#1 |
City & State: Ontario
My Country: Canada
Hi there,
This forum is an excellent place to start exploring and learning … After reading and more reading I decided to go ahead and ask for your help: So I tried to troubleshoot a (like-new) 24 inch LED-LCD Insignia tv with power problems: plug-in, the standby indicator was blinking red and stay red and sometimes goes off when try to power on. Open the cabinet and inspected the power supply board and capacitors for bulging or leaking, nothing suspicious, measured voltage as follow: BON=0V, PWM=0V, STB=5V, 5V-1=0V, PON=0V, 7V=0V, 12V=12.4V so the output voltage looks ok. Did reset it (unplug for more than 10min, press and hold power button from tv for 1 min and plug-in again) and surprising the tv power up and ask for initial set-up. But after few minutes, no standby indicator light, completely dead unit…try to reset, same results. Open again, plug-in and re-measured the voltages: BON=0V, PWM=0V, STB=5V, 5V-1=5V, PON=5V, 7V=0V, 12V= 12.4V so looks like something is on, but no standby indicator red/blue, no image or sound. Checked for jammed side buttons - nothing wrong. Disconnected the mainboard from the power supply and measured again I got same voltage reading like first time: STB=5V, 12V= 12.4V (other outputs 0V). At this point I am lost and your help will be appreciated. Thanks! |
#2 | |
City & State: Canada
http://www.badcaps.net/forum/showpos...94&postcount=1 2) Try pointing a fan to the back of the TV to see if the TV stays on longer. If it does, you could have a bad solder joint or some component is dying after too much heat.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#3 |
My Country: Canada
Hi retired,
Please find the attached photos. At this point I am not able to power on the TV, so no standby light, just the voltage mention earlier (with and without main board connected)! |
#4 |
Hookup everything.
The main board controls whether the TV comes or not. It usually needs steady and stable 5V DC voltage in order to work. One or more of the voltage regulators on the main board can be bad? To test a voltage regulator (circled in red), 1) Set your multimeter (if manual range) to 20V DC. 2) Put your black probe on a ground screw (circled in black). Leave it there the entire time. This is your ground. 3) Put your red probe on each of the pins including the "cut" pin, but ignore the "fat" tab. The fat tab is "up" or "north". Number the pins left to right. 4) You should have 3 readings per regulator. 5) Report them like so along with the part number of the IC. U100 AS1117-33 pin 1 = 0.0 pin 2 = 3.3 pin 3 = 5.0 edit: Manage attachments failing for some reason in both Opera and Chrome browsers, but the ones I can read are N602, N60, and N607. Last edited by retiredcaps; 07-03-2012 at 10:25 PM.. |
#5 |
My Country: Canada
I just add the photo with regulators location and those are the voltage reading:
N603, AZ1117D Pin 1= 0 Pin 2= 3.3 Pin 3= 5 N607, 1117 Pin 1= 1.3 Pin 2= 2.5 Pin 3= 5 N602, 1117 Pin 1= 2 Pin 2= 3.3 Pin 3= 5 N606, 1117 Pin 1= 0.6 Pin 2= 1.8 Pin 3= 3.3 N608, 1117 Pin 1= 3.8 Pin 2= 5 Pin 3= 8.8 N604 -MP1482-buck regulator for main IC pin 3 output 1.8V N605 -MP1482-buck regulator pin 3 output 5V |
#6 | ||
Do you have an analog multimeter? There isn't much resolution in your readings? That is, 5 = 5.00 or 5.04 or 5.0001? Quote:
#7 |
My Country: Canada
N603, AZ1117D-3.3
Pin 1= 0.01 Pin 2= 3.30 Pin 3= 5.07 N607, 1117 Pin 1= 1.30 Pin 2= 2.52 Pin 3= 5.07 N602, 1117 Pin 1= 2.04 Pin 2= 3.30 Pin 3= 5.07 N606, 1117 Pin 1= 0.60 Pin 2= 1.80 Pin 3= 3.30 N608, 1117 Pin 1= 3.82 Pin 2= 5.06 Pin 3= 8.80 N604 and N605 has pin 2 voltage (input) 12.47V . I agree with you , all voltages look fine. Also I measured the input voltage for eeprom chip (MX25L3206L) is 3.28V !! could be a sign of corrupted firmware ?? |
#8 |
Trace the PON pin on the main board. The main board should be responsible for toggling this pin high (i.e 5V) so the rest of the secondary voltages on the power board can start.
#9 |
My Country: Canada
I just want to confirm, my friend has the exact same model (rev. A, nov. 2011) and experienced same symptoms pattern as mine:
-phase 1- the TV will turn off randomly, -phase 2- restart by itself after 10-20 sec of normal function (same as LG, Samsung models) -phase 3- could not be turn on, the standby led is flashing (indicates a malfunction on power supply / main board) or stay solid red (goes off when try to power on) and finally no power at all! Definitely, some component gradually is getting worse (maybe bad solder joint?) |
#10 |
| Thread Tools | |
| Display Modes | |
