The final piece to the nVidia puzzle - voltage
  • Th3_uN1Qu3
    Believe in
    • Jul 2010
    • 6031
    • Romania
    Well, today was a tough day.
    I thought i'd finally get around to fixing my dv9800, since the new GPU had been sitting here for a while.
    Just yesterday (or, well, 2 days ago since it's almost 6am...) i had done a chip replacement in a Benq R56. I always reball even new chips with leaded solder, but on that one i got lazy and put it in the way it came from the factory, adjusting temperatures to match. No sweat, that one worked great and it's already back to the owner.
    Today (well, yesterday), i decided to do the same with my dv9800 and skip the reballing of the new chip. Only the $45 bastard decided to blow itself up at 230C... !#*%. I'll never solder a lead-free BGA again. I've had ZERO chips die in the last 2 years, and now i fried a BRAND NEW one. Plus, rendered my main laptop inoperable.
    I went outside with someone to clear my mind for a bit. When i came back home, i decided to go back to fixing the dv9000. I had another intel/8600gs board, which was in a pretty sorry state (someone went over it with a wind-proof lighter IIRC) but i'd lifted the shorted GPU a couple months ago and the board powered up fine. And i still had the old, semi-crapped GPU that i pulled from my board.
    I did my trickery on the GPU (covering everything but the die in lots of aluminum foil and bringing the die to some silly temperatures), and it came out alive. Of course, the bad old chip just doesn't want to die. Then i reballed it and soldered it to this other board. It came to life.
    I've been long wanting to try undervolting a nvidia GPU from the bad lot to see the difference it makes. I'd never gotten around to actually trying it though. So i did the mod on this dv9000 board. First by using a pencil, then once i've settled on a value, by soldering in the appropriate resistors. To finish it off, i removed the original aluminum foil/thermal material for the GPU, and applied Arctic MX-4. The CPU got the same treatment.
    I was able to undervolt the GPU from 1.2v/1.15v (high/low) to 0.95v/0.89v. That is 250mV, which represents a 21% reduction in operating voltage. All with the GPU not only still operating correctly, but still presenting some overclocking headroom!!! Under FurMark the GPU Vcore measured 0.943v.
    Since power increases (or decreases) squarely with voltage, resistance being constant, this 21% reduction in operating voltage results in a 37% reduction in power consumption (and thus, heat dissipation) of the chip. The chip now uses only 63 percent of the power it normally used, and thus it's only dissipating 63% as much heat.
    So, to sum it up: Nvidia underrated the current capability of the bumps inside most of their chips manufactured 2006 to 2009, they used the wrong materials for bumps and underfill, and to top it off, the parts were overvolted by 20%, thus using almost 40% more power and putting away 40% more heat than they could have. That's one hell of a booboo if you ask me.
    With the results i have gotten now, i would say that if the operating voltage was more carefully selected for these parts (all other things staying the same), 95%+ of them would have made it the useful life of the laptops.
    You may ask, how are the actual numbers looking? I'll just say this: My dv9000 is now cooler under FULL GPU LOAD than it used to be when completely IDLE. You'll have to do the guessing. I'll post pictures and screenshots after i get a good rest. I guarantee you'll be shocked. I still am, too.
    A working TV? How boring!
  • Per Hansson
    • Jul 2005
    • 5895
    • Sweden
    Re: The final piece to the nVidia puzzle - voltage
    CPU & GPU voltage is selected based on what the highest percentage of chips will be ok with.
    That is to get the yields where they want they select a voltage that is fairly high.
    Just because you have one chip that can do 0.9v does not mean that another million of them do.
    Especially the ones from the first production batches.
    In newer CPU's & GPU's the voltage is actually selected at the factory and is chip dependent.
    As you might know the chips from the middle of the wafer are usually the best.
    • dellxps15
      • Feb 2014
      • 1594
      • italy
      when i had a dell xps 15'' l502x, i did a undervolt of the gpu by vbios and was able to overclock my gt525m to a 555m same results with the 540m. completely different story with the 1gb (or 2gb cant remember , however double the amount of gt525m) version of gt540m you had to overvolt that gpu to make it stable when playn' videogame.
      wich chip does that 9800 got of nvidia? because i see 8600gt , gs or 8400 gt or gs from china costs about 10€ each
      one thing that i dont understand is that on a hp g62 i have done a complete reballing of a ati chip. in the coil all seems ok, i have voltage etc, but still a black screen and chip upperside looks perfect (it is a 2010 version)....
      PS: where did u put that resistor? just outside coil?
      • Th3_uN1Qu3
        Believe in
        • Jul 2010
        • 6031
        • Romania
        That's true. However, i've messed around with LOTS of these, and ALL of them produced very similar results (within 5%) as far as GPU overclocking went. I'm quite sure they would also undervolt almost the same.
        That is one step ahead.
        8600M GS, G86-770-A2. 2010 version G86-771-A2 is $45. Yes, there are many chips at low prices, but i wouldn't like getting a dud straight away. I'm trying to hold on to this thing for another year.
