Go Back   Badcaps Forums > Battling the Bad Capacitors > Frequently Asked Questions
Old 12-08-2007, 01:19 AM   #21
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
Line Voltage: 120V 60Hz
Default Re: The Good Capacitors Photo Thread
I can see how you got where you got then.
I don't consider endurance.
To me the endurance rating isn't a very practical (realistic) number.
First they don't test the capacitors to failure so it's an 'at least this long' rating. [not a max] - It says "We can abuse it xxxx many hours and it will still work properly."
xxxx is CHOSEN by the testers before the test is done and is not determined by the testing. (Which is why they are all in thousands of hours: 1000, 2000, 3000, ..... )
It does nothing practical towards telling us how long the cap last in a real world environment.
Yes you can use endurance and do the math to find expected life span but that's almost useless because it's so inaccurate.
I've forgotten which but one of the major manufactures (good caps brand) gives calculations of life span based on the endurance a "60% level of confidence" (their words.) This is because so many of the inputs to the equation are taken for other equations that give low precision results.
(Many inaccurate variables gives an even less accurate result.)
So, even if you do all the math and come up with say 5 years, it doesn't mean the cap will last 5 years. It means it will last somewhere between 3 and 7 years.
[ 5 years +/- 40%.]
So lets say we compare a 2000hr [5yr] cap and a 4000hr [10yr] cap.
5yr + 40% = 7yr
10yr - 40% = 6yr
In the real world the 2000hr cap may last longer than a 4000hr cap.
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 12-08-2007, 06:40 AM   #22
gonzo0815
City & State: Germany
If the ambient temp is low, may be not more than 45°c, then i may agree.
In non SMPS or similar low ripple applications may be too.
When higher temps or ultra low esr caps are used, then i certainly would take the endurance in to account.
As we have seen early failures of ultra low esr capacitors even with the good brands ( Rubycon MCZ, UCC KZG, KZE and may be KC8`S failed FM ) i would take it seriously.
Similar is the fact, that even ultra cheap crap capacitors like FuHiyu can last very long, if kept beyond a certain threshold of ambient temperature.
If not, they degrade very fast (<1 year).
At least Rubycon is still referring to Rhenius law in their appnote to calculate Endurance. And this is the way, an engineer or designer should have to go.
In this formula, even the small difference of 1000h @105°c is a significant factor.
So i would simply call it a failure, to put a ultra low esr cap with 2k endurance into a environment, where the guaranteed endurance will not be sufficient for the projected lifetime of the appliance.
The above stated generalization 2000h capacitor =5yr is from my point of view not applicable in demanding application.
Sure, the endurance does not mean, that the capacitor has lost it`s whole function, it depends on the circuit and the margin the designer has left.
Considering SOHO IT appliances, i am not that confident, if there is some.
I agree, that it is probably not that realistic to calculate a lifetime based on Rhenius law for more then five years, as this is certainly not proven for any of the recent series.
And sure, there are some safety margins calculated into the guaranteed endurance. But at least for me it is obviouse, that an Panasonic FC is probably more conservatively rated then a Rubycon MCZ.
There are some ultra high endurance high volt caps available, it is the Panasonic ED series with 12000h.
This capacitors are especially recommended for electronic ballasts, where the cap will be placed in the soket of the lamp.
If endurance would not mater, then i think no manufacturer would pay the hefty price tag they have.
And i have seen a lot of those CFL flickering or going dim due to dried up Capxon or even Rubycon capacitors well b4 the advertised lifetime of the lamp.
gonzo0815 is offline   Reply With Quote
Old 12-08-2007, 03:24 PM   #23
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
I think that if there were a way to determine a -realistic- number for estimated life span it would simply be put in the data tables.
I'm not saying Endurance isn't a useful number.
I'm saying most people use it the wrong way because they don't understand where it comes from or what it means.
All Endurance really says is: "you can abuse it 'at least' 'this long' without breaking it".
Unless there is a problem (crap PSU, crap caps present elsewhere on the board, inadequate cooling) in normal use even low Endurance caps will last longer than the useful lifetime of the equipment anyway so for me Endurance is the last (or not even a) consideration when selecting caps.
