Hi everyone,
Would like to say g'day from Australia. What an amazing forum to stumble across, there is a wealth of knowledge in here, so I'm hoping to take some away with me
My problem as stated in the thread topic is my Philips LCD TV will no longer power up.
I'll put as much info in here as possible to aid in your diagnosis.
A few months ago I noticed if the TV was turned off (not on standby), and I made an attempt to turn it on from the side panel on/ off switch, it would take a couple attempts to finally turn on. The front panel white light would flash a few times and then shut off, it would continue to happen as I pressed the on/ off switch, finally turning on after approx 3- 4 attempts.
However, if we were to turn the TV off with the remote ( to standby mode), the TV would have no issues turning on at all when prompted by the remote control.
In short, if turned off from the side panel or the mains power outlet, the TV would struggle to power up. If turned off via the remote, it would power up fine.
As of Thursday night my 2 yr old turned the TV off at the wall, and now it does not power on at all, no matter how many attempts are made. You hear a small click/ buzz, then the white flashing light does its thing for a few flashes, then shuts down, each and every time.
I have carefully looked at the capacitors on both boards and none seem to be puffed or leaking... Other than those I've no idea what else to look at.
I am an Electrical Linesman by trade, and repair/ modify electric guitars and RC cars in my spare time. So I'm keen to learn and not afraid to have a look. And I am confident with a soldering iron etc.
Thanks for your time everyone...
