Dell Latitude E7440 power LED blink
    Dell Latitude E7440 power LED blink after pressing power button, then power LED, hdd LED, wifi LED blink automaticaly and restarting again and randomly blink.
    No display, fan is turned on during power led blinking.
    Guys please help me.
    Thanks in advance.
    Here is the schematic:
    Re: Dell Latitude E7440 power LED blink
    Problem solved.
      Originally posted by subroto View Post
      Problem solved.
      how did you solved the Problem
        how did you fix this problems
          By flashing BIOS and replacing RTC battery.
            Re: Dell Latitude E7440 power off
            when switch on after 20 sec turnd off..and battery led blink for 2,3 sec..
            please advice.
            thanks in advance
              please advice.
              thanks in advance
              Read post 4 and 5 . Replace the cmos battery first,if that doesn`t work flash the bios.
                i tried both options change cmos and flash bios but still same...
                  there is no processor volts no ram volts and also no voltage on usb. please advice .
                    have a look at PU100 ,check for +3.3V_ALWP and +5V_ALWP
                      thanks alot for advice ... both voltages are ok..
                      any other thing
                        Ok, check voltage on PU100 pin 3 ,U43 pin 14 +3.3V_ALW_PCH and PL701 pin 1
                          thanks again brother... these all voltages are ok..
                          but i noticed on u46 input 3 and 5 voltages ok but output voltages no have..
                            U46 needs the RUN_ON signal from the KBC. Next check PU300 pin3 and 8
                              I have dell 5440 with same fault kindly help me
                                no voltage pin numbr 3 and pin 8
                                  Dell 5440 have source 19v q124 3v q126 but do not on the screen? thank!
