Picked this TV up, The Tv will not turn on .It has a blue led light on in the right hand corner that comes on when you plug it in. If you hit the power button again the light gets brighter for a second when the tV shuts off. All the voltage is right on the power board 5v and 12v. On the main board the powers are right for 12v and 5v but the 3.3v is not right. It is measuring 5.27v
coby LED 2326 will not turn on
Re: coby LED 2326 will not turn on
Where is that 3.3V test point? Is it under that long board attached to the power supply board?
I see the connector on the left side of the board where it has 3.3v label on it, so it must be 3.3V regulator or buck regulator on the main board.Last edited by budm; 03-27-2013, 10:37 PM.Never stop learning
Can you trace that back to the connection on the power supply board since I can only the the connector labeled with 5V and 12v OUTPUTS. There must be a regulator some where that drops the 5V down to 3.3V.
I see at least two 3-leg regulators on the main board.Last edited by budm; 03-27-2013, 10:38 PM.Never stop learning
Originally posted by budm View PostCan you trace that back to the connection on the power supply board since I can only the the connector labeled with 5V and 12v OUTPUTS. There must be a regulator some where that drops the 5V down to 3.3V.
Coby!! I thought they made trouser presses!!
U21 is an adjustable VR - can you test it -you have had lots of practice with those.
Also what is the value of the little attached resistors.
EDIT sorry that is CorbyPlease upload pictures using attachment function when ask for help on the repair
Budm did say trace it on the power supply (not sure if that is what he meant) but you have posted pics of the main board.
Can you do a close up of the other VR and on the power supply a pic from the side
showing all the legend for the connector and another shot of the back of the power supply
as the bit needed to trace back from the pin is flashed out.
ALSO what is the black blodge by the other connector on the main board has something died there - can you clean it off with isopropyl alcohol. There is also another streak in the last 3 opics can you clean that off as well in case it has gone conductive.
None conductive stuff and dust heat up and if they get to the point where they oxidize or start to burn it can turn to carbon which is conductive.Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostCoby!! I thought they made trouser presses!!
Power on, I think one of those regulator is for the 3.3V.Never stop learning
Originally posted by selldoor View PostBudm did say trace it on the power supply (not sure if that is what he meant) but you have posted pics of the main board.
Ok - U20 is the 3.3 volt VR but what part numbers are the two on the back U3 and U4
Also in pic4 just above R29 there is a black spot between two traces - is it just debris?
can you remove it and check the traces are not bridged.Please upload pictures using attachment function when ask for help on the repair
Originally posted by selldoor View PostOk - U20 is the 3.3 volt VR but what part numbers are the two on the back U3 and U4
U3 3251 R64 11051
U4 ME 15N10
R29 was nothing just something on the board
U4 is a mosfet
https://cdn.badcaps-static.com/pdfs/...33c86bdf36.pdf
There is something before 3251 ? on U3 two letters?Please upload pictures using attachment function when ask for help on the repair
U21 Tab-1.2v, pin 1-3.3v, center pin- 3.308v, pin 2- 000.1v
U20 tab -3.206v, pin1-2.02v, center pin-3.201v, pin 2-5.14v
Ok so still 5v on that pin marked 3.3? Can you trace back from that pin to either of these
VRsPlease upload pictures using attachment function when ask for help on the repair
All too often I have encountered errors on labels -- engineers in a rush to finish by 5pm?
(That happened today and I realised I forgot something important but luckily I can easily sort it out Tuesday...)Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
Good news is, neither can we. This board will use at least 4 layers meaning two hidden between the top and bottom. More likely it will be 6 layers making it even harder.Please do not PM me with questions! Questions via PM will not be answered. Post on the forums instead!