I'm not intending to drag anyone down here.
I'm just stating what -I- look at when choosing my own caps.
Endurance might matter in 2 or 3 years but that's about when I'd be upgrading the system anyway. In the mean time what matters is Ripple and ESR. So that's what I care about.
You pick your caps and I'll pick mine.
Don't worry. Be happy.
Live long and prosper. (or something like that)
Old 12-09-2007, 05:10 AM   #24
gonzo0815
No problem, it is a free forum in a free country I have no problem with this way of capacitor selection. In fact i do it sometimes the same way .
But i think it should always be clear, how and why we come to such rules of thumbs, as there are people, which don`t replace their hardware that frequently like we tech nuts do it.
And there are up today many other devices, where SMPS are used, which should last a bit longer or are running extraordinary hot (e.g. TFT`s, AUDIO HIFI, network equipment etc.).
Old 09-29-2008, 05:20 PM   #25
jpdoe
when looking at can size to improve ESR, is diameter more important than height? Or is it necesary to calculate volume and compare it instead?
jpdoe is offline   Reply With Quote
Old 09-29-2008, 10:08 PM   #26
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
You can only compare caps in the same series that way because of the differences in chemistry and materials between different series.
Old 09-30-2008, 04:31 AM   #27
jpdoe
Thanks, PCBONEZ
Old 04-22-2010, 02:32 PM   #28
Behemot
Behemot's Avatar
City & State: Prague, 50°4'52.22"N, 14°23'30.45"E
My Country: CZ
Line Voltage: 230 V/50 Hz
I've acquired these Sanyo's from some MoBo but I did not find a word about this DX series in Sanyo's old materials at all. However they should be original because there were also WG's...
Does somebody have datasheet of these? Can be used in PSU?
Behemot is offline   Reply With Quote
Old 04-22-2010, 03:30 PM   #29
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
Line Voltage: 120VAC 60Hz
Send a message via ICQ to Topcat Send a message via AIM to Topcat
I've never heard of DX series either. WG is mostly all I've dealt with in the Sanyo realm. If they aren't fakes, I don't see why they wouldn't be usable in a PSU secondary......but I tend to think its a bad idea to cannibalize caps from other devices and reuse them. Just get new ones, and never have to worry about it again.
<--- Badcaps.net Owner & Forum Administrator!!
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 04-23-2010, 03:59 AM   #30
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
I've come across DX before but I never found a data sheet for them.
Sanyo sold their lytics interests to the subsidiary that was manufacturing them and who is now their own company.
The name is SUN Electronics Industries Corp and the caps are now branded SUNCON.
~ To stress
- This is who has been making Sanyo lytics all along.
- Only the name on the side of the caps has changed.
Have to go there for data sheets now.
http://www.sunelec.co.jp
http://www.sunelec.co.jp/eng/catalog/catalog02.html
Old 04-23-2010, 05:27 AM   #31
Behemot
Behemot's Avatar
My Country: CZ
Yeah I digged this info, too, but on Sunelec's website is no mention about DX either.
I'll probably use them on motherboards around PCI slots etc. it should be fine.
ADD// Are the SUNELEC caps any good?
Maybe I'll try and ask them for the DX directly
Old 04-23-2010, 06:06 AM   #32
c_hegge
Unknown
c_hegge's Avatar
My Country: Australia
Line Voltage: 240V 50Hz
I do that all the time (use 2nd hand caps), but only if they are a good brand and series. (Ruby, Panny, Sanyo, Nichicon excluding 2000-2005 HM/MN, Chemi-con excluding KZG and KZJ)
Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro.
Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro.
2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod
c_hegge is offline   Reply With Quote
Old 04-23-2010, 08:54 AM   #33
Behemot
Behemot's Avatar
My Country: CZ
Exactly
Old 04-23-2010, 02:41 PM   #34
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
They are called SUNCON.
They -ARE- SANYO.
I thought I explained that already.....
Before
- Sanyo owned Sun Electric
- Sun Electric made the caps and put SANYO on them.
Now
- Sun Electric owns Sun Electric
- Sun Electric makes the caps and puts SUNCON on them.
~~ Same caps - new name.
I also said there is not a data sheet for DX.
