Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > General Electronics Technical Discussion
Old 05-17-2013, 02:34 AM   #1
sergio2013
City & State: Winnipeg/Manitoba
My Country: Canada
Default PLEASE HELP, how to repair burnt pad on board
I accidently used to much heat and burnt a pad on the board I don't know how to go about fixing it I heard that you have to scrape away the coating on the trace and if the capacitor legs reach you can solder it, but I scraped at the trace and no copper appears, only beside the trace some copper appears when I scrape, maybe that's not a trace im not sure. I included and circled in the picture the problem, a capacitor supposed to go there. please help
sergio2013 is offline   Reply With Quote
Old 05-17-2013, 02:56 AM   #2
rievax_60
City & State: mackay
My Country: australia
Line Voltage: 240
I'm a: Hobbyist Tech
Default Re: PLEASE HELP, how to repair burnt pad on board
To me it looks like the + pad goes nowhere. Whats on the other side of the PCB?
rievax_60 is offline   Reply With Quote
Old 05-17-2013, 02:59 AM   #3
Sparkey55
Won't be back.
City & State: OK
I do not see very much copper trace showing on the + side of the hole. Maybe the trace continues on the other side of the board and if so try to make shure that some solder flows to the other side of the board. The negative terminal looks ok for now.
Sparkey55 is offline   Reply With Quote
Old 05-17-2013, 03:00 AM   #4
sergio2013
My Country: Canada
Originally Posted by rievax_60 View Post
To me is looks like the + pad goes nowhere. Whats on the other side of the PCB?
I just included a picture of the top side
Old 05-17-2013, 03:15 AM   #5
rievax_60
Line Voltage: 240
You could try spacing the new capacitor some distance above the PCB so you can solder both pads on top of the PCB. Be sure that both pads are tinned well first. The - pad on the bottom still needs to be soldered.
Old 05-17-2013, 03:18 AM   #6
sergio2013
My Country: Canada
Ok, just the negative pad on the backside has to be soldered correct? cause the positive pad on the backside the solder wont stick.
Old 05-17-2013, 03:38 AM   #7
tw2005
tw2005's Avatar
City & State: QLD
My Country: Australia
Line Voltage: 240VAC
I'm a: Forum Junkie
I did not realise I was wasting my time. Looks like you've got plenty of help here in this forum.
tw2005 is offline   Reply With Quote
Old 05-17-2013, 03:41 AM   #8
sergio2013
My Country: Canada
Yeah my bad, I posted 2 times, your not wasting your time though, I asked you another question on the other thread. I wont double post again.
