Old 07-02-2013, 06:19 AM   #1
Wnowickiz
City & State: GA
My Country: United States
Default Samsung LED TV Model LN-S4041D intermittent loss of picture (sounds still works)
I read a lot about bad caps on these TVS, but could a intermittent loss of picture be caused by caps? I will turn it on and sometimes it works fine, shut it off and turn it on later with no picture. No other symptoms like cracking or popping.
Before, I tear into it and look for swelling caps, can caps fail like this?
Thanks in advance,
Bill
Wnowickiz is offline   Reply With Quote
Old 07-02-2013, 06:28 AM   #2
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: Samsung LED TV Model LN-S4041D intermittent loss of picture (sounds still works)
Capacitors would not be a typical suspect with this problem. In a dark room, when the picture is gone, can you see a glow from the screen or not? (Backlight)
tom66 is online now   Reply With Quote
Old 07-02-2013, 08:15 AM   #3
Wnowickiz
City & State: GA
I will check thanks. I am pretty sure it does not have a glow, but what would be if there isn't one?
Thanks again.
Old 07-02-2013, 08:26 AM   #4
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
T-con or main board w/ glowing screen.
Inverter, power or main board w/o glowing screen.
Old 07-02-2013, 09:44 AM   #5
Wnowickiz
City & State: GA
I made need a scope to check those things...
Old 07-02-2013, 12:04 PM   #6
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
You usually won't for most LCD TVs, but it can help to have one.
Old 07-02-2013, 08:05 PM   #7
Wnowickiz
City & State: GA
The tv is working great tonight. Go figure.
Old 07-04-2013, 08:44 AM   #8
Wnowickiz
City & State: GA
I tried the TV this morning and the screen is blank, no backlight and sound is working. Now what?
Old 07-04-2013, 09:43 AM   #9
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Take the cover off, and provide clear pictures of each of the boards in the TV.
Old 07-04-2013, 09:03 PM   #10
Wnowickiz
City & State: GA
Ok, will do.
Old 07-07-2013, 01:40 PM   #11
Wnowickiz
City & State: GA
Here you go. I do not see bulging caps anywhere.
Old 07-07-2013, 01:43 PM   #12
Wnowickiz
City & State: GA
Second pic.
Old 07-07-2013, 02:24 PM   #13
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
replace all secondary caps and resolder everything attached to a heatsink on that power supply.
that is not an led set either.
i see these often.
kc8adu is offline   Reply With Quote
Old 07-07-2013, 07:01 PM   #14
Wnowickiz
City & State: GA
Ok, thanks. All the can style caps or the others also? Should take any readings prior?
Old 07-12-2013, 02:24 PM   #15
Wnowickiz
City & State: GA
I tested all the diodes and transistors in circuit. DB851 and db803 appear bad (both directions). Could those be the cause? I am looking for a schematic for the BN44-00134D. Thanks again.
Old 07-12-2013, 02:35 PM   #16
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Intermittent would be unlikely to be caused by a permanent failure.
Schematic of PSU if it's any help:
http://www.toms-service-manuals.com/...df&mfg=Samsung
Old 07-13-2013, 12:14 PM   #17
Wnowickiz
City & State: GA
You were correct tom66. The replacement diode did not fix anything. Should I test the voltages prior to changing out. All the caps? Thanks again.
Old 07-14-2013, 12:24 AM   #18
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
I'm a: Student Tech
Yes, check all the voltages on the output side, in particular check the backlight on/off signal CN1803 pin 1.
Old 07-14-2013, 05:16 AM   #19
Wnowickiz
City & State: GA
Thanks.
