Abit BP6 recapping & stability tips [UPDATED]
  • Topcat
    The Boss Stooge
    • Oct 2003
    • 16955
    Ok, Ive had several emails and even a posting or two in the forums about the Abit BP6 motherboard... Along with the VP6, I've had a lot of experience with the BP6. As we all know, the BP6 was plagued with the crap cap problem as well... However, this board has room for a couple variations in changing out the caps. I usually try to sway people away from changing capacitance values, however, through MUCH testing and experimenting with this board, some mods were worth doing.
    I'm sure that all the BP6 users are familliar with bp6.com, and they've given me quite a few usefil tips, but their site is a MESS to dig through looking for info. The tips here are very simple and to the point if you want a stable BP6 again.
    It doesn't really matter which revision you have, as the mods will cover both revisions.
    Here's a list of the problem caps and what to replace them with.
    The following capacitors stock are 1500uF 6.3v caps. Replace them with 2200uF 6.3v or 10v capacitors. Use only LOW ESR caps!! This is VERY important!
    EC15, EC5, EC1, EC11, EC4, EC6, EC9, EC7, EC8, EC2, EC13, EC14.
    Ok, EC10 needs to be replaced with a 1500uF 10v capacitor.
    These caps need to be left at their stock values of 1000uF 10v caps.
    EC3, EC17, EC25, EC21, EC20, EC24, EC18, EC19, EC22, EC23, EC28, EC31.
    It is also recommended that some thermal grease be applied to the northbridge heatsink... You know that old BX chipset and how hot it can get!!
    I'm not going to go into any Coppermine modding, simply because it's risky business! I have successfully completed it on a few BP6's, but I also hosed a couple boards in the curve....
    The cap replacements above were found to be the BEST for reliability running stock, overclocked, and even Coppermine mods. If you plan on recapping your BP6 and have any questions, let me know!
    Good Luck!
    <--- Badcaps.net Founder
    Badcaps.net Services:
    Motherboard Repair Services
    http://folding.stanford.edu/
    Team : 49813
    Join in!!
    Team Stats
  • ncdave
    • Oct 2003
    • 33
    Where does one find low-ESR 2200uF or larger caps in an 8mm can?
    • Topcat
      The Boss Stooge
      • Oct 2003
      • 16955
      Ohhh.... Umm... Dave, you're gonna love this one...
      I've only found TWO places that I can get 8mm caps from, and one of them is Jackcon... While they don't traditionally sell to the consumer, they can be sweet talked... The second is Digikey (www.digikey.com)... The only problem with them is cost!! Their 8mm low ESR caps are almost a buck a piece!! OUCH!
      Honestly, on the BP6, I've always used 10mm caps. They will fit properly with a little ingenuity, and look stock, not like Mickey Mouse recapped the board.
      Team : 49813
      Join in!!
      Team Stats
      • kc8adu
        • Nov 2003
        • 8832
        • U.S.A!
        i prefer the panasonics that digikey has.
        more expensive but i hate having a repair job come back like a boomerang.i am still seeing bad jackcon caps in boards with 2002 dates.
        not seen a repeat failure yet.
        i will post the digikey part numbers when i get to the shop in the morning.(if roadrunner is back up)
        • Topcat
          The Boss Stooge
          • Oct 2003
          • 16955
          OHHHH WERE THOSE THE DAYS!!!!
          I sold my last BP6 about 5 months ago, running 2x Celery 366's @ 550/100, 2.2v core, OCZ heatsinks... I actually miss that system...
          I have a parts BP6 still here, as a matter of fact, ncdave of our forum got the VRM toroid coils out of it...
          Overclocking just hasn't been the same since the BP6!!
          Team : 49813
          Join in!!
          Team Stats
          • Topcat
            The Boss Stooge
            • Oct 2003
            • 16955
            BP6 recapping using 10mm caps
            Ok, as mentioned above, the hunt for 8mm replacement caps is a difficult persuit... They're nearly impossible to acquire from a reputable manufacturer. I have added a couple pictures of a BP6 I recapped using all 10mm Nichicon and Sanyo capacitors. Doing this takes a little more finesse to make it look pretty like the example below, but it is really easy!!
