Requesting caps selection help for Amiga 1200.
  • ShK
    Banned
    • Jul 2013
    • 4
    • no
    I do not understand enough about the properties of capacitors. That's why I am asking for your expert's help.
    An Amiga 1200 will be long periods unused. I am looking for the best possible capacitors that stays operational condition without active use and do not damage motherboard.
    Code:
    [B][U]#	Location	Original			Size          [/U][/B]
    1	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C214"][U]C214[/U][/URL]		10μF 35v (Audio) Bi-Polar	5mm
    2	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C235"][U]C235[/U][/URL]		100μF 6v			6.3mm
    3	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C236"][U]C236[/U][/URL]		100μF 6v			6.3mm
    4	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C237"][U]C237[/U][/URL]		470μF 16v Through Hole		7mm (Lead Spacing 5mm, Height 12.5mm)
    5	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C239"][U]C239[/U][/URL]		100μF 6v			6.3mm
    6	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C303"][U]C303[/U][/URL]		22μF 35v			6.3mm
    7	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C304"][U]C304[/U][/URL]		22μF 35v			6.3mm
    8	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C306"][U]C306[/U][/URL]		10μF 35v			5mm
    9	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C307"][U]C307[/U][/URL]		470μF 16v Through Hole		10mm (Lead Spacing 5mm, Height 12.5mm)
    10	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C324"][U]C324[/U][/URL]		22μF 35v non-polarised (Audio)	6.3mm
    11	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C334"][U]C334[/U][/URL]		22μF 35v non-polarised (Audio)	6.3mm
    12	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C407"][U]C407[/U][/URL]		10μF 35v 			5mm
    13	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C408"][U]C408[/U][/URL]		1000μF 10v Through Hole		10mm (Lead Spacing 5mm, Height 15mm)
    14	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C409"][U]C409[/U][/URL]		100μF 6v			6.3mm
    15	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C459"][U]C459[/U][/URL]		22μF 35v			6.3mm
    16	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C811"][U]C811[/U][/URL]		1000μF 10v Through Hole		10mm (Lead Spacing 5mm, Height 15mm)
    17	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C821"][U]C821[/U][/URL]		47μF 16v			6.3mm
    18	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C822"][U]C822[/U][/URL]		47μF 16v			6.3mm
    If you can help me, please use Digi-Key's part numbers (I have the group order possibility from there). Thank you very much for your help.
  • ShK
    Banned
    • Jul 2013
    • 4
    • no
    Re: Requesting caps selection help for Amiga 1200.
    What if I choose the Aluminum Capacitors? Should I change any of list's capacitors the better ones (using Digi-Key's In stock part numbers)? Or should I choose something else types of capacitors?
    Code:
    [B][U]Original			PCS	Digi-key	Size			Location      [/U][/B]
    10μF 35v (Audio) [URL="http://eab.abime.net/support-hardware/67240-a1200-cap-voltages.html"][U]non-polarised[/U][/URL]	1	[URL="http://www.digikey.fi/product-detail/en/ECE-V1VA100NP/PCE3135CT-ND/247925?cur=USD"][U]PCE3135CT-ND[/U][/URL]	5mm			[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C214"][U]C214[/U][/URL]
    1000μF 10v Through Hole		2	[URL="http://www.digikey.fi/product-detail/en/10ZLH1000MEFC10X12.5/1189-1072-ND/3134015?cur=USD"][U]1189-1072-ND[/U][/URL]	10mm (LS5mmH15mm)	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C408"][U]C408[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C811"][U]C811[/U][/URL]
    100μF 6v			4	[URL="http://www.digikey.fi/product-detail/en/UCW0J101MCL1GS/493-9407-1-ND/3962755?cur=USD"][U]493-9407-1-ND[/U][/URL]	6.3mm			[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C235"][U]C235[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C236"][U]C236[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C239"][U]C239[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C409"][U]C409[/U][/URL]
    10μF 35v			2	[URL="http://www.digikey.fi/product-detail/en/UCW1V100MCL1GS/493-9428-1-ND/3962776?cur=USD"][U]493-9428-1-ND[/U][/URL]	5mm			[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C306"][U]C306[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C407"][U]C407[/U][/URL]
    22μF 35v			3	[URL="http://www.digikey.fi/product-detail/en/UUL1V220MCL1GS/493-9533-1-ND/3962865?cur=USD"][U]493-9533-1-ND[/U][/URL]	6.3mm			[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C303"][U]C303[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C304"][U]C304[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C459"][U]C459[/U][/URL]
    22μF 35v non-polarised (Audio)	2	[URL="http://www.digikey.fi/product-detail/en/EEE-1CA220NP/PCE4306CT-ND/946241?cur=USD"][U]PCE4306CT-ND[/U][/URL] 	6.3mm ( 22μF 16V ? )	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C324"][U]C324[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C334"][U]C334[/U][/URL]
    470μF 16v Through Hole		2	[URL="http://www.digikey.fi/product-detail/en/UPB1C471MPD1TD/493-4935-1-ND/3129272?cur=USD"][U]493-4935-1-ND[/U][/URL]	10mm (LS5mm, H12.5mm)	[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C237"][U]C237[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C307"][U]C307[/U][/URL]
    47μF 16v			2	[URL="http://www.digikey.fi/product-detail/en/UCW1C470MCL1GS/493-9416-1-ND/3962764?cur=USD"][U]493-9416-1-ND[/U][/URL]	6.3mm			[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C821"][U]C821[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C822"][U]C822[/U][/URL]
    • ShK
      Banned
      • Jul 2013
      • 4
      • no
      I try fix the tables. I hope they are now easier to read.
