Thermaltake TR2-420 blown!
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    This psu is identical with this, I already recapped and improved.
    I got it from a friend (stefos) that already gave it a try but couldn't fix it.
    I removed the caps except some not important small caps that tested good, removed the primary heatsink, then started testing parts.
    As you can see in the following photos there is damage both in primary and secondary.
    The diode with the red color in BOARD3.jpg is shorted and the transistor near it with orange color is bad, even though not shorted or open circuit.
    On primary section (BOARD4.jpg) there are 2 resistors burnt and failed open. Their values were 1 and 10 ohm.
    The 2 diodes with orange color have been tested and found ok but I am thinking about replacing them, as they might be leaky (?)
    Any opinion / comment welcome
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    Re: Thermaltake TR2-420 blown!
    The blown parts..
    The resistor cut itself in half during desoldering..
    • c_hegge
      • Sep 2009
      • 5219
      Wow. Looks like you gave a few bad components there. I assume the switchers are blown too, as the PCB looks discoloured around where they were.
      • goodpsusearch
        • Oct 2009
        • 2848
        • Greece
        They were blown and replaced with 2x 13009 TO-220 by stefos. The replacement transistors were tested by me and found good.
        • TechGeek
          Computer Geek
          • Jan 2015
          • 2254
          Is it cranking away now, or still dead?
          Permanently Retired Systems:
          Kooky and Kool Systems
          sigpic
          • goodpsusearch
            • Oct 2009
            • 2848
            • Greece
            I have to replace the blown parts. I am going to buy them tomorrow. Wish me luck!
            • TechGeek
              Computer Geek
              • Jan 2015
              • 2254
              What are you going to use that PSU for? Or are you going to sell it as refurbished?
              sigpic
                master hoarder
                • May 2008
                • 12164
                • Bulgaria
                Good luck!
                All in all, I think you will be able to fix it, though. It's a simple half-bridge design. Made by Channell Well Technology (CWT), for those curious.
                Here are two more similar units (though much crappier):
                https://www.badcaps.net/forum/showth...ight=turbolink
                The 2-transistor 5VSB circuit in this PSU has been known to become a motherboard killer as well. With that said, make sure both the 5VSB output caps and 5VSB critical cap are good.
                • goodpsusearch
                  • Oct 2009
                  • 2848
                  • Greece
                  Didn't work
                  5vsb is there but when I short green with ground it just makes a clicking sound. All the output voltages move a bit, but the fan remains still.
                  • TechGeek
                    Computer Geek
                    • Jan 2015
                    • 2254
                    Check the filter caps. That may be it.
                    sigpic
                    • SteveNielsen
                      Retired Tech
                      • Jun 2012
                      • 2327
                      Give us a photo of the bottom side of the board. It looks like C30 is missing.
                        master hoarder
                        • May 2008
                        • 12164
                        • Bulgaria
                        Didn't work
                        Well, you have 5VSB, so that's still something.
                        Does the 5VSB whine, whisle, or make "gushing water" sounds? Either way, measure the secondary side auxiliary rail voltage (it is derived from 5VSB traffo, output at D24 I think, right next to electrolytic capacitor C9). Should be around 10-15V. Also check the BJT driver transistors on the secondary side. Typically that would be two small TO-92 case transistors (c945) and their associated diodes. From the pictures you posted, those transistors are likely Q3 and Q4 (right next to where you found that bad diode, D10), and two of the associated diodes are D10 and D11. I think you might also want to replace D11, just in case it is leaky.
                        Also, why are there resistors in places of diode D38 and D37(?) (or is it D39?). On my TurboLink (see links above, those are diodes). Speaking of my TurboLink, the board is also a REV-G01, so if you need any part references or measurements, let me know .
                        See this picture from my TurboLink:
                        https://www.badcaps.net/forum/attach...1&d=1407035562
                        • goodpsusearch
                          • Oct 2009
                          • 2848
                          • Greece
                          5vsb is perfectly stable and silent. 5.05V
                          I already replaced D10, D11 and D7, D8 with new.
