Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Old 09-15-2012, 12:39 AM   #1
pctek
City & State: athens
My Country: Greece
Default HP pavilion dv7
It powers on , fan spins but after a few seconds restarts and caps/num lock flash 1 time with 3 seconds interval . Could it be cpu as hp says or vga/southbridge ? Anyone has experience with this model and error ?
pctek is offline   Reply With Quote
Old 09-15-2012, 04:33 PM   #2
fddizon
City & State: Forbidden
My Country: Philippines
Line Voltage: 220v 60Hz
Default Re: HP pavilion dv7
try replacing cpu
fddizon is offline   Reply With Quote
Old 09-16-2012, 11:39 AM   #3
thesloc
Banned
City & State: Seattle
GPU is out. Reflow GPU and SouthBridge to be sure.
Could also signify bad ram port.
thesloc is offline   Reply With Quote
Old 09-16-2012, 11:50 AM   #4
lucco85
City & State: Rijeka
My Country: Hrvatska
I have most of them repaired
Each platform has its own fault.
Your platform is?
CPU?
Gpu?
lucco85 is offline   Reply With Quote
Old 09-17-2012, 08:31 AM   #5
pctek
My Country: Greece
exact model is 1030ev . I don't have any spare cpu to test so I will try reflowing gpu and see what happens .
Old 09-18-2012, 12:03 PM   #6
lucco85
Likely GPU (G96-630)
Try to see if you have on the external monitor picture
Old 09-18-2012, 10:10 PM   #7
pctek
My Country: Greece
Reflowed but the same happens. Starts up , fan spins for a second and then caps/num flashes one time every 3-4 seconds.
Old 09-19-2012, 12:52 AM   #8
pctek
My Country: Greece
I found a similar proccessor and tried it but the same error. I'll try reflowing northbridge and then I'll give up .
Old 09-25-2012, 07:37 AM   #9
VaNDAL_UK
City & State: Birmingham
My Country: United Kingdom
Line Voltage: 240V
Have you tryed the "Blind" Bios recovery proceedure?
I'm guessing a corrupt bios.
VaNDAL_UK is offline   Reply With Quote
Old 09-28-2012, 05:26 AM   #10
pctek
My Country: Greece
Unfortunately I don't have it any more to try . Thanks for the suggestion
Old 10-01-2012, 08:59 PM   #11
gabik111
ORD spotter
City & State: Chicago O'Hare
My Country: USA / Poland
Line Voltage: 120VAC 60Hz & 240VAC 50Hz
I think best way to make it work is replace GPU or reball it with leaded balls. But if you reflew it and it still does not work rather I can say GPU needs to be replaced . Soldering pads separeted from GPU like it happened in this faulty series and reflow does not work.
After you replace it remeber to reflow GPU RAM chips because you can get artifacts.
Laptops and computers repair.
gabik111 is offline   Reply With Quote
Old 10-01-2012, 10:46 PM   #12
fddizon
if 3 seconds interval, try replacing memory
http://h10025.www1.hp.com/ewfrf/wc/d...t=3860630#N215
its what hp says
Old 08-15-2014, 01:52 PM   #13
it.vendor
City & State: sialkot
My Country: pakistan
did anybody have bios of hp pavilion dv7-6858sf ...beats audio.
M.Ajmal Sohail
IT Vendor SKT
0333-8676 343
it.vendor is offline   Reply With Quote
Old 08-16-2014, 11:44 AM   #14
Ramee
City & State: Israel
My Country: Israel
Did you melt the balls from under? Light reflow won't work, reflow it, but melt the balls. If you know how to reball, it would be better, but do not use heat gun, use the proper machine.
Ramee is offline   Reply With Quote
