 10-29-2008, 08:50 PM   #10
370forlife
Spoot
370forlife's Avatar
Send a message via AIM to 370forlife
http://www.newegg.com/Product/Produc...name=Quad-Core
Quad core 604's.
http://www.newegg.com/Product/Produc...82E16819117176
6 core 604.
370forlife is offline   Reply With Quote
Old 10-30-2008, 01:06 PM   #11
Per Hansson
370; yea, but I don't think the board supports them
Only the reqular (Netburst) dual core Xeons I think...
But anyway, awaiting caps from Big Pope, and yes, diameter is 10mm and height is 20mm
Old 10-30-2008, 01:20 PM   #12
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Thanks Per Hansson,
Was thinking about getting my hands on one of those boards and wanted to know what caps to expect to need replacing.
There are some weird 2.8GHz 533FSB Nacona core CPU's that I think Intel made custom just for Dell OEM systems. Pretty sure they went into Precision 470's.
There is no documentation on them at Intel.
Is that what you have?
Old 11-03-2008, 03:09 PM   #13
Per Hansson
PCBONEZ; Will check the exact SSPEC of the CPU if I remove it again...
Got the mobo recapped now, took a long while
Some massive ground planes leading away all the heat from the soldering iron!
However I still had the same issue when trying to power on; A click from a relay is heard from within the PSU
5VSB is present all the time, but the other rails don't become active it seems
The fault is not in the mainboard; I tried running the PSU bare bones only shorting the green wire to ground but it just does the same thing...
(I had an old harddrive and fan connected for load but they didn't even budge...)
I think it's strange because the PSU looks pristine inside, it's one of the most well built PSU's I've ever seen
Can someone give some pointers to where I should look for possible faults, and where I should take more pictures?
The PSU is not a standard ATX spec, it's some weirdo Dell thing with one 24 pin contact, one 20 pin and a third going to a breakout giving the HDD/FDD etc cables...
Old 11-03-2008, 03:31 PM   #14
Per Hansson
More Pictures...
Old 11-03-2008, 04:00 PM   #15
Per Hansson
Lastly one of the H/V area with the copper heatsink removed (sorry for the multiple posts, 10 min rule...)
Old 11-20-2008, 12:42 PM   #16
Per Hansson
Bought a new PSU on eBay (Plus the DMS-59 dongle for the Quadro 280 GFX card)
System is working fine now
Had some issues booting; turned out RAM was installed in incorrect slots when I got it from my company...
But it booted my Windows Live CD based on BartPE with XPE straight up without issues
Installing Windows 7 now (from USB because it only had a cd-rom, no DVD...)
Thanks Big Pope for the quick caps service as usual!
Old 11-20-2008, 02:26 PM   #17
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Congrats!
Old 11-20-2008, 05:10 PM   #18
weirdlookinguy
Excellent score.
weirdlookinguy is offline   Reply With Quote
Old 11-21-2008, 03:05 PM   #19
zandrax
Hit and miss
Good catch: don't forget to post some pics
Zandrax
I'm not dead, just have been busy.
Have an happy life, as usual.
zandrax is offline   Reply With Quote
Old 11-23-2008, 04:14 AM   #20
Per Hansson
It's a standard Xeon Nocona 2.8Ghz with 800Mhz FSB SL7PD
TDP of 102W is quite high, system draws 130w AC idle and about 170W full load
Would be nice with a low voltage CPU instead but no idea what will work (neither have Dell it seems)
First I was set on a Dual Core Paxville but the TDP of 165w does not sound good, of course it does support EIST (Speedstep) which this CPU I have now don't...
The graphics card in it isn't worth the PCB it's printed on, nVidia Quadro NVS 280, based on NV34. It's the slowest POS I've had my hands on for atleast the last 10 years (well, maybe not but you get the picture)
3.5fps in Rthdribl, don't get me started on actually running Solidworks 2009 on it or anything else, the slideshow is the worst I've seen!
Apparently based of Geforce FX 5100, which was a replacement for Geforce 4 MX which was really a Geforce 2 MX but only worse to begin with...
Badcaps.net Technical Forums © 2003 - 2010
Powered by vBulletin® Version 3.8.6
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
Advertise on this forum!
