Old 10-07-2013, 08:15 AM   #1
LEEDASH
City & State: Bedford
My Country: Bedfordshire
Default Megmeet mlt666t board
Hi all i have a technika 32-56 lcd tv set,it has power issues,switches on once the not again,so i purchased another power board (mlt666t) of a well know auction site and guess what it still does not switch on not even a flicker,the boards i are both the same part number,but the date is different,would this make a difference ?
REV:1.2a 2008.11.06 or-
REV:1.2a 2008.09.02
LEEDASH is offline   Reply With Quote
Old 10-07-2013, 08:21 AM   #2
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: Megmeet mlt666t board
Probably a date of manufacturer.
Do you have a multimeter? - check PSU outputs are stable including standby voltage.
tom66 is online now   Reply With Quote
Old 10-07-2013, 08:44 AM   #3
LEEDASH
Unhappy Re: Megmeet mlt666t board
Ok,very annoying though,seller got brilliant feedback and even in the listing its been apparently tested,-what else could it be ???
Old 10-07-2013, 08:45 AM   #4
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Uh, no-one (well almost no-one) test the boards on eBay.
Have you actually CHECKED the power board to find out if the original was bad before replacing it? Otherwise, you may be chasing a wild goose.
Old 10-07-2013, 09:32 AM   #5
LEEDASH
Hold my hands up I did not check the original board,I had to flick the on/off switch until the set came on,then did not power on again,hence why I bought another one.
With this new one I'm not get light or naff all,I'm only a newbee and wouldn't know how to test unless you could tell me the basics,then i will test both boards,all I have is a multimeter though.
Old 10-07-2013, 10:15 AM   #6
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Well I would be considering main board TBH with those symptoms.
Checking power board outputs: locate each connector, multimeter in 20VDC range for voltages up to approx 18V, and in 200VDC range for 24V/33V outputs.
Red probe on each pin of each connector, black probe on chassis. Note reading down and compare to labelling, if available. Test in several states: standby, working first time, second standby, failing second time.
Old 10-07-2013, 10:54 AM   #7
LEEDASH
Hi when you say check each connector does this included the two pin power lead one ?
Old 10-07-2013, 10:55 AM   #8
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Not presently, though checking your input AC voltage can also be a good check just as a general thing to rule out. Use the 750VAC range.
Also do NOT test any outputs marked HIGH VOLTAGE e.g. if board has inverter built in. Typically white/pink/sky-blue wires.
