Old 08-13-2012, 12:45 AM   #1
zombslayer
City & State: OHIO
Default magnavox 37mf337b/37 parts advice
Hi! I am a new member and love the site! Thanks for all of the information, very helpful!!
I have a MAGNAVOX Model:37mf337b/37 that currently has the squeak/squeal going on. The Stock CapXon Caps are currently present in the t.v. @ a rating of 1000uf 35v.The three caps will need replacing due to bulging, also I tested the Diodes and found that two need replaced:
ZD902 (KE12 74) tested at .017 and .017, D912 (RD) tested at .001 and .001 while installed to PSU.
What brand of caps should be used?
What are the correct diodes that I will need?
Part #'s, Brands, any advice would be helpful.
I can be more specific if necessary, Thanks again!!
zombslayer is offline   Reply With Quote
Old 08-13-2012, 12:48 AM   #2
tom66
Wants a Tesla
tom66's Avatar
City & State: Leeds
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: magnavox 37mf337b/37 parts advice
These are suggested:-
http://www.digikey.com/product-detai...445-ND/2433579
+ shipping about 3 bucks
Panasonic FR - low ESR, high ripple current, very long lifespan.
Just check the diameter (12.5mm x 20mm) will fit.
The diodes - I believe UF4007 is tossed around here - http://www.digikey.com/product-detai...ICT-ND/3340246
Old 08-13-2012, 12:52 AM   #3
zombslayer
City & State: OHIO
Thank You! for such a quick response! I will be sure to check diameter.
Old 08-13-2012, 07:38 AM   #4
truep
City & State: Flower mound, TX
Line Voltage: 120VAC 60 HZ
Isn't ZD mean zener diode?
truep is offline   Reply With Quote
Old 08-13-2012, 11:30 AM   #5
zombslayer
City & State: OHIO
Hello! Yes, from what i understand ZD is zener diode. So does anyone know which ZD I will need? I will be ordering the parts described as above, but would like to make sure that I have a regular diode and a zener diode.
Thanks again!!
Old 08-13-2012, 11:38 AM   #6
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
Thanks again!!
I dont understand what you are asking - you have the board there what are the part numbers of the parts you want- is the part number you originally quoted not the number off ZD902 " ZD902 (KE12 74)" Is that not correct?
Test them again off the board.
selldoor is offline   Reply With Quote
Old 08-13-2012, 11:48 AM   #7
zombslayer
City & State: OHIO
I will retest out of board and report my results. I am needing a KE12 74 , which is ZD902. I was just making sure I do not replace a ZD w/a regular diode.. I am not sure if uf4007 would be good for both faulty diodes.
Thanks for the quick responses, this site is amazing!!
Old 08-13-2012, 11:54 AM   #8
selldoor
Slow Learner
selldoor's Avatar
You can always check by looking at the data sheets for the part numbers.
Even if you dont fully understand them ( I dont) you can usually get enough
info for basic comparison. Just google the part number and download the data sheet ( Pdf file)
Old 08-13-2012, 12:02 PM   #9
zombslayer
City & State: OHIO
I will do that! When I do find the info. I will be sure to pass it on. I will keep this thread open and update my progress. I am pretty good with electronics, this is my first tv and is a good learning experience.
Old 08-13-2012, 12:20 PM   #10
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Is there a chassis number on the model number sticker?
Pleas remove that zener diode, it should have number with PKEXXXX on it, it is Zener Diode for the snubber circuits, will be in 200V range.
Old 08-13-2012, 12:36 PM   #11
zombslayer
City & State: OHIO
PSU # is 715T2484-4, there is a barcode also on PSU with ADPF24220R1P/P5PB74752533 as I am not sure what those numbers stand for. The back of the tv its self has model# and serial #.
Old 08-13-2012, 12:39 PM   #12
budm
budm's Avatar
Most PHILIPS/MANAVOX TV's have chassi number printed on the model number sticker to tell the service technician which chassis being used inside the TV since same model can have more than one version of the chassis. Any number on that PKE ZENER Diode?
Old 08-13-2012, 12:45 PM   #13
selldoor
Slow Learner
selldoor's Avatar
"Any number on that PKE ZENER Diode?"
Thought he has already said twice it is a KE1274
Old 08-13-2012, 12:49 PM   #14
budm
budm's Avatar
From the picture, I can see KE2XXX. I do not see KE12XX. I expect it to be P6KE2XXX. I expect it to be 200v Zener.
His circuit may be similar to this one. I need to find the chassis number to look up the service manual.
http://www.mouser.com/ProductDetail/...k9x0jN%252bFfF
Old 08-13-2012, 01:10 PM   #15
zombslayer
City & State: OHIO
ZD902 is p6ke120a/744, now that i do see it. I am guessing i should replace with a P6ke120a? Thanks.
Diode tester reveals .019 and .019 out of PSU.
Old 08-13-2012, 01:38 PM   #16
budm
budm's Avatar
Digikey:
http://www.digikey.com/product-detai...ACT-ND/2770358
That is pretty low voltage rating for Snubber.
The other Diode D912 more likely to be UF4007, but take it out of the circuit to check and get the number off the body.
Old 08-13-2012, 01:50 PM   #17
zombslayer
City & State: OHIO
I will definitely take D912 out,confirm the body numbers and diode test . I really appreciate all the input, I could not have done it without BADCAPS!! Thanks for the schematics as well VERY HANDY thing to have.
Old 08-13-2012, 01:52 PM   #18
budm
budm's Avatar
The diagram I post is not the exact as your power supply, but it shows how the Diodes are used.
Old 08-13-2012, 02:01 PM   #19
zombslayer
City & State: OHIO
I will search for the chassis number, I am interested in that now. The diagram is great in showing how the diodes are used, very interesting stuff.
Old 08-13-2012, 02:38 PM   #20
killian6pk
killian6pk's Avatar
City & State: Kentucky
Line Voltage: 120VAC 60HZ
Make sure you are keeping a written record where all these parts of coming from on the board. You sometimes get so many you forget from time to time. I also like to take a picture of the board before I start taking parts off of it.
Have you ever stopped to think and then forget to start thinking again?
As a very wise man once said on this forum: "Of all the things I have lost I miss my mind the most."
killian6pk is offline   Reply With Quote