                          Here:
                          https://www.badcaps.net/forum/attach...1&d=1433376228
                          But wait, look closer:
                          Can you see it??
                          Oh, no! How could I have missed this? Was it like this in the first place or did it just blow while I was testing it?
                          Should I just jumper it and re-test?
                            master hoarder
                            • May 2008
                            • 12164
                            • Bulgaria
                            Probably like that. Otherwise the transistors would have likely blown again.
                            Jumper and re-test. But do it with a series incandescent light bulb. 40-60W should be enough for that.
                            • goodpsusearch
                              • Oct 2009
                              • 2848
                              • Greece
                              It works!!!!!!!
                              • TechGeek
                                Computer Geek
                                • Jan 2015
                                • 2254
                                I would put a resistor in place of the jumper(IDK which value) and test it in a computer.
                                sigpic
                                  master hoarder
                                  • May 2008
                                  • 12164
                                  • Bulgaria
                                  ^ Can't put a resistor of any significant value on that trace, because it is the grounding trace for primary aux. winding on driver transformer (used for driving the BJTs).
                                  It works!!!!!!!
                                  • goodpsusearch
                                    • Oct 2009
                                    • 2848
                                    • Greece
                                    It's up and running.
                                    Fan mod
                                    3.23kohm resistor in parallel with the thermistor
                                    Minimum load resistors
                                    Original --> New
                                    5vsb: 50ohm --> 180ohm
                                    3.3V: 15ohm (!!) --> 50ohm taken from 5vsb
                                    5V: 50ohm --> 150 ohm
                                    12V: 240ohm --> 1000ohm
                                    -12V: 470ohm --> no change
                                    Capacitors
                                    5vsb: 2x1000uF 6.3V Rubycon YXG
                                    3.3V: 2x2200uF 6.3V Ltec LTG
                                    5V: 2x2200uF 6.3V Ltec LTG
                                    The Ltec LTG caps were taken from Delta GPS 350W psu I repaired and recapped. Usually they are fine in Delta psus for a couple of years. It would be interesting to find out how long they last in a non Delta power supply.
                                    12V: 1x1000uF 16V Rubycon YXF & 1x3300uF 16V Panasonic FR
                                    -12V: 1x120uF 16V Panasonic FC & 1x120uF 35V Nichicon PM
                                    Fan Capacitor: 1x220uF 16V Τaicon VZ (correct me if I am wrong but this cap is identical to Nichicon VZ)
                                    Primary caps: 1x800uF 200V Panasonic EE 105C (real C:767uF) & 1x820uF 200V Teapo LXK 85C (real C: 810uF)
                                    When I received this psu it had its main switching transistors blown. I replaced them with 2x13009 from Fairchild Semiconductor TO-3P package.
                                    I think it is a decent power supply now!
                                    • Wester547
                                      • Nov 2011
                                      • 1268
                                      • USA.
                                      I think you mean Taicon VZ, not LTEC VZ. Taicon VZ is almost a direct cross to Nichicon VZ but both have a different temperature range (-40C to +105C for Taicon and -55C to +105C for Nichicon except for the 160V ones and higher which are rated for -40C and the 450V ones which are rated for -25C). Also, Taicon VZ is rated for 2,000 hours @ 105*C and the Nichicon VZs of the -55C to +105C range 1,000 hours @ 105*C. And since Nichicon only owns about 1/3rd of Taicon, I doubt that they source all their materials from them. I don't know how long those LTEC capacitors will last in that unit. We all know they don't deal well with heat. I don't consider Taicon capacitors so bad because I've only seen two series from them fail with disconcerting frequency (HD and HI, equal to HM). Good job on the repair though!
                                      • goodpsusearch
                                        • Oct 2009
                                        • 2848
                                        • Greece
                                        Yeap. I meant Taicon VZ! I messed it up
                                        I know Delta knows how to keep those Ltec alive. On the other hand CWT has a bad history with thermal management! That's the reason I changed the minimum load resistors. Let's see how well they will do
