LG 37LF65-ZC No Backlight
  • Daveatfernie
    • Nov 2013
    • 70
    Good Morning All.
    After searching for my model number and finding a different inverter set from the one installed in my TV and with a different problem I thought I'd post for help in a nerw thread.
    I have an LG 37LF65 which I bought on Friday, The seller said that the TV had sound but no video. It appears to have no damage to the Screen. When powered up I can't see anything with a torch although my light isnt the best and I don't know where the OSD is on these TVs.
    I opened the rear and found that there were two leaking caps 680uF @35V on the inverter board and replaced them with good Low ESR caps.
    I then powered up the TV and got nothing at all. Green light flashes about 5 times, then stays illuminated green. Nothing on the screen with torch. No flash from the backlight.
    I checked all other caps in the TV (main PSU board mainly) and replaced any with an ESR above 0 on my Atlas ESR Meter with a new lower ESR version, Marking each one with a pen mark as I went.
    Powered up again and still found nothing.
    All voltages coming from the Main PSU board are present and correct to labels, I'm seeing a VSync square wave signal coming from the TCon board@ about 100Hz, 24V is present to the inverter board.
    Other voltages are as below:
    Option pin from TCON: Seems to be sending Data to the Config chip during startup and shutdown
    ADIM
    ON/OFF
    BRT
    Status
    All sit low when powered off (and discharge from on fairly slowly)
    When powered all lines are pulled high to 24V.
    I've checked all 4 of the the FETs and none show short.
    The input winding to the transformer is at about 0.2 ohms and the secondary is about 150 Ohms.
    I have a 16W 16CFLD4 but i'm sure its just a standard fluorescent tube rather than a CCFL. Will I be able to test my inverter with this?
    This all appears (Granted to someone new to this) as looking ok?
    Am I looking at a CCFL failure?
    Re: LG 37LF65-ZC No Backlight
    Place the fluorescent tube near the inverter board outputs. Unplug the outputs. The tube should glow slightly for a few seconds if high voltage is present. You might need to use a neon-bulb (small type) in case a fluorescent is too big. The inverter shuts off after a few seconds if no bulbs are connected, so you will have to repeat the test a few times.
    • Daveatfernie
      • Nov 2013
      • 70
      Thanks, I'll have a try in the morning (tv is at work). If the lamp lights I assume it's the CCFL?
      I did measure a pulse to the primary of the transformer which is momentary (less than a quarter second).
      • Daveatfernie
        • Nov 2013
        • 70
        Tried the tube next to the transformers, not a peep. I can hear a faint detuned channel noise from the speakers.
        Is it worthwhile swapping out the os9966 ic on the inverter board? Do these often go?
        • Repairtechlcd
          • Nov 2013
          • 12
          • Malta
          Check for s/c on the os9966 and give it a close inspection for possible burn marks.I wouldn;t be surprised that it failed due to the ripple caused by those two bad caps you had on the invertor boards.
          • mmartell
            • Oct 2013
            • 3189
            Longshot for you but I've seen it first hand...
            See that ribbon cable going into the left side of the t-con ? Unplug it and fire the set back up.
            • Daveatfernie
              • Nov 2013
              • 70
              The one that has the VSync and option cables? I'll have a go and see what happens....
              • Daveatfernie
                • Nov 2013
                • 70
                Unfortunately nothing happenned. I assume that the problem is with either the inverter or the tubes themselves. I'm going to order the Inverter controller IC as it's only about £4 from ebay. Failing that I can get a new set of 37" CCFL's for about £20 delivered. Still makes for a cheap TV. (Reconditioned TV's are about £170 on this model).
                • mmartell
                  • Oct 2013
                  • 3189
                  I should have asked for a closeup of that part of the board. Does that ribbon run from the tcon back to the inverter ?
                  On mine it controlled a dimming circuit that some LG sets have apparently to cheat on their overall contrast measurements.
                  • mmartell
                    • Oct 2013
                    • 3189
                    Disregard my last post. I see you posted before me.
                    • Daveatfernie
                      • Nov 2013
                      • 70
                      Thanks for the reply but looking at the fact that I don't even get a flash I'm leaning towards the Tubes, I do see a quick peak on the primary side of the transformers but no flash and it seems by all accounts that I shoudl at least see that. I'll have the screen apart and hunt for a cracked tube.
                        There are many tubes in parallel, tubes would be unlikely to cause this. It's possible though that there's a short inside the panel causing this issue.
                        • Daveatfernie
                          • Nov 2013
                          • 70
                          I assumed they'd be in series as there are only two leads from the inverter board rather than a bank of cables as I've seen in other TVs?
                            If it's an LG panel they are all in parallel. One wire goes to one end, the other goes to the other end. EEFL tubes, high reliability.
