Old 04-03-2013, 12:24 PM   #1
ztu165
City & State: Chicago, Illinois
Wink Sylvania lc320sl1
I believe the tv has two transistors (k2417) that are bad. I would just like you guys to let me know if I'm correct in this. I have checked both transistors in ohms and diode mode, and from the drain to source I get around 2.437 ohms and when I come back to source after touching the gate there is absolutely no change. It does the same in diode mode and I believe after touching the gate and going back to the source it's supposed to go down significantly. What do you guys think?
ztu165 is offline   Reply With Quote
Old 04-03-2013, 12:28 PM   #2
johnboy1313
City & State: Midwest
Default Re: Sylvania lc320sl1
I can't add anything about the transistors. What is the issue with the tv?
johnboy1313 is offline   Reply With Quote
Old 04-03-2013, 01:46 PM   #3
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Did you test them out off the board?
Old 04-03-2013, 02:15 PM   #4
ztu165
Yes I tested them out of the board. These transistors are from the backlight inverter. The TV does not turn on at all. I ordered the power supply and it still did not turn on at all so I decided to check all the transistors on the backlight inverter and those two give me the readings I mentioned.
Old 04-03-2013, 03:59 PM   #5
budm
budm's Avatar
Can we see the picture of the boards?
Not sure if this service manual has all the ifo:
http://elektrotanya.com/?q=showresul...oria=&kat2=all
