ASUS P5P800 with bad caps
  • NWArcher
    • Aug 2006
    • 3
    My board will be RMA'd for the second time very soon. The first time it went back it had about 8 swelled caps. Sorry I can't remember the brand. I received a recapped replacement board, but they did not recap the entire board, just the bad caps. I now have a board with Rubycons (the replacement caps) with a mix of Ltec (currently bad and swelling), and Ost and GSC caps (not swelling, but suspect). This is the first ASUS board I've ever had issues with. I'm considering not sending it back to them and recapping it myself. I don't solder very much though and I'm concerned I just may kill the board trying.
    In the past few days, I've read a lot on these forums and learned a lot from many of you. Thanks! Any advice would be appreciated though...
  • gonzo0815
    • Feb 2006
    • 1600
    Re: ASUS P5P800 with bad caps
    Until you don`t have a proper soldering iron (betwen 60 and 80w, depending onthe quality) and at least the basic soldering skill, i don`t advise an recap. If there is warranty, i would not bother to send it away, as long as it isn`t to expensive (shiping etc). This is very bad service from Asus, selling bad caps and then refuse to fix it right. Seems to me, that there are some people incharge by ASUS, wich want to ruine the brand for some fast bucks.
    • UraBahn
      Scrapheap Hound
      • Nov 2004
      • 165
      Maybe Topcat can help you if you're in the US?
      If you're feeling brave though, try putting on some Rubycon MBZ or MCZ. Other good Japan-icons to try are Chemicon KZE (I wouldn't trust the KZG too much though recently), Panasonic FC and FM. Some have amazing results with Samxon GC, mainly in the overclocking department. (Only one Samxon fail that I can remember, and that was most likely due to excessive heat. But high heat can kill even Rubycons with disgusting ease.)
      Total bummer for me though to hear that Asus is using GSC of all caps. And all this after I got through recommending ASUS to friends and family.
      The ever-amazing (and ever-affordable) KY, Chemi-con's best kept secret.
      I'll probably be the only person going to SteamOS once it gets out of beta (ha ha.)
      • RJARRRPCGP
        • Jul 2004
        • 6304
        I can't recall seeing any GSCs on Asus motherboards.
        ASRock B550 PG Velocita
        Ryzen 9 "Vermeer" 5900X
        Arc A770 16 GB
        eVGA Supernova G3 750W
        Alienware AW3423DWF OLED
        • c_hegge
          • Sep 2009
          • 5219
          I've seen a few small GSCs on ASUS motherboards
          • PCBONEZ
            Grumpy Old Fart
            • Aug 2005
            • 10661
            https://www.badcaps.net/forum/showpo...9&postcount=21
            Asus has never had a problem with using GSC/Sacon/Evercon, they just prefer OST.
            GSC went *poof* around 2003-2004[ish] and reappeared as Evercon and Sacon.
            Evercon and Sacon [at least their site] went *poof* in late 2008/early 2009.
            The owner of GSC/Sacon/Evercon isn't a manufacturing icon. [He owns distribution type businesses. That's what he does.]
            Manufacturing of GSC/Sacon/Evercon caps was appearently outsourced to Capsun.
            Capsun is a HUGE manufacturer of caps but you never hear about them because their primary business is building caps for other companies.
            http://www.szcapsun.com/en/Products_pt.asp?id=1
            I suspect some OST and some G-Luxon are also outsourced to Capsun.
            [Which means at least some of the OST Asus uses might as well say GSC.]
            I suspect that because I've seen a collection of boards with mixed Capsun, OST, GSC, Evercon, and G-Luxon caps in which all the caps [regardless of branding] had the same abnormality in the vent.
            In that mix of manufacturing names Capsun is the only one that doesn't outsource, meaning they are the likely source.
            Mann-Made Global Warming.
            - Dr Seuss
            • brethin
              • Dec 2008
              • 1907
              2 year old thread bump, but yes the caps should be fine on that P5P800. They used OST and Chemicon KZE on alot of P4C800 boards without issues as long as the heat wasn't a factor.
              • trodas
                • Jan 2006
                • 770
                • Czech republic
                So I do wonder, is the Asus P5P800 using OST caps near the CPU (Vcore regulator)?
                Or they are Chemi-con KZE or something else?
                Since judging from this thread: https://www.badcaps.net/forum/showthread.php?t=6944
                It looks like they used Elite caps.
                Now is not Elite making polymers these days?!
                Asus P5P800, user Lithotech, HardwareCanucks forum
                "It is dangerous to be right in matters on which the established authorities are wrong." - Voltaire
                "I believe that all the people who stand to profit by a war and who help provoke it should be shot on the first day it starts..." - Hemingway my config - my caps
                • Tynan Dill
                  by Tynan Dill
                  Assuming...
                  11-22-2024, 01:46 PM
                • m1ch43lzm
                  by m1ch43lzm
                  05-12-2025, 08:37 PM
                • Dani_2024
                  by Dani_2024
                  10-28-2024, 05:06 PM
                • black6host
                  Replacement caps for Samson Resolv studio monitor 65A Amp board.
                  by black6host
                  Good day!
                  I have a Samson Resolv studio monitor that has no sound output. I've opened it up and found two caps that are bulging on what I believe to be the power supply section of the amplifier board. The board is marked Resolv 65A AMP V1.2. The caps in question are YUSCON, 2200uF, 35V, 85C temp and have markings of RA(P) and are 16mm x 25.5mm tall. I've attached the schematic and the caps in question are C5 and C6. I'm assuming they are low esr caps. I've tested both caps and they test low uF, nowhere near 2200uF.
                  I'm going to replace the caps and I'll be the first...
                  02-06-2024, 08:22 PM
                • Noodneek
                  Replacing all the caps on the BenQ SW2700pt's power board didn't help...
                  by Noodneek
                  My 3.5 years old monitor (BenQ SW2700pt) started to black out for 1-2 sec every minute or so, it was doing this even with PC disconnected from it. I searched online and read that it's probably aging capacitors and there's a workaround to lower the brightness.
                  I lowered it from 100 to 65% and it indeed helped, but after a couple of months the issue returned... I continued to lower the brightness, but it helped only for a couple of hours at most, then I needed to lower it further... Turning the monitor off and waiting for it to cool down also helped for a short time, after which it...
                  08-30-2024, 12:52 PM