        Any codes on caps lock? Tried reflashing BIOS? Also, is it the version with discrete graphics? If so, go ahead and reball Northbridge. The problem on the G62 isn't with the GPU, it's with the NB. Even with the discrete graphics version it's the same.
        Yes. Here's the pics - as you can see, that board does not look too happy at all. But it works a treat.
        • dellxps15
          • Feb 2014
          • 1594
          • italy
          tnx very much for reply. ill try ith nb reballing.
          what flux do you use? im using kingbo right now and im happy with it. it's just a bit harder to clean with ipa when put together with desolder wick
          just clean your board and it will looks like new
          PS: what value is the resistor ? and how did u spot the right place to put it ?
          PS: i see chip 2012 is 45$ as you said .... a bit expensive chip..... i can buy an hp with nvidia problem for 70€, but donno if worth it.... it has a t5450 intel (have some core duo cpu here like t5870, t9400, t7300, t4500 i can change with)
          edit: do you think is possible to exchange 8600gs with a 8600gt bga ?
          • Agent24
            I see dead caps
            • Oct 2007
            • 5008
            • New Zealand
            Nice!
            I like your idea for resurrecting the die solder balls too
            -David VanHorn
            • ktmmotocross
              Boardkiller
              • Feb 2014
              • 3614
              • slovakia
              the_unique. u must use low quality paste. that brown shit is burned paste.
              never have this shit with kingbo flux and kingbo is not the best
              • dellxps15
                • Feb 2014
                • 1594
                • italy
                i have this when clean pads with kingbo + desolder wick ipa or acetone will clean all
                • Th3_uN1Qu3
                  Believe in
                  • Jul 2010
                  • 6031
                  • Romania
                  Kingbo here too.
                  42k. Made it from 1x 22k and 2x 10k in series. I have whipped up a quick Excel spreadsheet for calculating the voltage output of the MAX1993 used in this board for GPU vreg, i'll attach it if you wish. I figured it out from the GPU VRM schematics and PDF of MAX1993.
                  I wouldn't pay more than 40-50 euro.
                  Possible, yes. But it requires BIOS modification, as 8600GT is G84 core while 8600GS is G86. There are some resources on Russian websites on how to do that, you'll have to use google translate.
                  Originally posted by Agent24
                  Nice!
                  Done a few so far and none failed yet. I did blister a couple old chips while figuring out the proper temperatures, but they didn't go short. Unlike this new one... grrr.
                  The brown shit was there when I got the board. Like i said, it's been burned with a mini torch in a failed attempt to repair the GPU.
                  • Agent24
                    I see dead caps
                    • Oct 2007
                    • 5008
                    • New Zealand
                    I'm kinda surprised that it still works...
                    -David VanHorn
                    • Th3_uN1Qu3
                      Believe in
                      • Jul 2010
                      • 6031
                      • Romania
                      Works great actually. The only thing it seems to be missing is the caps lock LED - everything else checks out.
                      I also did the TME unlock mod (pin 4 of clock generator to ground) and was able to overclock stably to 227 FSB using the free version of SetFSB, which brings my T9300 to 2.83GHz base clock and 3.06GHz IDA. Interestingly enough, i had to lower the PCI clock a bit, otherwise the GPU started acting up. This board does not seems to have a PCI/PCI-E clock lock, it changes with the FSB when the fine adjustments are used. It goes up to 240-245 without crashing but it isn't stable.
                      I tried to strap the clock generator to 266 (1066) FSB, but it didn't boot. Got as far as the BIOS, where it showed a nice 3330MHz clock, but that was about it.
                      I see nobody made any guesses about the temperatures yet.
                      • ktmmotocross
                        Boardkiller
                        • Feb 2014
                        • 3614
                        • slovakia
                        Ooooooooooo nice one man u give me lot of ideas :-)
                          • 31137
                          i hope you know how big the fine is if the government catches you putting Pb solder in a RoHS product!!!
                          • Th3_uN1Qu3
                            Believe in
                            • Jul 2010
                            • 6031
                            • Romania
                            Technically it's not RoHS - the nvidia chips are soldered to the substrate with high lead bumps.
                            • spleenharvester
                              • Mar 2010
                              • 913
                              The reason the voltages are so high is that it increases yield. Many chips will only run stably at higher voltages. Some good quality chips can run at much lower voltages. So by increasing the default voltage fewer of them wind up in the "bad" bin.
                              Similar situation with CPUs, I've had Athlon IIs that can be undervolted rediculous amounts and still be stable. I've also had some that crapped out barely below the stock voltage.
                              The same situation is true for CPUs and GPUs produced in modern times; without the defect. Even if the part doesn't last as long, manufacturers won't give a damn, as long as it fails as soon outside the warranty period as possible.
                              Very interesting writeup eitherway.
