Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 04-15-2007, 01:03 AM   #1
pentium
pentium's Avatar
City & State: Kamloops BC
My Country: Canada
Default Intel PD440FX won't POST
I was given this board from a guy whose computer was ejected from his trailer (potholes are nasty around here) and rolled about 100 feet to the bottom af an embankment. I had to use the jaws of life (a car lift) to pry the case open enough to get to the screws and pull the board out. Besides one damaged trace that I easily fixed the board has some nasty bending that should settle out once it's in a case.
Anyways, when I set the board on my test bed (a rubber padded table with an ATX psu, monitor, PCI video card, keyboard and mouse and turned the thing on I got nothnig. To be positive that the system was not dead dead I pulled on stick of rm and I got the sandard three long beeps which indicate a memory error so I knew the bios was ok. I then double checked all settings and they all were properly set. I checked the cpu and it was properly seated and I know for a fact that there is no problem with bad caps. It only uses sanyo caps ( purple with no vent seam on the top) and nichicon PM(M) caps along with a few poly caps.
Wow, I'm stumped on this one.
Find Nedry!
Check the Vending machines!!
<----Computer says I need more beer.
pentium is offline   Reply With Quote
Old 04-15-2007, 04:47 AM   #2
Rainbow
City & State: Slovakia
Default Re: Intel PD440FX won't POST
As it's bend, there are probably some solder joints broken.
Rainbow is offline   Reply With Quote
Old 04-15-2007, 08:55 AM   #3
kc8adu
kc8adu's Avatar
City & State: dayton ohio
that amout of bending will also break smt caps and resistors.
its toast.
kc8adu is offline   Reply With Quote
Old 04-15-2007, 12:05 PM   #4
pentium
pentium's Avatar
My Country: Canada
Oh rats.
Thanks guys. I didn't want to work on this board too much before I found out it was dead.
