Dyp-42w2plus bn44-00194a
  • flocko
    • Nov 2012
    • 1121
    • uk
    have this 50" Samsung come in with red standby light will not power on, checked power board and 5v standby is good and PS-on is 4.6v when in standby and goes low when power button on remote is pressed but relay fail to click,have pulled the board and put 680ohm resistor from PS-on to grd still no relay click started pulling and replacing caps,but getting nowhere fast any one had this with this board, it also looks to have been worked on in the past
  • flocko
    • Nov 2012
    • 1121
    • uk
    Re: Dyp-42w2plus bn44-00194a
    Has anyone seen any of the VIPer 22A primary switcher chip go bad on these boards, have not looked up the pin out for it but will check tomorrow and see if it tests out
      Since you have 5VSTBY, that means the VIPER22 is working, you need to check the circuit around QB803, QB804, ICB802.
      • Ltank
        • Jun 2013
        • 776
        How low of a dvc when it drops? Does it go low enough? Q402 is not turning on. If circuit was working properly Q402 has a .7vdc drop.
        LVT817B has a .7vdc drop leaving 3.6 vdc at anode of optoisolator. With 3.6vdc on anode and 4.6vdc on base of Q402 the transistor is not turning on and the led part of the optoisolator is reverse biased; therefore it too is turned off.
        Try jumpering a low to grouund through a 500 ohm reisistor to the base of Q402. It should turn on both the transistor and thhe optoisolator. It aperars that
        this set turns on with a active low not a high.
          QB402 is for the UV-Reset, do you mean Q401 (is normally ON) which when PS_ON pin is grounded, the Collector will rise up and allow 5V to get to the LED in Opto PCB803S/A?
          • flocko
            • Nov 2012
            • 1121
            • uk
            Thanks guys for the input, Will have a look at the voltage reg ICB 803 and check transistors in and around it tomorrow
            • Ltank
              • Jun 2013
              • 776
              My Mistake I miss read it. I thought it said PS-on but what I see now is VS-on. I was on page 4 lower right corner when I made the mistake
              • capricorn64
                • Sep 2014
                • 15
                • England
                Hoping someone can help, I have pulled the power board from my Samsung tv, as I keep getting a clicking from the relays on the hot side of the board which is a DYP-42W2PLUS , 220V input supply, I have checked all the caps and all seem to fine . When I disconnect the plug from the CN801 port the clicking stops, I get 4.86V at the standby but nothing else 12v measurement non existent , I also get no readings from Vs205 or Va63.
                Now I am assuming that a voltage regulator has gone down ,but I have no idea where to start looking for the fault if anyone has any ideas as to where I should be looking I would be most grateful, thanks in advance guys .......Steve
                • flocko
                  • Nov 2012
                  • 1121
                  • uk
                  Hi you need to test power supply out of he set with the mains connected you should have the 5v stby on the bottom right connector on pin 1, if you have that by making Ps on pin 4 Low to grd that will bring the relay in and give all voltages apart from Vs , to bring in Vs voltage jump Vs on pin 2 to 5v stby pin 1 with 500 ohm resistor. I hope this helps , the fault I had was that the relay would not come in when Ps on was made low the problem was tracked down to a fault relay coil the relay was replaced and fault was no more Flocko
                  • capricorn64
                    • Sep 2014
                    • 15
                    • England
                    Thanks Flocko I will give it a try I think I understand what you mean !!!
                    • capricorn64
                      • Sep 2014
                      • 15
                      • England
                      I have done what you advised ps on to grd which activated the relay (clicked on ) but turned of straight away so I am surmising that I could possibly have a relay problem aswell as voltages at pin 8 and 9 which are D5.3V are only reading -.250v would I be correct in my assumption ??
                        Ground the PS_ON and then check the VCC_P (for RL802S) and VCC_S (for RL801S) DC Voltages which are for driving the relay coils to see if they are steady, use the negative leg of the main filter cap for meter ground ref. points. See page 1 of the SCH.
                        • capricorn64
                          • Sep 2014
                          • 15
                          • England
                          Thank you budm I will give this a try.
                          • flocko
                            • Nov 2012
                            • 1121
                            • uk
                            I would look at all the soldering on the back of the board for cold joints as these board do have lot of problems with these , I do hope you have also checked the fuses? if you don't find and cold /dry joints then we need to start testing for shorted FETs Flocko
                            • capricorn64
                              • Sep 2014
                              • 15
                              • England
                              Hi guys
                              The saga continues......I have changed out the relays for brand new ones, I now have a strong 5v at standby which is encouraging....or is it ,at the d5.3v its reading .756v so I guess I have a problem with the fets, trouble is I seem to be doing a lot of guessing.......
