Panel swap fail: Image reddish
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    I had an LG Flatron L204WS with broken LCD panel and today I got a LG Flatron L207WT that missed a power supply. I took the panel of the L207WT and used it on L204WS. The display works but the image has some artifacts.
    Can you tell me what is wrong? Can the panel die like that? Is the signal board bad? I have no experience with this.
  • goodpsusearch
    • Oct 2009
    • 2848
    • Greece
    Re: Panel swap fail: Image reddish
    I tried to take some images but it is difficult to show from the pics how bad the image is
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      Are the t-con boards the same? If not, see if they will interchange. You;re using a panel with different numbers, so there's some kind of difference apparently.... The t-con board is what drives the panel, so if they are too numbered differently but plug in the same (check that very carefully before trying), that may clear it up.
      <--- Badcaps.net Founder
      Badcaps.net Services:
      Motherboard Repair Services
      http://folding.stanford.edu/
      Team : 49813
      Join in!!
      Team Stats
        You have to get the LCD panels spec to compare the pinout of both panels.
        • goodpsusearch
          • Oct 2009
          • 2848
          • Greece
          They look compatible to me. I upload photos of the 2 panels.
            Same pinout:
            Cannot find V.1, V.8 has the same pinout as VC.
            So I do not know why you have the problem.
            • Topcat
              The Boss Stooge
              • Oct 2003
              • 16955
              Double check all your ribbons on your t-con cable connections. I had a TV do this to me, except it was green and artifacting.... Reseated everything and it went away.....or perhaps thats why that monitor was parted out, the pane is bad in the first place.
              Team : 49813
              Join in!!
              Team Stats
              • goodpsusearch
                • Oct 2009
                • 2848
                • Greece
                I disassembled and reassembled everything and the problem was solved. I also used tape to secure the cables.
                I was not impressed with the image quality, but after several hours messing with monitor controls and gamma through windows I find it acceptable
                This is going to be my everyday pc's monitor, replacing a 17 inch Samsung 710N that served me great :-)
                Thank you for your advice!
                • goodpsusearch
                  • Oct 2009
                  • 2848
                  • Greece
                  One Su'scon capacitor bulged.
                  I found out 1 week ago while I was aiming with my flashlight through the ventilation holes of the screen chassis.
                  I did a full recap:
                  • Sus256
                    HISENSE 65E7KQ PRO - no boot
                    by Sus256
                    Hi all!
                    HISENSE 65E7KQ PRO
                    RSAG7.820.13512 - chassis
                    MT9618BAATAB - cpu
                    RSAG7.820.12059 - power
                    HD650Y3U77 - panel
                    KLM8G1GETF - emmc
                    The TV does not turn on, the standby indicator is on. All voltages are present.
                    Emms is dead. Not readable, not detected.
                    Replaced emmc.
                    But with another dump there is no launch
                    Terminal log
                    UART
                    AC_ON
                    RPMB key is not yet programmed
                    HASH1_VERSION=0x00000000 64bit
                    E-B
                    FDE enabled
                    layout pattern onebin by SAR7,0...
                    06-01-2025, 02:11 AM
                  • dragometin
                    Hitachi 40HYC42
                    by dragometin
                    TV Model: Hitachi 40HYC42
                    Power Supply: 17IPS71
                    MainBoard: 17MB95M
                    Panel: VES400UNDS-2D-NO3
                    When the set came in it was dead. Fuse was open primary side and the power mosfet was shorted. So I ordered a new power supply. Now it turns on, only displays "Hitachi" and then power off red and blue led flashing.
                    I had to modify the 0ohm resistors in the led backlight of the new PS like the original power supply.
                    Is there any variants on 17IPS71 power supply's?
                    UART output pins 10 and 12 on scart connector:
                    Code:
                    12:24:04.595
                    08-08-2024, 05:53 AM
                  • r3vsEngIT
                    Sony Panel Swap Experiment 65x900h with the panel from a 65x930d
                    by r3vsEngIT
                    65x900h with the panel from a 65x930d.
                    900H: model yr 2020, Samsung panel
                    930D: model yr 2016, Innolux panel
                    spec wise the panels are the same. the drivers and tcons are obviously different but what made me want to give this a try is that the wiring diagrams for the data signals going into the tcon for each tv were nearly identical. there are only a couple pins that i am unsure about and that is what brings me here.
                    the 930d has the DPS board where the 900h has none, however, if you follow the pins to the BM1 it would appear that the signals...
                    07-11-2023, 11:11 AM
                  • Raulnn
                    Tdsystems K40dlt3f Panel V400HJ6-PE1 REV C2 short circuit no image
                    by Raulnn
                    good evening. I have put the panel model, because it is a generic Chinese tv. The symptoms are the following: The rear light turns on, but there is no image, 12v arrives at the tcon integrated in the panel. I have made measurements of vgl, vgh and vaa. They are not present but they all act as rectifiers except for vaa, which is shorted. my questions are. Do you know any quick method to know the capacitor that is shorted without having a laboratory source? How could I know the value of the capacitor once extracted? I can't find schematics for this panel. a greeting
                    12-20-2022, 05:11 PM
                    HP Elite Slice G2 + Image Load & Asset Tag Elite Slice i5-7500T Specification for Upgrade or Repair
                    This specification for the HP Elite Slice G2 + Image Load & Asset Tag can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the Elite Slice G2 + Image Load & Asset Tag boardview and Elite Slice G2 + Image Load & Asset Tag schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please...
                    09-12-2024, 02:20 PM