                            • Daveatfernie
                              • Nov 2013
                              • 70
                              Ah right, How about the driver IC, Are these known to be reliable?
                                They frequently fail.
                                • Daveatfernie
                                  • Nov 2013
                                  • 70
                                  I also assume that I can't swapp EEFLs with CCFLs?
                                    Not unless you swapped all of them at once, and were able to replicate the external electrode (versus cold cathode type.)
                                    EEFL vs CCFL:
                                    http://upload.wikimedia.org/wikipedi...L-EEFL.svg.png
                                    Because the electrode to the bulb is external the typical failure mode is mercury sputtering around 150,000-200,000 hrs. A CCFL can last 40,000 hrs to 60,000 hrs (sometimes less, I've had them fail at 15,000 hrs), limited by the internal electrode degrading from the ion depletion and very high temperatures. (Cold cathode just means they aren't deliberately heated, it doesn't mean that they don't get hot!)
                                    • Daveatfernie
                                      • Nov 2013
                                      • 70
                                      I'll swap the IC and hope for the best then...
                                      • Daveatfernie
                                        • Nov 2013
                                        • 70
                                        I see on ebay there are a number of inverter boards for the same price as the ic.
                                        Does anyone know if inverters are cross compatible?
                                        My inverter is a single board lc370wu3
                                        • ttmi100x
                                          HANNSG Hi221 -- 2 secs to black feat. CCFL flicker & "burn" marks on power board
                                          by ttmi100x
                                          Greetings everyone,
                                          I have a HANNSG Hi221 monitor that exhibits two seconds to black issues (backlight goes off, display is still on as confirmed by shining a flashlight on it) with some additional oddities...
                                          The monitor failed on me with a standard "2 seconds to black" some time ago prompting me to initially replace most of the electrolytic capacitors (some of them were bulging/leaking).
                                          Things kinda sorta worked for a night, then the problem returned along with some flickering and "buzzing" noises.
                                          Upon closer inspection...
                                          07-31-2024, 06:36 PM
                                        • signal.quest
                                          Samsung LN40C630K1F LCD TV No Backlights and Flashlight Test Fail
                                          by signal.quest
                                          I have been working on a Samsung LN40C630K1F LCD TV. On power up the backlights only briefly light up when first powered on then they go out (2 seconds to black). The flashlight test also fails. The sound works fine. Please see attached pics.
                                          I have researched the forums a lot. I have watched the videos of trying to locate the bad CCFL or transformer and bypassing. I can't find any evidence of a bad transformer/CCFL. I verified I get 376V from the big caps to the fuse. I have used a small/cheap oscilloscope and it looks like the MOSFETs on the inverter...
                                          09-30-2024, 11:21 PM
                                        • x_orange90_x
                                          Vizio E55-E1 bad backlights or bad inverter?
                                          by x_orange90_x
                                          I just got this tv today and it appeared to have no backlight on. After taking off the rear cover and checking again in the dark I can see that MAYBE one quadrant is lit.. But still it's quite dim. I was going to check the LEDs with my tester, and I found LED 1 and LED 2 + pins on the wire from the inverter, but I couldn't identify a ground. Nonetheless I tried using a mounting screw on the inverter board and also the chassis as ground but regardless my tester reads 300 which is what it reads when there is no voltage draw.
                                          I don't know how exactly to test the inverter itself. Is it...
                                          01-29-2025, 09:24 PM
                                        • EvazX
                                          ASUS ROG G513QY – RX 6800M powered but not detected intermittently + random crashes (Motherboard: 6050A3254002-MB-Axx)
                                          by EvazX
                                          I am working on an ASUS ROG G513QY laptop with RX 6800M dGPU.
                                          Originally, this laptop was completely non-functional. I replaced the motherboard (part number 6050A3254002-MB-Axx), and with the replacement board it started working fine.
                                          For a long time, the dGPU worked perfectly stable. I played several hundred hours on very demanding games such as Cyberpunk 2077 without any crashes, instability, or detection issues. Performance was excellent and there were no warning signs of failure.
                                          However, after some time, the replacement motherboard...
                                          08-25-2025, 06:09 PM
                                        • lostone
                                          Looking for help with a Viewsonic VP230mb where the backlight comes on only momentarily
                                          by lostone
                                          Hello, I came here after finding some similar questions asked on other monitors and hope someone here can help me get an ancient Viewsonic VP230mp (23" 4:3 LCD) back to working condition.
                                          First a little background, I have a background in computer and electrical engineering, and I'm smart enough to know I know nothing about LCD displays and how they work. For this topic I'm as green as they come.
                                          When the display is turned on the viewsonic logo displays in the uppper left for 2 seconds then the screen goes black, the power LED is green (on) and when a computer is connected...
                                          05-19-2024, 11:40 AM
