Go Back   Badcaps Forums > General Topics > General Capacitor Questions & Issues
Old 09-24-2008, 07:48 PM   #1
powrslave007
Default Failed Recap -New capacitor very hot to the touch
Hi all - I just attempted my 2nd recap - this time without success. I replaced a bad Rubycon MBZ 6.3v 1000u with a Rubycon MCZ 6.3v 820u (all I have at the moment) -at first I thought the recap was successful, but the PC soon rebooted and I can hear a slight crackling/popping sound coming from the motherboard. Has anyone seen something similar? The new cap got very hot to the touch and FAST - the PC was probably on for less than 1 minute.
FYI, the Motherboard I'm doing the recap on is a IBM Barbados 915G/GV
Thanks!
powrslave007 is offline   Reply With Quote
Old 09-24-2008, 09:04 PM   #2
gdement
City & State: Northern CA
Default Re: Failed Recap -New capacitor very hot to the touch
Make sure you didn't put it in backwards. Also look for shorts.
gdement is offline   Reply With Quote
Old 09-25-2008, 06:48 AM   #3
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
post a pic of the board and the area of this cap.
kc8adu is offline   Reply With Quote
Old 09-25-2008, 08:05 PM   #4
powrslave007
Here is a pic - the replacement Cap is in the middle - notice the black heatsink looking item placed close to this cap - it also gets VERY hot VERY fast. That area of the board appears to be slightly discolored - scorched? -
Old 09-26-2008, 11:59 PM   #5
linuxguru
That FET (Q190?) below the cap is probably cooked (shorted), and the rail that is powered by that VRM may have had an overvoltage as a result. If that has happened, a lot of mobo components could have gone south (CPU, Northbridge, memory, ...). Just pray that the FET shorted to ground rather than from the input to inductor junction.
The only course is to replace the FET (maybe two FETs on that rail), check the inductor and replace if necessary, and try again. Look for shorts on every rail before powering up again. If you're lucky, only Vcore may have had an overvoltage - the CPU may have fried, but your Northbridge and Southbridge may have survived. If you're unlucky, lots of things may have fried.
linuxguru is offline   Reply With Quote
Old 10-04-2008, 11:52 AM   #6
bgavin
City & State: Orangevale, CA
I see the coloration difference in the phot.
LG, how difficult is changing it out? Never done one, don't have the parts, but could probably scrounge off a dead board. Just curious
bgavin is offline   Reply With Quote
Old 10-10-2008, 10:04 AM   #7
linuxguru
Replacing FETs soldered to large copper planes is painful, but it can be attempted with suitable tools - hot-air gun, some kind of metal stencils to protect adjacent plastics, and a pair of hemostats to dislodge the FET when the solder softens. It may not be worth the effort unless the rest of the board is believed to be functional.
Old 10-13-2008, 05:01 PM   #8
severach
City & State: Michigan
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
I've done it with a Weller 140w heating the large pad and backing plate and a small iron heating the other pads. It takes two people and the person helping me was a bit drunk and we didn't have the proper grabber tools so the quality wasn't very good.
severach is offline   Reply With Quote
Old 10-13-2008, 10:23 PM   #9
Agent24
I see dead caps
Agent24's Avatar
City & State: Hiding inside a plated-through hole
My Country: New Zealand
Line Voltage: 230VAC 50Hz
I imagine the overheating did not occur before you did the recap?
Perhaps you shorted something when you did the soldering?
Agent24 is offline   Reply With Quote
Old 12-13-2011, 02:25 PM   #10
wtimber
I have 10 of these systems with these failed boards, FRU 39J6196. I called IBM and they want $1866.00 for the replacement board FRU 41T3044. We have 32 more of these systems in service until they also fry. They are failing at a rate of about two a week now. I tried replacing the caps and had the same result as above. Has anyone replaced the FET on these boards yet?
wtimber is offline   Reply With Quote
Old 12-13-2011, 03:08 PM   #11
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
In my experience those FETs aren't that hard to replace. All you need is a fat iron (60W plus) with a wide chisel tip, and a finer one.
With the fine iron heat the legs, use braid to get as much solder out as possible, and then carefully lift one leg at a time with a pair of tweezers or a small screwdriver. Then heat up the fat iron, keep it on the tab of the FET for 30 seconds or so, and push it a little. If the FET moves easily when you push on it with the iron then it means the solder has melted - just use a pair of pliers to grab it and lift it off the board.
To put a new one in just do the steps in reverse - align it, solder the legs first so that it doesn't move, then keep the big iron on the tab of the FET and push on it until you feel it sink into the solder. Lift the iron, let the board cool, and it's job done.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 12-13-2011, 08:05 PM   #12
Evil Lurker
Warranty Voider
Evil Lurker's Avatar
City & State: West Tennessee, USA
Also the magnet wire trick works too, just take some magnet wire (easily salvaged from an old transformer, its coated so it won't stick to the solder), wrap it thru in between the body and pins, heat up the pin and pull the wire. If you properly desoldered the pin with a wick first it should pop right loose. Then you can take your iron and work on removing the back pad.
Evil Lurker is offline   Reply With Quote
Old 12-15-2011, 12:46 AM   #13
kc8adu
kc8adu's Avatar
My Country: U.S.A!
watch out for reversed markings on your board.
look at other caps to see the marking.most have a half circle for neg but a few(asus,asrock,asus oem,)have it positive.
iirc some of these are asus oem.
