Old 07-05-2013, 06:57 PM   #1
65t350
City & State: Bay Area. CA
Default Samsung 50" Plasma PN50A450P1D vertical lines
Looking for help in solving this vertical line issue. TV was off for 4 days and first power up shows a group of vertical lines (Multiple colors) going up the right side of the panel.
From my quick reviews of the FAQ's and such it looks like it could be a simple repair but I am not sure. Before I take the TV down I would like to get a couple of possible solutions ready. I have access to DMM and other parts but am not that technical so any and all help is appreciated.
Thank you,
Rich
65t350 is offline   Reply With Quote
Old 07-06-2013, 01:31 AM   #2
Sevenqi
Default Re: Samsung 50" Plasma PN50A450P1D vertical lines
Most probably is not repairable.
Sevenqi is offline   Reply With Quote
Old 07-06-2013, 02:20 AM   #3
capkid
City & State: Federal Way,WA
My Country: United States
Line Voltage: 120VAC 60Hz
I'm a: Hobbyist Tech
It's either a panel issue (not at all uncommon for this Samsung model), poorly-seated connector on one of the address boards that run along the bottom of the panel in the vicinity of the defect, or a bad address board. It's hard to see the issue clearly in your pic because of the brightness, but I'd bank on a bad panel. My PN50A450 had vertical lines in a random pattern - bad panel.
capkid is offline   Reply With Quote
Old 07-06-2013, 02:49 PM   #4
65t350
Thank you for your feedback. Here is a closer picture of the vertical lines. You can still see an image through the lines and the color pattern repeats.
Does this help determine the potential problem?
Thanks,
Rich
Old 07-06-2013, 04:45 PM   #5
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
A repeating pattern is a little more lucky, it may be just loose connector. It is likely to be a bad plasma panel though.
Old 07-06-2013, 08:03 PM   #6
65t350
Got the plasma down off the wall and took the back off. Checked and reset all ribbon cables and problem is still there. I notice that the main logic board feeds both E.F buffers with a 60 pin ribbon. Would I learn anything if I drove the E buffer with the signal meant for the F buffer?
My fears is that the panel is gone but I don't have the knowledge to know when to "Pull the Plug".
Thanks again,
Rich
Old 08-31-2013, 06:02 PM   #7
sergio2013
City & State: Winnipeg/Manitoba
My Country: Canada
Did you figure out what the problem was? I have the same problem.
sergio2013 is offline   Reply With Quote
