Old 09-23-2012, 11:13 AM   #1
lilmonk3
City & State: Kansas
Default SANYO DP37647 Sound no Picture
It powers on just fine with sound, no pic or back lights.
Power board readings:
Cn2 goes to main
PS_on 4.9 v
5vsb 5.0 5.0 v
12v 12.0 12.1 v
24v 24.1 24.1 v
CN4 goes to inverter
24.0v
24.1v
24.1v
24.0v
MAINBOARD from Power board
K8B
white 4.9v
12.0v
12.0v
24.1v
24.0v
K6R goes to inverter
white 3.3v
3.3v
0.3v
4.3v
File Type: pdf sanyo_dp32647_chassis_p32647-03m_sm.pdf (5.82 MB, 58 views)
lilmonk3 is offline   Reply With Quote
Old 09-23-2012, 11:15 AM   #2
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: SANYO DP37647 Sound no Picture
No backlight or no image on lit screen?
Check inverter fuse.
Old 09-23-2012, 11:34 AM   #3
lilmonk3
Fuse and transformers all in spec .. I should have said I already tried a replacement inverter..
Old 09-23-2012, 11:35 AM   #4
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Inverter VIN measures 4.3V? That is too low but you do have 24V on your power board. Check if there are fuses on the power board - maybe one there.
Old 09-23-2012, 11:38 AM   #5
lilmonk3
Yes I have 24v on power board .. The 4.3 is coming from the main to the inverter
Old 09-23-2012, 11:40 AM   #6
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Can you post a clear shot of the inverter? It doesn't look like the 24V is getting to the inverter - I'm suspecting a fuse on the PSU somewhere (and fuses can be deceptive, looking like anything...) This TV probably uses the 24V for the audio circuit as well, many do.
Old 09-23-2012, 11:52 AM   #7
lilmonk3
I was just looking over the Power board and found this.. Would this ferrite bead cause a problem
Old 09-23-2012, 11:57 AM   #8
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
I don't think so - it's just a bit of ferrous material wrapper around a wire. It's to reduce the interference the TV can kick out with regards to radios etc.
Old 09-23-2012, 12:10 PM   #9
lilmonk3
Its a long inverter.. Here are a few pics
Old 09-23-2012, 12:17 PM   #10
lilmonk3
One thing that made me scratch my head is... On the power board there is a cable 24v connection CN5 that is empty and there is also and empty connection on the inverter.. Is there SUPPOSE to be a cable going between the 2....
Old 09-23-2012, 12:19 PM   #11
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
OK, test the voltage as indicated in the image. Red probe on the red highlighted pin, black on the black highlighted pin.
You can test the voltage on any of the main caps on the inverter.
Old 09-23-2012, 12:20 PM   #12
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Hmm I wonder. Perhaps the owner tried to fix their TV?
Old 09-23-2012, 12:29 PM   #13
lilmonk3
Thats what I am wondering... The set didnt SEEM to have been opened but ya never know
Old 09-23-2012, 12:41 PM   #14
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Do the check I mentioned - if it's zero volts or near enough zero, you can always solder individual wires between the PSU and inverter or crimp your own cable.
Old 09-23-2012, 12:45 PM   #15
lilmonk3
24v on all caps on inverter
Old 09-23-2012, 12:49 PM   #16
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
So I think it's OK. That plug on the PSU is probably for a slave inverter, and on the other inverter is probably for a different PSU, or for use as a slave inverter in some way. Check all the transformers on the inverter next as you have Darfon ones and they often fail.
Old 09-23-2012, 01:16 PM   #17
lilmonk3
Transformer all are good.. One of the first things I checked
Old 09-23-2012, 01:22 PM   #18
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Check the primaries of the transformers too. I've never seen one fail, but wouldn't rule it out. You are expecting close to 0 ohms.
Old 09-23-2012, 01:23 PM   #19
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Oh, and did you check this fuse too?
Old 09-23-2012, 01:29 PM   #20
lilmonk3
Secondary all 0.3, primary 2.15 ,all white fuses 1.0
