Old 08-22-2013, 02:32 PM   #1
Pentium4
CapXon Be Gone
Pentium4's Avatar
City & State: WA State
Line Voltage: 120VAC 60Hz
I'm a: Hardcore Geek
Default Magnavox 32MF301B/F7 board swap
This Magnavox TV doesn't power on at all. It was very obvious why right when I opened it, the fuse is blown. And it looks like an extremely low quality power board. I'm guessing there are some shorted diodes somewhere and that the fuse would just blow again if replaced. The customer wants the TV back ASAP, so I was just going to do a board swap and replace the 85C caps.
The stock board is a BA17F8F0102 2 and the one I'm looking at online is a BA17F1F0102 5. It looks to be the same type of board with a smaller caps and a nichicon primary instead of HEC... Should it work correctly?
Buy quality, and you only cry once
Pentium4 is offline   Reply With Quote
Old 08-22-2013, 02:34 PM   #2
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: Magnavox 32MF301B/F7 board swap
I can't see why it wouldn't work.
Old 08-22-2013, 02:43 PM   #3
Pentium4
CapXon Be Gone
Pentium4's Avatar
Just wanted to make sure, not a TV expert haha. I'm surprised Magnavox would use such a cheap board. Or is this just a rebranded "Funai" set?
Old 08-22-2013, 02:47 PM   #4
aaronwt6
City & State: Savannah, Georgia
My Country: US
I'm a: Hobbyist Tech
I would at least try the fuse. I had two of these exact boards that were indeed bad but did not have a blown fuse. The one I did get in with a blown fuse had been through a lightning power surge and it was indeed just the fuse. Pretty quick fix.
Both of the boards I replace had very obvious heat damage on them which yours does not have.
Anyway, based on my experience I'd sacrifice one.
aaronwt6 is offline   Reply With Quote
Old 08-22-2013, 02:48 PM   #5
aaronwt6
My Country: US
Rebranded. There is a Phillips, Magnavox, and Emerson model that are all exactly the same set. I've had one of each unfortunately.
Heck if nothing else, jump the fuse temporarily to see if it powers up. What's the worst that can happen, smoke?
J/K of course
In all seriousness though try the fuse.
Old 08-22-2013, 03:00 PM   #6
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Don't jumper the fuse. You can replace it with a new one, but DON'T jumper it!
Old 08-22-2013, 03:08 PM   #7
Pentium4
CapXon Be Gone
Pentium4's Avatar
Haha alright thanks I'll look around my pile of scrap to see if I can find a suitable fuse
Old 08-22-2013, 03:13 PM   #8
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
One of those that blow out the power MOSFET and related conponents around it, look for shorted Diode in the secondary side or the load which more likely to cause this simple two-transistor switching power supply to fail.
Old 08-22-2013, 03:20 PM   #9
aaronwt6
My Country: US
I really should have changed that completely. I was trying to joke around. Bad idea.
Old 11-11-2016, 09:50 PM   #10
evelhorn
City & State: kentucky
My Country: usa
I was looking for a new main board for this model and was surprised at all the different board numbers, does anyone know why, and if they are interchangeable.
Strike that, I'm sure no one could make that assumption given the limited info
evelhorn is offline   Reply With Quote
Old 11-11-2016, 10:54 PM   #11
Packard93
City & State: DALLAS
My Country: United States
I found plenty of boards for this tv I was looking for tv in my area and this tv had a working screen for 25 bucks great find it has a slight solarizing but the there is something wrong with the color i adjusted it as much as I could . There is some solarization in some sceenes then others there is none at all. So Im not sure I ordered a main board for 10 bucks was ultra cheap from some parts store . I wanted to go cheap since I have a knack for fixing things I said wth im in . If i dont like it Im only out of 25 bucks plus this 7 dollar main. Not bad .
Packard93 is offline   Reply With Quote
Old 11-11-2016, 11:00 PM   #12
Packard93
tv only had software freeze cause it locked up when i first got it in dvd mode and only the power button worked . Then I got a suggestion remove dvd cables did that and the software glitch when I first got it is gone and it works flawlessly even the dvd player works awsome find for 25 bucks considering most used tvs in this range for 89 to 120 at pawn shops for 32 incher. I think the main for 7 bucks is well spent cause these boards should last long enough for me if I decide i want a different tv . But It beats watching the projection tv my girl wanted to watch I told her lcd and led put better picture quality . So im gonna fix this with main Im sure.
