DELL XPS L502X Core I7 Master Bios Password
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Hi
    got a dell xps l502x locked . trying reset bios master password using hardware method ( 1-use a clean no-password dump of another dell xps BIOS
    2-erase the locked eeprom chip and copy that clean one dump in , using programmer EZP 2010)
    but at startup, the laptop still ask for master password.
    trying dismantle the laptop and found two
    eeprom chip . one of 512Kbyte and another of 4Mbyte
    question
    If someone have already experienced this kind of problem , which of the two eeprom hold that password. ???????????????
  • dycc
    Vision
    • Nov 2011
    • 625
    • Côte d'Ivoire
    Re: DELL XPS L502X Core I7 Master Bios Password
    • spidey
      climbs
      • Dec 2012
      • 644
      • Cyprus
      re-program that 4mb chip. 512 k chip is just for ec to power up.
      • Francisco.s
        • 686
        • Spain
        Could be that none of them store the password, many motherboards has an I2C memory chip that stores serial number, password, etc.
        In this case the schematic is the only help.
        Regards.
        • spidey
          climbs
          • Dec 2012
          • 644
          • Cyprus
          Regards.
          i fix 30-40 laptops in a week. And i didnt see anything like that. Clould you please show me an example ?
          • Francisco.s
            • 686
            • Spain
            Hi spidey, the following screen capture, is from a mbx-223 motherboard, and as you can see it has a memory with the I2C bus. I don´t know if password in this model are stored in this chip, but some other models from Sony, I´m sure it is.
            Also some models from Acer, like de aao have a memory with the I2C bus, and they stores serial number, uuid, etc.
            Regards.
            • dycc
              Vision
              • Nov 2011
              • 625
              • Côte d'Ivoire
              still looking for 4mb dump
              • Kpax7
                • Jun 2013
                • 16
                • Iran
                Hello
                I'm also badly looking for a way to break bios password for this model.
                Maybe I can help. Tell me the exact way to dump that 4Mb one.
                if any softwares needed for that give me the link please.
                tnx
                Edit>> I found this:
                How do you manually Unlock and reset the password from your Dell Laptop?
                To remove Dell Bios password manually: If you are Computer technicians with
                superior knowledge, open the laptop, and find the Chip 24C02 on the motherboard,
                and Short circuit the legs 3 and 6 during booting, See picture attached, This
                same chip is located in different position in different dell laptop motherboards, Using
                a bent paperclip at an angle short circuit pins 3 and 6. when the 24c02 bios chip
                is not found you may also look for chip 24c04 and 24c05 Short circuit during
                booting . only leg 3 and 6 should be used as shown on picture on right ->
                resetting dell bios password manually
                When Short circuiting legs 3 and 6 fails, you may want to try short circuit legs 4
                and 5, additionally try jumping legs 3 an 7, but do know this, if you use this
                information you are doing it at your own risk, it is dangerous, and you may burn
                the motherboard, and we are not reponsable for anything,
                we recommend buying our master password to unlock your dell laptop
                With the laptop turned off, position the bent paper clip on the Bios chip proper
                legs, and than turn on the laptop, this will cause a short circuit in the Bios chip
                and reset the password.
                • dycc
                  Vision
                  • Nov 2011
                  • 625
                  • Côte d'Ivoire
                  that is for old brand
                  • spidey
                    climbs
                    • Dec 2012
                    • 644
                    • Cyprus
                    What is your mobo code ?
                    • dycc
                      Vision
                      • Nov 2011
                      • 625
                      • Côte d'Ivoire
                      hi spidey this the diagram
                      • spidey
                        climbs
                        • Dec 2012
                        • 644
                        • Cyprus
                        http://forum.notebookreview.com/dell...ages-more.html
                        choose suitable dump for your laptop.
                        • Kpax7
                          • Jun 2013
                          • 16
                          • Iran
                          @spidey : That's not the full dump.
                          @dycc: Is it the right way to dump the chip?:
                          http://www.sodnpoo.com/posts.xml/ard..._4mb_flash.xml
                          • spidey
                            climbs
                            • Dec 2012
                            • 644
                            • Cyprus
                            if you read te page carefully you will also find non modded dump. Btw what do you mean with full dump ? is it half ?
