Badcaps.net Forum
Go Back   Badcaps Forums > Motherboards with Bad Capacitors > ECS - EpoX - Gigabyte
Thread Tools Display Modes
Old 09-02-2011, 01:43 AM   #1
Crash1hd
Default Ga-8knxp
Hello Everyone,
I have attached an image of what I believe to be some bad caps. The motherboard will give off a sound of very fast beeps a couple of times on boot but nothing shows up on the screen, I have tried a different power supply and video card but both work fine in other systems which leaves it to the mobo, cpu or ram (pretty sure the ram and cpu are fine) alas I think its the mobo? Can anyone let me know if this sounds correct and if the image is showing bad caps have I just been lucky up to this point with it booting? cause they have beeen looking like this for awhile.
THanks
P.S. I just realized that I put this in the wrong thread (please move if possible) thanks
Crash1hd is offline   Reply With Quote
Old 09-02-2011, 01:59 AM   #2
Uranium-235
Radioactive
Uranium-235's Avatar
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
I'm a: Professional Tech
Default Re: Ga-8knxp
it looks like you had a power supply that blew those, as they look baaaaad, I don't mean bloated but exploded-i'm suprised you didn't hear a pop
yes, replace them, but it might be too late for nearby components.
Uranium-235 is offline   Reply With Quote
Old 09-02-2011, 02:01 AM   #3
Crash1hd
What do you mean by nearby components? like other parts?
Old 09-02-2011, 07:32 AM   #4
RJARRRPCGP
City & State: Bellows Falls, Vermont
My Country: USA
Line Voltage: 123-127V 61.5-63.5 Hz
I'm a: Knowledge Seeker
Looks like Rubycon, too!
__________________
Asus P6T Deluxe
Core i7 Extreme "Bloomfield" 965
PNY GeForce GTX 960
Windows 7 SP1
SoundBlaster ZXR
Antec High Current Pro 1200 W
"Don't eat yellow snow!" -Salem
RJARRRPCGP is offline   Reply With Quote
Old 09-02-2011, 08:31 AM   #5
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
The circuitry near those capacitors is probably related to the generation of proper voltage for memory (remember, power supplies give 3.3v, 5v and 12v but memories are either about 2.5v for ddr1 or 1.5-1.8v for ddr2/ddr3) .
If so, the motherboard probably can't power/recognize the memory modules properly and beeps.
I would also check the capacitors near the agp slot as that uses 3.3v/1.5v so it may receive power from the same place (but unlikely, it's a bit far away) and should also check the ones near the cpu socket (but if the problem you have is due to bad 3.3v from psu, shouldn't have problems with cpu area as that uses 12v)
mariushm is offline   Reply With Quote
Old 09-02-2011, 09:49 AM   #6
Crash1hd
This makes sense thank you would explain exactly what is going on will have a look at the ones around the video card (maybe post picks for confirmation)
Old 09-02-2011, 05:01 PM   #7
momaka
momaka's Avatar
City & State: VA (NoVA)
My Country: U.S.A.
Line Voltage: 120 VAC, 60 Hz
I've seen many blown Rubycon MBZ like this - in all my cases, it was due to excessive heat (HP/Compaq DC5000 SFF computers have poor cooling design) so I doubt the PSU is the reason why these bulged. I suggest you check your computer and make sure it has enough airflow because Rubycon caps don't go bad for no reason.
In any case, just replace them and all should be well. For replacements, you can use Rubycon MBZ (MCZ is a slight upgrade in ESR, but they should also work) or Nichicon HM (HN is a slight upgrade but would also likely work). Not sure which series of Samxon correspond to these (most likely either GC or GD). All of these are available at the badcaps.net capacitor store.
Old 09-02-2011, 05:16 PM   #8
c_hegge
c_hegge's Avatar
City & State: North Coast, NSW
My Country: Australia
Line Voltage: 240V 50Hz
Out of curiosity, what PSU do you use?
__________________
c_hegge is offline   Reply With Quote
Old 09-03-2011, 02:27 AM   #9
Crash1hd
Well First it was an Enermax 350w whisper EG365 which eventually died and then I replaced it in 2005 with the Enermax 420w EG425P-VE sfma noisetaker which is still working to this day and afaik it could have been the first one or this one that caused the error no idea since it is a system that sits in the basement and I never physically see it unless something is wrong and I cant remote into it (like now) lol
Old 09-03-2011, 07:34 AM   #10
PCBONEZ
Grumpy Old Fart
PCBONEZ's Avatar
City & State: Phoenix, AZ
My Country: USA
Line Voltage: 120V 60Hz
If I'm not mistaken [and I might be] the Noisetakers were one of the Enermaxs with the conductive glue problem.
__________________
Mann-Made Global Warming.
- Dr Seuss
PCBONEZ is offline   Reply With Quote
Old 09-03-2011, 09:58 PM   #11
Crash1hd
Is this something I should worry about? Or something I could look into as I just picked up a new mobo and I will be using this psu with it. Not too worried though since the new mobo has a 4yr warrenty
Old 09-03-2011, 11:58 PM   #12
c_hegge
c_hegge's Avatar
The warranty doesn't cover being taken out by a PSU.
Old 09-04-2011, 07:40 AM   #13
Crash1hd
actually this warranty covers anything its an over the counter exchange and if its broken due to power surge they dont question it or at least they have not yet.
Old 09-05-2011, 12:27 AM   #14
Uranium-235
Radioactive
City & State: tehas
My Country: US
hahaha. I didn't realize, I actually have a VERY similar version of this board
my boss gave me a GA-SINXP1394, included the VRM board. with SAME bloated caps, but not burnt like yours. still booted though
first pics i've taken with my blackberry curve, kinda sucks
I recapped them with some rubycon yxg's
and replaced some main vrm caps KGZ's with MBZ's.
I'm probably going to end up putting a P4 3.4ht chip I found in a laptop in here (laptop with a desktop chip, I know)
Old 09-05-2011, 12:28 AM   #15
Uranium-235
Radioactive
City & State: tehas
My Country: US
all I need to do now is clean the NB fan. my boss smokes like a stack and its stuck
Reply
Thread Tools
Display Modes
Posting Rules
You may not post new threads
You may not post replies
You may not post attachments
You may not edit your posts
BB code is On
Smilies are On
[IMG] code is On
HTML code is Off
Forum Jump
Badcaps.net Technical Forums 2003 - 2017
Powered by vBulletin ®
Copyright ©2000 - 2017, Jelsoft Enterprises Ltd.