                              Dell E7450 | i5-5300U | 16GB DDR3 | 256GB SSD
                              • Th3_uN1Qu3
                                Believe in
                                • Jul 2010
                                • 6031
                                • Romania
                                It's not quite like that - i'm sure the manufacturers WILL give a damn if they made a mistake in the past that cost them $200 million... I was just pointing out that there is yet another side to the big nVidia issue that very few people have investigated.
                                • Th3_uN1Qu3
                                  Believe in
                                  • Jul 2010
                                  • 6031
                                  • Romania
                                  Nobody curious? Let me spice it up a little. If i told you this thing idles at 50C and loads at low 60s, with 23-25C ambient, would you believe me?
                                  • dj_ricoh
                                    • 2073
                                    • uk
                                    NO!
                                    what? over 3-4 years a notebook? Are you bloody insane?
                                    2 years then they can buy another notebook!
                                    Big difference between manager and Engineer!
                                    the Engineer does what the manager tells him
                                    • Th3_uN1Qu3
                                      Believe in
                                      • Jul 2010
                                      • 6031
                                      • Romania
                                      It's actually 6-7 years. But i'm not talking about now. nVidia lost the lawsuit back in 2009 and it hit them hard. And by the looks of things, they're not very fast to learn from their mistakes... My point is, a lot of those laptops didn't MAKE IT the 2 years warranty, and they had hundreds of thousands of them to deal with.
                                      • sopik78
                                        • Nov 2013
                                        • 517
                                        • Czech Republic
                                        And what about Ati? Has anybody tried to undervolt that damn RS780/880?
                                        • Instafixx
                                          Macbook A2179 820-01958
                                          by Instafixx
                                          Have a Macbook A2179 with liquid damage. Customer showed it some shop which has done an ultrasonic cleaning of the board.
                                          The board pulls 0V but doesnt turn on. No Fan SPIN. NOT IN DFU.
                                          I checked the Power Sequences below and found this -
                                          Once a valid external power source (Charger or battery) is connected, the following rails will come online.
                                          PPBUS_G3H: Normal voltage is ~12.6v on the charger with the battery disconnected. Produced from the ISL9240 (U7000, which uses PPDCIN_G3H as its VIN.
                                          PP3v3_G3H_RTC: Normal voltage is ~3.3v. Produced...
                                          05-20-2023, 05:19 AM
                                        • Fernon@Repair
                                          Gigabyte Z490 Gaming X Motherboard No VCORE Voltage
                                          by Fernon@Repair
                                          i have Gigabyte Z490 Gaming X Motherboard .it has a power on no display fault .. no vcore voltage and debug led stuck CPU LED .
                                          VCCIO voltage ok
                                          VCCSA Voltage OK
                                          VCCPLL Voltage OK
                                          Ram Voltage ok
                                          RamVTT OK
                                          VPP 2.5 OK
                                          But No Core Voltage
                                          and i want to this vrm ic datasheet or pinout (ISL69269)
                                          anyone have this ic pinout voltages?...
                                          06-25-2025, 07:19 AM
                                        • electron_jj
                                          Panasonic TH-L42D25A checking the PSU output voltage
                                          by electron_jj
                                          Hi Everyone, I am new to this forum. I have a Panasonic LED TV which doesnt turn on and is blinking 4 times repeatedly when I turn on the switch. The TV does not respond to the remote control so I had to turn on using the physical switch on the side of the TV. When I turn on the switch the 4 x blinking starts and repeat itself until I turn off the TV. There is a black screen. I turned off the light in the room to check the panel and I think there is no backlight as far as I can tell.
                                          I have been inspecting and testing the capacitors and diodes in the power supply board to try to...
                                          08-29-2021, 08:13 AM
                                          Trip light 2400 watt line conditioner bought used issue with low voltage oscillation going on between relays
                                          by sam_sam_sam
                                          I found two capacitors on the board and one of the leads on one capacitor had bad soldering joint and the other joint connections not much better and there were several soldering joints that way to much flux around the joint redid several of them
                                          The capacitors were a non brand that I did not recognize they got replaced and now it does not oscillating between relay but what concerns me a little bit is when the voltage is a little bit low the output voltage is around 130 volts and then drops down to 115 volts this happens around 105 to 108 volts if remember correctly
                                          Now...
                                          06-09-2024, 10:57 AM
                                          ISL95831HRTZ ISL95831HRTZ-T ISL95831IRTZ ISL95831IRTZ-T Voltage Regulator Datasheet
                                          3+1 Voltage Regulator for IMVP-7/VR12 CPUs
                                          Compliant with IMVP-7/VR12, the ISL95831 provides a complete solution for microprocessor and graphic processor
                                          core power supply. It provides two Voltage Regulators (VRs) with three integrated gate drivers. The first VR can be
                                          configured as 3-, 2- or 1-phase VR while the second output is 1- phase VR, providing maximum flexibility. The two VRs share the
                                          serial control bus to communicate with the CPU and achieve lower cost and smaller board area compared with the two chip approach.
                                          Based on Intersil's Robust Ripple Regulator...
                                          11-05-2024, 03:24 PM
