Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Power Supply Design and Troubleshooting
Old 11-15-2013, 04:03 AM   #1
tn245
City & State: South East
My Country: UK
Line Voltage: 230Vac 50Hz
Default Vestel 17PW25-4 repair - resistor value?
I bought a repair kit for this TV power supply. Shorted diodes, FET and several tiny surface mount components to replace. On starting the repair I noticed someone had had a try before me and even helpfully ripped up some of the PCB pads. In spite of that I think I've managed to get everything in place and connected up correctly.
My question. The schematic for this power supply (attached) lists SMD resistor R923 (off pin 4 of FAN7529) as 15R, but the repair kit supplied 100R and the one I removed from the board was also 100R (bearing in mind someone had repaired it before - maybe with same kit?). I wrote to the kit supplier to ask about it and he hasn't replied.
As I don't have the electronics knowledge to know what that resistor value should be, do you think there's any reason a 100R might be supplied instead? If I go ahead and use 100R might there be any consequences?
Thanks!
tn245 is offline   Reply With Quote
Old 01-01-2015, 06:10 AM   #2
Klockaren
City & State: Årjäng
My Country: Sweden
Default Re: Vestel 17PW25-4 repair - resistor value?
Thanks!
I have the same problem regarding R923. I havent got any schematics with the right value for this resistor.
Then R980 are broken and I can't see the numbers on it. Schematics says 15R for this also, but I don't trust on this.
Do you got any correct schematics for this board?
/Gunnar
Klockaren is offline   Reply With Quote
Old 07-31-2015, 12:02 PM   #3
steviewonder
City & State: Littleborough
My Country: england
bit of a old thread,but just had the same problem.
R923 is indeed 100 ohm,the schematic is incorrect.
steviewonder is offline   Reply With Quote
Old 07-31-2015, 06:49 PM   #4
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
15 Ohms or 100 Ohms is not going to make any difference, the there is 40K internal resistor/Capacitor filter feeding the input of comparator circuit inside for that Current Sensing (CS) pin. if you look at the app note circuit, you do not need the resistor.
Badcaps.net Technical Forums © 2003 - 2017
