m-tec gutless wonder
Re: m-tec gutless wonder
I actually had one of these under the generic brand of "PRO POWER". It had CapXon capacitors in it, and I did use it to power and AMD K6-2 450MHz computer a long time ago while I was waiting for a better power supply to come.
It failed later in that AMD K6-2 450MHz computer with a loud pop, the fan outlet was also lit up for a second. It turns out to be a blown fuse. I didn't bother repairing it, since it was so crappy. The computer luckily survived, and the better power supply (an AOpen 250W PSU) came soon after. I still have this power supply in its dead state in my junk bin.
I don't know who manufactured this power supply, since it had no certifications (UL, CSA, etc.) on the label. Probably a drunk 20 year-old designed it, because it is worse than your typical DEER/L&C/Allied power supply.
A small computer store I know of sells a Pro Power 450W power supply with the 24-pin ATX motherboard connector along with P4 and SATA support, but I wouldn't buy it as I have not had a good experience with Pro Power (whatever they are). Probably its just this crap power supply with the 24-pin ATX motherboard connector, P4 +12V connector, SATA connector, and a 450W label!Last edited by Newbie2; 09-02-2008, 10:40 AM.My gaming PC:
AMD Phenom II X6 1100T Black Edition 3.3GHz Six-Core CPU (Socket AM3)
ASUS M4A77TD AMD 770 AM3 Motherboard
PowerColor AMD Radeon RX 480 8GB GDDR5 PCI-Express x16 3.0 Graphics Card
G.SKILL Value Series 16GB DDR3-1333 RAM (4x4GB dual channel)
TOSHIBA DT01ACA200 2TB 3.5" SATA HDD (x2)
WD Caviar Green WD20EARX 2TB 3.5" SATA HDD
ASUS Xonar DG 5.1 Channel PCI sound card
Antec HCG-750M 750W ATX12V v2.32 80 PLUS BRONZE Power Supply
Antec Three Hundred Mid-Tower Case
Microsoft Windows 10 Pro 64-bit
Microsoft Windows 7 Ultimate SP1 64-bit
Originally posted by kc8aducame from a system another shop trashed.
had a asus p4c800 deluxe board in it.
and they wondered why the system wont post!
note lack of p4 +12 .
board is fine as is the 2 gigs of ram and p4 3.2 proc.
i love getting castoffs from dumbasses!
Even if that PSU had a P4 +12V connector, probably that PSU wouldn't last long and kill the whole computer when it fails.My gaming PC:
