Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Computer Displays
Old 07-10-2012, 08:43 AM   #1
hairykiore
City & State: Invercargill.Southland
My Country: New Zealand
Line Voltage: 230v 50 hz
Default Cleaning PCB? my bad Solder Technique
Hi.Again I hope I am in the right forum... I removed two SMD Mosfets on my power board and I am not happy and would welcome any tip on how I clean it up prior to my soldering new mosfets on....I have attached two photos ..one of a new board and one of my board ... you will see the difference... Can anybody advise me please on the technique I should apply to clean up the area where the Mosfets came off ..Thanks Hk
hairykiore is offline   Reply With Quote
Old 07-10-2012, 08:46 AM   #2
mariushm
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Default Re: Cleaning PCB? my bad Solder Technique
Liquid flux , solder wick, isopropyl alcohol...
Apply liquid flux on the solder wick, put the wick over the solder, heat it up and let it absorb the solder.
Clean the pad and surroundings with alcohol as the black stuff is burnt flux as far as I can tell.
Apply a new layer of solder over the pad before applying the new mosfets
mariushm is offline   Reply With Quote
Old 07-10-2012, 12:50 PM   #3
hairykiore
Many thanks ....I wonder what heat on the tron I should have ...Hk
Old 07-15-2012, 01:48 PM   #4
killian6pk
killian6pk's Avatar
City & State: Kentucky
Line Voltage: 120VAC 60HZ
Depends on if your using Lead Free or regular 60/40 (or other) type solder. The lead free stuff melts at a higher temperature. Check the package the solder came in for a melting point.
Have you ever stopped to think and then forget to start thinking again?
killian6pk is offline   Reply With Quote