The link was so if you needed a data sheet for some other series of 'formerly Sanyo' cap.
Yeah, if you write them they might have a data sheet for DX.
If they do please upload it for other folks.
Old 04-23-2010, 03:06 PM   #35
Behemot
Behemot's Avatar
My Country: CZ
They -ARE- SANYO.
Before
Now
It does not prove or disprove anything.
Take Seasonic as an example: the company makes lot of PSU's. Some of them are high-end, some of them are cheap craps even both could share the same design. It's just that some company like Arctic Cooling comes and says "we know you have high-quality PSU's, but what can you do for XX dollars?" And Seasonic goes and makes Fusion. Same design, initially somehow super specs, but we know the PSU has worse components and the worst caps and it will have problems after time.
The same for Delta, the same even for Channel Well Technology. Everyone gets what he pays for. Sanyo paid well. But most experiences tell us Sun Elec. will probably just use the sound of the name and make craps.
I asked for real experiences, wheter the caps are good and are able to sustain load at least acording their specs, better much more and for longer time as known high-quality caps do. But I did not heard about it yet. Nothing against you personally, I just think your trust if based on paper rather than experience is not enough. OST's, TEAPO and others usually have better specs on paper, you know
Old 04-23-2010, 04:51 PM   #36
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Those examples are not the same. - Those examples are OEM situations.
This was not an OEM situation. - One company split into two.
They are made by the same people in the same factory as they have been for several decades and they are STILL a Japanese company, not some Chinese or Thai crap paddlers.
I'm not going to explain it again.
If you want to remain blissfully ignorant then go right ahead.
Old 04-26-2010, 01:14 PM   #37
Behemot
Behemot's Avatar
My Country: CZ
I am not trying to be ignorant, I'd just like to see somebody saying he has only (or mostly) good experiences under some conditions. I did not read whole Bad Caps forum, bud up to date I haven't seen anybody actually using or at least recommending Sun Electronics caps. I haven't seen a system using them. Even Sanyo caps were not widely spread and only minority people used them (compared to Chemi-Con, Rubycon or Nichicon caps). And even some people who I think have far better knowledge about capacitors probably did not ever hear about Sun Electronics.
So sorry if I am annoying, but even (or maybe due to) I have the luck I was born right after the 40 years of communism here in central Europe, I tend to double-check or tripple check. At least in area which I know at least something about. For that reason I'd like somebody to confirm your statements - yes, those are statements until it's proved that's how you say. In the real world economy I tend to not believe companies are good and care about customers so much because I've usually seen the oposite. So I won't base my potencial buy decision on hope wheter some company continues producing good stuff after they divorced from mother firm (with good reputation) thus they are not under watch and can do whatever they want.
Anway, I've got a reply that the (ME-)DX series is not in produce for long time and (ME-)WX is replacement. It can give us some info but I still asked for the datasheet of DX if they have it somewhere.
Old 04-26-2010, 01:43 PM   #38
370forlife
Large Marge
370forlife's Avatar
City & State: Kalamazoo, MI
Line Voltage: 0-120VAC 60Hz
I'm a: Hobbyist Tech
Send a message via AIM to 370forlife
People don't generally recommend sanyo as they are much harder to get. The reason why people haven't recommended suncon is because most people don't know suncon = sanyo, also sanyo still has thousands of sanyo stock to sell off before you start seeing suncon.
Originally Posted by JFK
The American, by nature, is optimistic. He is experimental, an inventor and a builder who builds best when called upon to build greatly
370forlife is offline   Reply With Quote
Old 04-26-2010, 04:51 PM   #39
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
Yet you are succeeding.
Google is your friend.
[Read the last page:]
http://www.edc.sanyo.com/english/pdf/alm/EC_E.pdf
http://www.altec-ag.ch/ger/News/Lett...etter_0409.pdf
Old 06-15-2010, 03:03 PM   #40
Behemot
Behemot's Avatar
My Country: CZ
Found Panasonic HFG caps, FC seems to be replacement for those. Discontiunation notice could serve as datasheet.
What are old Phillips caps from begining of 90's like? I also found Roederstein caps, as I read here they are part of Vishay now, but are these old ones better than now or total craps too?
