Old 06-20-2012, 03:48 AM   #1
junger
Default Lg 37lc55
Hi All
I have had a couple of the same model giving the same sympton on
LG 37LC55.
When switched on you get no picture, If the LCD is left on for say 15minutes and then the mains cable is unplugged and reinserted then it works perfectly well. I have looked at the caps on the power board and they are not bubbled/dry.
Any ideas, anything I can try?
Junger
junger is offline   Reply With Quote
Old 06-20-2012, 10:40 AM   #2
budm
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Default Re: Lg 37lc55
Bad cap can look normal but it can have high ESR. What you can do is this, heat up the power supply board with hair dryer, then pug in the TV and see if it will come on. ESR will go down when cap is heated up. It sure sounds like bad caps to me.
Never stop learning or per Greek Pro "when you will update your ID from Knowledge Seeker to a Pro (in 10 years) ,
then I will take you more seriously, for now you are just a kid playing with it keyboard"
Baisc LCD TV and Monitor troubleshooting guides.
budm is online now   Reply With Quote
Old 06-20-2012, 11:11 AM   #3
tom66
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
The LG 37LC46, 37LC55, 42LC46 and 42LC55 are prone to four bad caps on the PSU going bad. More Samwha WBs.
** Begin Signature **
I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system!
Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me.
I have successfully fixed (from best --> worst build quality):
3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs
[Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.]
Old 06-23-2012, 09:21 AM   #4
junger
hi
which caps are they, so that I can inspect them closer, Thanks for the hairdryer tip, I will try that
Old 06-23-2012, 03:22 PM   #5
psmedley
City & State: Greenwith, SA
My Country: Australia
Line Voltage: 240VAC 50Hz
http://www.ohmsupplies.co.uk/LG-37LC...301-REPAIR-KIT
LG 37LC55 REPAIR KIT
BOARD MARKED EAY34796801, EAX32268301
FAULT SYMPTOMS:
STAND BY
FLASHING LED
DEAD
WHATS IN THE KIT:
C217
C218
C226
C210
C221
C206
C222
C208
psmedley is offline   Reply With Quote
Old 06-26-2012, 07:11 AM   #6
junger
hi all
The fault has developed further,now I can see in the back, when switched on the hv lights up, after about 10 mins the hv lights strobe/flash and then goes back to normal.
I have replaced the PSU board from my mates LG (same model) and it was the same, so I changed the main board and the fault travelled with the board. so the fault is on the main processing board, any ideas?
Old 06-26-2012, 10:02 AM   #7
selldoor
Slow Learner
City & State: Lancashire UK
Pictures top and bottom of your main board might help.
Did you try the hairdryer trick on the main board.
Please can you update your profile with country and mains voltage.
I will attach instructions for pictures.
Welcome to the forum-
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
http://www.badcaps.net/forum/attachm...1&d=1290283049
http://www.badcaps.net/forum/attachm...7&d=1280167246
It will be useful if you can say a bit about yourself - skills tools etc.
selldoor is offline   Reply With Quote
