I have APC Back-UPS XS 1300 LCD for 5 years powering home PCs. The battery pack is almost new, was replaced a year ago. Battery voltages are 14.5V and 14.4V, total 28.9V .
Its recently started shutting down power to battery outlets, while surge outlets remain powered. I did some measurements and found that during daytime input utility voltage stays at 116-117V, and at that voltage the UPS doesn't charge the battery anymore. Charging voltage on terminals is 17V with battery disconnected at no load. At night utility voltage raises to 118-120V, and the UPS charges batteries OK overnight to full capacity. Charging voltage on terminals at night is 28.9V raising within 3-5 min to 30.9-31V at no load, and stabilizing.
APC support said, when batteries aren't charging due to lower power voltage from wall outlet, they're continuously slowly discharging by design (probably due to supplying power to UPS PCB?), even if connected to UPS battery outlets equipment still drains power from utility, and not from batteries. Once the battery is fully discharges in about 8 hours, the UPS switches off power to battery outlets. Other than that, the UPS doesn't report any failures or problems at all, and all its functions like sound alarms etc. work OK.
If some tech guys are still willing to provide any meaningful help on this forum, pls advice what caps or other PCB elements I can test and replace to fix this aging UPS? What software I can use for failed components diagnostics (PowerChute doesn't do that)? Pls don't suggest obvious things like "time to buy a new one", unless you're an APC rep. This equipment can be relatively easily repaired, and "repair" is not limited to battery replacement.
Also, could someone point to a proper procedure for UPS Battery calibration, or software for it compatible with APC UPS line? Can it be that APC sets a time bomb in firmware that degrades UPS specs after 4-5 years so it stops working normally and must be "upgraded"? Their older models were reported to work for 8-15 years, but now APC seems to dominate UPS market to the extent when product durability is no longer a factor.
