Hi all, I'm an EE so talk exotic, no problems there.
I've got a motherboard out of a Toshiba C655 which is designated MN10R-6050A2423501-MB-A02, that in itself is one of the problems, seems everyone has the G45 / MAS10M type schems but no one has the NM10R type.
Now, to the actual fault...
If I put a charged battery into the system it shows a battery light and I can boot fine, but it does not seem to take charge from the power brick / powerbrick-IN.
Once the battery runs out, everything shuts down, even if the powerbrick was active.
My "theory", the ACIN sense is dud or something connected to that, the trouble is, all the parts on this board are DFN, MLF or QFP size and as such the numbering on the parts are essentially useless and it'd be great to get a schem / board-part-map to track back.
I've already put the whole board through one reflow process to no avail, so it wouldn't seem that we're dealing with an obvious joint issue, at least not initially.
In summary... anyone got a schem for this board?
Thanks in advance.
Thanks in advance.
