BN44-00469B Samsung PSU, schema?
  • Alan78
    • Dec 2014
    • 5
    • Spain
    Hi people , i have a Samsung tv (LTF400HM05) with power supply problems. Mosfets are burned and few resistors near mosfets too (i had indentify 4 resistors KO), 2 are easily readable and other 2... imposible, i don't know the original value and are not readable .
    Problematic resistors are:
    RI811
    RI804
    RI834
    RI824
    And it would be good to verify:
    RI803
    QI803
    DI805
    RI823
    QI809
    DI809
    I need a component schematic for this psu board. Anybody have this? i'm not found for anywhere
  • thoma
    • Sep 2012
    • 268
    Re: BN44-00469B Samsung PSU, schema?
    Is there nobody who has a access to gspn samsungportal or knows
    someone who have access!I can`t believe that there a no more
    schematics for the newer powersupplies!
    regards thoma
    • Alan78
      • Dec 2014
      • 5
      • Spain
      That's right thoma, it's unbelievable >:.
      Anyway, thanks to friends in here other forum i can know the correct components for my PSU later a great patient dose jejeje:
      http://tv.yoreparo.com/plasma_lcd/12...0.html#4579783
      Tv it's working fine again .
      Thanks for all.
        Here is the BN44-00368B as referred to in your link.
        TOM66 has lots of SCH.
        http://www.toms-service-manuals.com/
        • Alan78
          • Dec 2014
          • 5
          • Spain
          budm unfortunate these schema it's not the same for BN44-00469B. Probably it's from smaller TV.
          Look at R1803 (330RF) vs 220, R1804 (27RF) vs 18 ohm, Zenner DI802 (BZX84C24LT1) it's less powerful than mine (BZX84C24LT1G), CI806
          (220pF) vs 330 and so on. Many components are the same but others are different.
            Well the link you post shows the SCH of the BN44-00368 which I thought you use that link to get the correct parts value to repair your board. I did not translate that page to English so I may not under stand what it is saying but I did see the SCH and the BN44-00368B on that page.
            • Alan78
              • Dec 2014
              • 5
              • Spain
              No, i have not used this scheme, I asked someone who had a PSU like mine and looking my own components (not burned) for replace the same type . Finally i had post a complete component list: (for any reason appears in other order on thread):
              En mi caso la placa presentaba problemas en los dos bancos de componentes que alimentaban/operaban los mosfets grandotes 5N52U, en primer caso uno de ellos reventó, sustituí la pareja y acabó dando problemas de nuevo hasta hacer reventar el fusible de 3,15 ah que controla esa parte de la placa. Comprobé ambos mosfets fuera y estaban en corto. R1803/R1823 ya presentaban signos de quemaduras, asique las desoldé y efectivamente estaban dañadas, igual que R1816/R1837 e igual que los mosfets Q1803/Q1809 (comprobados y en corto). Como la escabechina afetaba a ambos bancos, directamente opté por meter todo nuevo y dejarme de historias. Comprobé que el trafo TI805S no estuviese en corto midiendo la resistencia entre cada pareja de pads de salida, con ayuda del polímetro en modo diodo y asegurándome que no pitase, lo cual dió un resultado satisfactorio. También seguí revisando hacia atrás en la alimentación de los 5N52U y comprobé que RM801 (al lado del trafo más grande) estuviese sana y con valores correctos (desoldando y comprobando fuera) y que el diodo DM801 también condujese en un sólo sentido. Viendo hacia adelante de los mosfets comprobé que R1806/R1805 (5,6 ohm) estuviesen sanas y opté por cambiar los condensadores cerámicos C1816/C1803 (331K 1KV), que parece ser pueden ser motivo de un mal funcionamiento e incluso avería en la alimentación del inverter (no tengo aparato para medir capacidad de condensadores y me salía mas rentable cambiarlos). Lo único que he descartado cambiar de los dos bancos de componentes fueron las bobinas B1802/B1803 ya que a simple vista se veían bien, era poco probable que se hubiesen quemado y estando aisladas de otros componentes, a golpe de polímetro me daban exactamente la misma resistencia que otras posibles donantes que tenía por casa (efectivamente estaban sanas). Aun con todo esto, algún componente que ya había decidido cambiar, lo comprobé a medida que fuí desoldando para sustituir y casi todos estaban casi todos KO, otros... ya no tuve opción porque murieron en la operación de desoldado (los SOT-23 estaban pegados al PCB y acababan reventando al intentar soltarlos apalancando).
              Lista de componentes de sustitución, idéntica a la original, para la placa BN44-00469B y en algún caso, de mayor potencia (detallado):
              - R1803/R1823: 270 ohm , encapsulado 0603 [Métrica 1608]
              - R1804/R1824: 18 ohm, encapsulado 0603 [Métrica 1608]
              - R1811/R1834: 47K ohm, encapsulado 0603 [Métrica 1608]
              - R1816/R1637: 100K ohm, encapsulado 0603 [Métrica 1608]
              - Q1803/Q1809: 2N7002K, encapsulado SOT23 (referencia exacta según potencia del mosfet que había en mi placa)
              - ZD1802/ZD1803: BZX84C24LT1G, encapsulado SOT-23
              - D1805/D1809: BAV70 encapsulado SOT-23
              - Q1802 y 1803: STF6N52K3, encapsulado TO220FP (en sustitución del STD5N52U, pudiendo aguantar más potencia que el original).
              - C1816/C1803: condensadores cerámicos 330pF 1 KV (331K 1KV), referencia de fabricante en este caso DEHR33A331KN2A.
              - FS802S: fusible cristal 5x20 mm. 3,15 ah (en mi caso fundido por el corto).
              Espero que con esto quede claro para quien sufra un destrozo en su fuente pueda recuperarla sin hacer el pino puente por una cuantía monetaria bastante comedida Smile .
              Respecto a lo de comprobar el oscilador que comentaba jose murillo2014, eso ya se escapa a mis conocimientos. Quizá él nos pueda arrojar luz sobre el asunto Razz .
                I understand now.
                  09-07-2024, 05:50 AM
                  09-06-2024, 11:40 PM
                  09-06-2024, 08:40 PM
                  Samsung Galaxy Book Flex NP950QCG-K01DE Notebook Specification for Upgrade or Repair
                  This specification for the Samsung Galaxy Book Flex NP950QCG-K01DE Notebook can be useful for upgrading or repairing a laptop that is not working. As a community we are working through our specifications to add valuable data like the NP950QCG-K01DE boardview and NP950QCG-K01DE schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet,...
                  09-06-2024, 06:20 PM