      Code:
      [FONT="Courier New"][SIZE="1"][B][U]# Location Original            Size[/U][/B]
      [B][U]Original            PCS Digi-key   Size         Location[/U][/B]
      470μF 16v Through Hole     2  [URL="http://www.digikey.fi/product-detail/en/UPB1C471MPD1TD/493-4935-1-ND/3129272?cur=USD"][U]493-4935-1-ND[/U][/URL] 10mm (LS5mm, H12.5mm)[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C237"][U]C237[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C307"][U]C307[/U][/URL]
      47μF 16v            2  [URL="http://www.digikey.fi/product-detail/en/UCW1C470MCL1GS/493-9416-1-ND/3962764?cur=USD"][U]493-9416-1-ND[/U][/URL] 6.3mm        [URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C821"][U]C821[/U][/URL],[URL="http://www.amigawiki.de/dnl/schematics/A1200_R1.pdf?#search=C822"][U]C822[/U][/URL][/SIZE][/FONT]
      • Per Hansson
        Amiga 600 PCB corrosion from capacitors leaking electrolyte
        by Per Hansson
        Hi, fixing up an Amiga 600 for a co-worker.
        Caps C821 & C822 have leaked electrolyte causing the PCB to corrode.
        You can see how it looked after desoldering the caps in IMG_6993
        I have tried my best to clean it, the aftermath in the remaining pictures.
        After this I've also tried baking soda mixed with water to stop the chemical process.
        But I'm not sure if it's the best way, Googling gives very conflicting results.
        I'm thinking of using Vinegar (acetic acid) but just wanted to ask first if there are any recommendations either way?...
        08-20-2018, 11:34 AM
        LENOVO ThinkCentre M900 ThinkCentre M i7-6700T Specification for Upgrade or Repair
        This specification for the LENOVO ThinkCentre M900 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M900 boardview and ThinkCentre M900 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
        09-12-2024, 01:58 PM
        LENOVO ThinkCentre M700 ThinkCentre M i5-6400T Specification for Upgrade or Repair
        This specification for the LENOVO ThinkCentre M700 can be useful for upgrading or repairing a desktop PC that is not working. As a community we are working through our specifications to add valuable data like the ThinkCentre M700 boardview and ThinkCentre M700 schematic. Our users have donated over 1 million documents which are being added to the site. This page will be updated soon with additional information. Alternatively you can request additional help from our users directly on the relevant badcaps forum. Please note that we offer no warranties that any specification, datasheet, or download...
      • ruzhda
        Clean Bios dump for HP 260 G4 mini
        by ruzhda
        I am new in forum, working whit computers since Commodore 64 (own 2 defect units) And Amiga 1200,
        I taring to fix HP 260 G4 mini whit bios corrupted error , after reading and writing bios whit programmer pc is not powering on .
        I need clean dump to write new IC chip.
        07-21-2024, 08:10 AM
      • crosswinds
        Amiga 500 PSU
        by crosswinds
        Hello!
        So i am replacing all the caps in an old Amiga 500 PSU.
        Now, im not quite sure about the main 400v 47uF cap.
        The one my supplier had that was exact in the values, and closest in dimension is a Panasonic EEUEE2G470S
        Now, this one have very thin legs, and the original have quite "beefy" Please see this image:
        https://ibb.co/cfB9Pb
        Can i still use it, you think?...
        12-03-2017, 11:22 AM
