Old 06-25-2012, 03:27 PM   #1
eqtitan
City & State: Southgate, MI
My Country: United States
Line Voltage: 120V 60Hz
Default Need help with a Emerson 32" TV LC320EM2F
Ok, so I traded a laptop (only paid $50 for, worth $300) for an Emerson 32" LCD TV the guy powered it on via an inverter in his car which I thought was a bad idea. None the less it powered up after the power light blinked RED. Took it home all excited plugged it in to a cable line (COAX) and plugged in the power turned on the TV and heard buzzing coming from the back left it on for a minute when it started to smoke. Took the back cover off and found the issue, it was a capacitor with a bulging top got so hot it melted the shrink material that was wrapped around it.
Model: LC320EM2F
The capacitor is labeled as (HEC) 390uf 200wv neg20 85 C but i am unable to find this exact capacitor online or Ebay. I'd like a good quality capacitor replacement.
It's about as around as a 50cent piece and about 1in in height. I can get pictures later tonight when I get home if needed.
eqtitan is offline   Reply With Quote
Old 06-25-2012, 03:30 PM   #2
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Default Re: Need help with a Emerson 32" TV LC320EM2F
Just checking you definitely used 115V AC (did he?) Very rare for a primary capacitor like that to go bad unless something else is bad on the power board.
Old 06-25-2012, 03:34 PM   #3
eqtitan
Everything else checked out good on the board visually. Not sure what type or output he used when he used the inverter it was plugged into a power out in has escalade.
Old 06-25-2012, 03:47 PM   #4
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
Did you see an actual picture on the set in his car or just the screen lit up white.
selldoor is offline   Reply With Quote
Old 06-25-2012, 03:48 PM   #5
eqtitan
The start up screen that was searching for a signal (Search for Digital Signal) was displayed in lower right corner.
Old 06-25-2012, 03:50 PM   #6
selldoor
Slow Learner
selldoor's Avatar
You will need to post pictures as follows.
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
http://www.badcaps.net/forum/attachm...1&d=1290283049
http://www.badcaps.net/forum/attachm...7&d=1280167246
It will be useful if you can say what the supposed fault was and a bit about yourself - skills tools etc.
Old 06-25-2012, 03:52 PM   #7
eqtitan
Pictures added to OP
"Whatever you are, be a good one" - Abraham Lincoln
Old 06-25-2012, 04:42 PM   #8
eqtitan
Old 06-26-2012, 04:46 AM   #9
selldoor
Slow Learner
selldoor's Avatar
Pictures are not clear enough for troubleshooting. need them to be square on
and in focus and one of the bottom of the board.
It there any evidence that the leads to the cap could have touched something under the board.
One of these should do you id get a 105 deg one.
http://www.digikey.sg/scripts/dksear...f+200v&stock=1
We have had similar boards recently where it has been thought that a diode may have blown if you can check them for shorts.
What is the part number of the board- looks like they may be available at a reasonable price.
Can we assume there is no way the guy could have switched sets on you?
as Tom says Big Cap blowing is not something we often see aprt from one
pc monitor that keeps cropping up.
Old 06-26-2012, 10:37 AM   #10
eqtitan
No leads did not touch anything under board the frame it attached to was plastic and non conductive. I looked up the part number for the board and checked Ebay the cheapest replacement board was $81 shipped.
None of these look the correct size of the one they are replacing....is digi-key located in the USA?
Old 06-26-2012, 10:51 AM   #11
selldoor
Slow Learner
selldoor's Avatar
Hi - its international - dont know how I got the singapore page just type in digikey.com into your browser and search for 390uf 200v then narrow it down by size. Can you tell US the board number and redo the pics.
Old 02-28-2013, 03:17 PM   #12
Mario R Morales
City & State: san antonio,texas
My Country: usa
Need parts list 4 d610 (1zb36) orignal part# 4 lc320em2f emerson and d1208 (1m200z) orignal part# 4 emerson lc401em24
Mario R Morales is offline   Reply With Quote
Old 03-08-2013, 01:38 PM   #13
Terryfictv
City & State: Vista,Ca
Line Voltage: 120VAC 60HZ
Hi !
I am working on the same model...this is my list =
Blown fuse
Shorted Q600 = TK10A50D
Shorted D610 = 1ZB36 ( 36V 1 watt zener )
Shorted D640 = SK2B ( SMD on bottom of board )
Open R608 = .19 ohm
Update ASAP
T.
Terryfictv is offline   Reply With Quote
Old 04-26-2013, 06:19 PM   #14
mu2
I also need some information. Working on the same model and my power supply board is BA17F1F0102 3 and the number on the sticker is A17FDMPW.
I've already replaced about 5 parts - mosfet, zeners, resistor, etc.
I now have two burned resistors and can't identify the values.
The reference numbers are R635 and R636. They are located on the bottom right side of the board, above the fuse and to the right of the optocoupler.
Would really appreciate the values. I can't make out the color codes from the pictures that have been posted.
Does anyone have a link to the schematic of the power supply?
Thanks in advance
mu2 is offline   Reply With Quote
Old 04-28-2013, 02:30 PM   #15
carjo3000
City & State: San Antonio
Thanks in advance
Hello, I just started to work on the same board. I've tried replacing the fuse but it keeps blowing out so now I'm checking all the components that have been listed on this thread.
The values for R635 and R636 are 120ohm 5%.
You mentioned replacing 5 parts so far, can you please list the reference numbers? Has replacing them solved the problem?
thanks
carjo3000 is offline   Reply With Quote
Old 04-29-2013, 06:52 AM   #16
mu2
The tv isn't working yet, haven't had much time lately.
The parts that I have replaced are:
R608, D604, D645, D648, Q600 and D640 on the bottom of the board.
Also replaced the two 120 ohm resistors I mentioned before - but that fault wasn't related to the original problem.
Right now the transformer is squealing when the set is connected to power. I haven't left it on long enough for fear of more damage.
Check out this thread. I think this set uses the same power board.
http://www.badcaps.net/forum/showthr...light=lc320ss2
The writer lists some digikey part numbers.
Mike
Old 04-29-2013, 08:29 AM   #17
kc8adu
kc8adu's Avatar
City & State: dayton ohio
My Country: U.S.A!
Line Voltage: 12vdc,120/240vac,480vac 3ph on my bench
change the opto and the 2 zeners after the rectifiers on the secondary side.the opto dies with the chopper and caused an overshoot.
kc8adu is offline   Reply With Quote
Old 04-29-2013, 12:42 PM   #18
microvibe
City & State: steinbach,mb
My Country: canada
i have this same tv and problem with power supply , replaced parts and tested others i still dont have power , there is no clicks or nothing when pluged in. i have power at the zenner d604 not sure where it stop after that trying to follow the circuits still
microvibe is offline   Reply With Quote
Old 08-28-2013, 10:08 AM   #19
buymytvpleez
City & State: ny
My Country: usa
D611 is the part that needs replacement. Problem is, I can;t find ANYWHERE to purchase it.
go to youtube and type in the Emerson LC320EM2F repair. There is a repair video (in spanish) that shows you the part that you need. Can anyone help me find the D611 part for purchase?
Johnny
buymytvpleez is offline   Reply With Quote
Old 11-06-2013, 04:36 PM   #20
Dmaltz
City & State: Grants Pass Oregon
The schematic I have only has a part number for D611 which is 12B220-YBB. I'm guessing it's a 220 volt zener based on the numbers it has.
Dmaltz is offline   Reply With Quote
