Customer bring this in,,,LG 50ln5700 led strip fire, after testing , all was fire just no bl... replaced complete set of strips and the firmware update to stop this from happening again is important. had to have smelled that!
Mike
For fuck sake Lg ! Mothercunts need suing for such a bad design ! Thanks for the photos, as well as FW update be sure to turn tbe Bl way down.
That looks nasty. And you thought Samsung were the only ones having trouble with fires...
Even after 80 odd years--They Still Cant make a TV set--That doesn't catch fire!
--Such nonsense should be a thing of the distant thermionic past!
--Make 'em for nowt, pile 'em up high, sell 'em cheap with no longevity--who cares if down the road it buggers up someone's whole day, We'll sell ya Yet Another Turd!
We once had a toaster oven catch fire from the control unit while it was off. We contacted GE, they sent some one to our house to pick it up, they dropped off their best Toaster oven they make free of charge and refunded us the full retail price of the unit that caught fire. And it was 3 years old.
Some companies take this stuff serious, not sure if LG does but might give them a ring?
It seems to be shorting the return trace out which is why thats burning up. Very odd.
so what am i seeing, the pcb shorting against the backplate, or arcing between the tracks on the board?
it's very uniform along the length!
One LED failing short circuit in a series chain causing other LEDs to fail catastrophically and then leading to the array basically being a short across the power board output would be my guess.
The psb is only putting out 76.1v now. the legend states 110.v to LED, they just flash at boot. ideas?
mike
Driver Ic return probably damaged due to shorted/burnt string.