                            • Kpax7
                              • Jun 2013
                              • 16
                              • Iran
                              That won't help resetting the password, I flashed the bios with that to no avail.
                              • dycc
                                Vision
                                • Nov 2011
                                • 625
                                • Côte d'Ivoire
                                i use this to dump chip
                                http://www.ebay.com/itm/EZP2010-High...-/221072211816
                                • Kpax7
                                  • Jun 2013
                                  • 16
                                  • Iran
                                  DYCC: Any updates?
                                  • dycc
                                    Vision
                                    • Nov 2011
                                    • 625
                                    • Côte d'Ivoire
                                    flash bios with 4Mbytes dump but the laptop still ask for master bios password. i wonder if 512kbytes EC bios hold that password .
                                    • Kpax7
                                      • Jun 2013
                                      • 16
                                      • Iran
                                      The security is really high in this model :-/
                                      I gotta ask someone tomorrow ...
                                      • dycc
                                        Vision
                                        • Nov 2011
                                        • 625
                                        • Côte d'Ivoire
                                        please someone here could give me the dump . will really appreciate
                                        • zenius
                                          by zenius
                                          12-08-2024, 06:13 AM
                                        • mikeybass
                                          Dell 9010 MT BIOS Update Always Fails
                                          by mikeybass
                                          Hi, I hope some one has some advice for me. I searched the forums but didn't see anything relevant. I acquired two identical Dell 9010 Mid Tower computers from a business office upgrade (they were going to throw them out). Both of them have the same motherboard (00F82W). One of them works flawlessly. The other one had a corrupted BIOS. I tried flashing numerous main BIOS and EC files from the internet, but none of them worked. I decided to copy the main BIOS and EC from the working 9010 computer and successfully flashed the corrupted BIOS. This got the computer able to boot again and run norm...
                                          04-23-2025, 04:30 PM
                                        • capoplays
                                          Help with BIOS update on Dell G15 5515 after chip replacement
                                          by capoplays
                                          Hey everyone,
                                          I recently bought a Dell G15 5515 with an AMD Ryzen 7 5800H and 3060 RTX. The BIOS chip on it was dead, and my hardware guy replaced the chip. After that, everything was working fine.
                                          The BIOS is currently at version 1.22.1, and I wanted to update it. I downloaded the latest BIOS version from Dell Support using my ST: FQZMYJ3, but when I tried to run it, it says "unsupported system." I asked my tech guy what he did, and he said he took the chip from another board and flashed it onto mine.
                                          When I check the BIOS using the F12 menu Flash...
                                          10-24-2025, 06:53 AM
                                        • traxformania
                                          TONGFANG "GM7TG7P" Bios Password Problem?
                                          by traxformania
                                          I'm using TONGFANG "GM7TG7P" model laptop for over 3 years and i'm entering the same bios administrator password everyday. My laptop has Aptio BIOS (American Megatrends, AMI).
                                          But today it's not accepting my password. I'm %100 sure i'm entering the correct password.
                                          I'm trying to reset my bios without success.
                                          I tried :
                                          -I removed the BIOS battery and main battery. Waited for a long time but it didn't work. They already stated in the user manual that the password will not be reset even if the batteries...
                                          11-15-2023, 07:32 AM
                                        • tlindi
                                          Toughbook CF-18KHH65LE (Customer Special Configuration) Supervisor Password needed remove HDD locking and BIOS Access ...
                                          by tlindi
                                          Sublect line continuation: ... Jaguar IDS PC aka Panasonic
                                          >Read BIOS guides, methods, resources and tools
                                          Ack
                                          >Try the method at BIOS guides, methods, resources and tools before requesting help
                                          Ack
                                          >Explain you were not able to succeed with the methods at BIOS guides, methods, resources and tools
                                          python ./main.py "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.BIN" --output-dir "/mnt/c/temp/205605f9e1b60403a41787efeffe9cad-flas_maybe5.txt"
                                          01-30-2025, 04:26 AM