                              • Neelix
                                • Oct 2013
                                • 145
                                • South Africa
                                You get any 12V_OUT or 18V_Amp voltage? If not, you get any voltage at pin 15(VCC) of ICX801?
                                • flocko
                                  • Nov 2012
                                  • 1121
                                  • uk
                                  Are you now saying that the relay clicks on and stays on when you ground PS -on (pin 4)? before you were saying it come in then went off.
                                  • capricorn64
                                    • Sep 2014
                                    • 15
                                    • England
                                    Neelix
                                    I have checked voltage at pin 15(VCC) and all I am getting is -0.06V , getting nothing at 12V_OUT or at 18V_AMP !!
                                    Flocko
                                    Still getting the relays switching on and then going off straight away when I ground PS - on !!
                                    Pretty flummoxed now ?
                                      Originally posted by capricorn64
                                      Neelix
                                      Flocko
                                      You are not going to get any Boosted PFC Voltage, 5.3V, 12V, 18V_AMP until you can get those two relays to stay on. If you look at the diagram:
                                      Those two relays get their voltage from the standby power supply AUX winding TB801S, the Voltage is then fed through switched QB803, ICB802 (regulator), QB804 they are turned on when the opto OCB803S is turned on the PS_ON signal.
                                      So, do you have steady STD_5V? Did you check the voltages at VCC_L, VCC_P, VCC_S that I suggested you to test? see post 12 and see the schematic to get more understanding how it works.
                                      • flocko
                                        • Nov 2012
                                        • 1121
                                        • uk
                                        Just a thought you are keeping PS-on grounded not just flashing it ?it need to be held to ground all the time Flocko
                                        • tvguy12012012120
                                          by tvguy12012012120
                                          02-07-2025, 05:13 PM
                                        • fharris1977
                                          Vizio D50u-D1 Dead Set No Standby
                                          by fharris1977
                                          Hi. I got a Vizio with no power or standby, and won't turn on with remote or button. I checked the voltages on the connector and all read 0.00V or nearly 0(0.050 ON/OFF pin). None of the pins are labeled STB for standby although I do see some 5V pins. Other than the obvious standby led, which isn't coming on, is there a way to check for standby voltage on this PS. I'm trying to see if my problem is the PS or mainboard. Some Vizios I have fixed with no standby led me to think it was the PS but it turned out being the mainboard. Any experience with this set would be greatly appreciated.
                                          12-28-2023, 10:25 AM
                                        • Crystaleyes
                                          Samsung BN44-00259A standby question
                                          by Crystaleyes
                                          Hi all.
                                          I started a thread while back regarding TV power supply standby circuitry as it is something I am not quite on top of.
                                          SMPS theory and function is becoming more familiar, however the standby part is still a bit of a mystery.
                                          Anyway, a friend has this TV with the above mentioned power supply board which has no standby voltage, nor any other voltages leaving the board.
                                          The mains AC comes in fine, gets filtered and rectified with power is on the main filter cap as well as the transformer and drain pins of the ICE3B0665J, but that's it.
                                          08-11-2023, 05:15 AM
                                        • psssst
                                          Yamaha TSX 120 Standby Problem
                                          by psssst
                                          Hello forum. I've recently been given a Yamaha TSX 120 DAB radio and ipod dock. Its working well however when put on standby its using 6.3 watts. The manual states less than 1 watt on standby. I measured this with a plug in monitor which seems accurate with other items. In use it uses around 7.5 watts. Firstly has anyone who owns a similar radio also got a plug in monitor to check if this is normal with this unit? In the first half a second the monitor shows 0.3 watts which I suspect is what it should use but something is switching it to be almost fully powered. I've searched the manual for eco...
                                          03-01-2024, 07:25 AM
                                        • reessi
                                          JSK4228-050 Power Supply Standby voltage changing! (Possible from Wharfedale LTF37K1)
                                          by reessi
                                          I am trying to re-purpose this power supply that I saved years ago from a tv with a cracked screen for a monitor but that is not really that relevent at the moment. I do not recall which tv but a google search looks like it is from Wharfedale LTF37K1.
                                          You may notice I made some alterations moving some components to the top and some wires which are from a 5v regulator I fitted to the 12v output as the monitor requires 5v. The standby was already at fault from the beginning, it has nothing to do with the alterations...
                                          Years ago it had some bulging caps...
                                          04-26-2021, 11:42 AM