            The only issue with using 10mm caps on this board is the spacing around the CPU sockets. This is an issue with the original 8mm caps also. This was a blunder on Abit's part, placing the caps in such close proximity to the sockets. This inhibits the use of monsterous coolers. Although, this was an issue before with the original caps, the 10mm caps just make things a little tighter. However, all retail Intel Celeron coolers fit with no problems, and so do the nice ThermalTake copper Golden Orb heatsinks.
            If you have any questions, feel free to post them!
            Team : 49813
            Join in!!
            Team Stats
            • kc8adu
              • Nov 2003
              • 8832
              • U.S.A!
              do you still have the carcass?
              why was it scrapped?
              i may need one to pick parts from
              i finally got one thats is more than caps.
              all voltages normal,clock running but no post no beeps.
              • Topcat
                The Boss Stooge
                • Oct 2003
                • 16955
                Yes, I still have a BP6 carcass... It's plundered pretty bad though... I PM'd ya.
                Team : 49813
                Join in!!
                Team Stats
                • DynaxSC
                  Need real mobo dump of BIOS v402 for ASUS PRIME Z590-A - stock image no help
                  by DynaxSC
                  I have a serious problem to program the Z590 chipset SRAM with a Management Engine after replacing the chipset.
                  The new chipset is factory new and is not containing any Management Engine. Any attempts to program it into the chipset under Windows ends with a failure (eg. Error 20: Management Engine Device not present, or something similar).
                  Due to the lack of the ME several ports on the board, including all M.2 ports aren't working, booting OS works only on USB. So it's now other way, as to program the chipset with a ME.
                  Usually on ASUS boards it worked...
                  06-14-2024, 03:49 PM
                • estabilito
                  Tips geting oxidized when using wick
                  by estabilito
                  Hi, i have weird problem - when i'm using soldering wick to clean BGA balls under CPU or PCH on motherboard my tips(different types) getting oxidized very fast and lost all power.
                  i Was trying different types of wick, flux - no difference. I can't even clean one full socket and i need to use deoxidizer in half-time.
                  Temperature: 350-365celsius
                  station: jbc cd-2bqe
                  Wick: edsyn
                  flux: warton hf rework jelly
                  Do you have any tips?...
                  04-12-2025, 11:55 AM
                • Foetuss
                  Recap motherboards :: Abit KG7-LITE and Soltek SL-75FRN2-L
                  by Foetuss
                  Hi all
                  Hope this is in the correct place.
                  I'm planning on recapping both motherboards. I actually already ordered recplament caps for them, where I will be changing out most for poly's.
                  Could use some double checking to see if I'm not doing something stupid .
                  Pictures of the boards are attached.
                  What I will be replacing with what : (planned)
                  Soltek Golden ::
                  4 1500µF 16V 10mm (5mmL) KZG => APSG160ELL152MJ16S (Chemi-Con 1500µF 16V)
                  6 3300µF 6.3V 10mm (5mmL) KZG => APSG160ELL272MJ20S (Chemi-Con 2700µF 16V)...
                  01-18-2025, 11:44 AM
                • Maxim Bojko
                   Palit RTX 2080 Super Jetstream Mats/Mods help
                  by Maxim Bojko
                  I have a RTX 2080 that is broken, but interesting thing is that the card works how it should work, but when playing the card crashes, black screen fans go to 100% and nothing happens anymore. I changed thermal paste because I thought it was overheating, but no. So I checked with gpu z and here is what I had.
                  After a while a dude I got friends with told me to underclock the gpu via msi afterburner. First to underclock the core speed by 200 then open the chart for the mhz and voltage and said that I should change the mhz at 0,9v to 1900mhz. Since then I doesn't crash...
                  09-18-2024, 04:18 PM
                • benwaterson
                  Gigabyte Aorus 1080ti - card not initialising
                  by benwaterson
                  Hi there.
                  Have searched various forums but haven't come across the exact issue I am having.
                  Bought the 1080ti with a fault (randomly shutting down, black screen , fans full speed etc). Previous owner had replaced thermal pads but many were too thick on inspection.
                  I tested the card in windows, all loaded up ok. Put some load on the card and it crashed. GPU was reporting 92 degrees C at the time.
                  Switched the stock cooler out for an AIO water cooler from my 1080 FE, booted the card back up - temps were much better and allowed some load to be applied...
                  02-05-2022, 11:42 AM
