Hi guys, I found an HP 2509m in the bin, and would like to try and fix it. The large size and built in speakers seem like it would be good screen for my father.
So I've read up a bunch on this beast, and it seems like one or both mosfets on the daughter board are shot, as well as the accompanying diode, maybe an IC, and maybe a resistor. Also, I'm certain once I get the board working properly, the bulbs will be shot and I'll have to replace those.
I've read through many threads, including:
https://www.badcaps.net/forum/showthread.php?t=24866
https://www.badcaps.net/forum/showth...ighlight=2509m
https://www.badcaps.net/forum/showth...BDG#post117302
http://h30434.www3.hp.com/t5/Desktop...s/td-p/1210387
http://h30434.www3.hp.com/t5/Desktop...D/td-p/1643025
which seem to capture the gist of the problem.
I am comfortable with the component replacement on this tiny board, but unsure of which parts to buy.
The components in question on the board are:
mosfet #1: Nikos P5506BDG N-channel
mosfet #2: Nikos P9006EDG P-channel
Diode: SR26 PJ039
IC: INL816GN AA3113.1N 1016A1
and 105 ohm surface mount resistor
I've read that for the P5506BDG fet, I can use STD20NF06L, FDD8451, or FDB6030L
for the P9006EDG, the only thing I've seen is AOD413
for the diode, I've seen STPS2L60 and SS26, easy enough
No idea about the IC, or if it's even required
and the resistor has 105 on it, so I assume a 105ohm surface mount is what I want, but digikey has so many options that I'm unsure of, like wattage and such.
If requested, I can desolder the caps blocking view of the daughter board and get some pics if it'll help.
Thanks in advance!
Alex
Diode: SR26 PJ039
Thanks in advance!
Alex
