#1 |
City & State: Los Angeles
My Country: United States
Hi all--
Newbie here, have searched all day, but cannot figure out if these caps are bad or not. The are not bulging as far as I can tell, but some have these dark purplish marks, that look like they COULD be leaking, but also look like somebody could just have taken a marker and marked them. This is from a Mintek DTV-260 LCD Color TV. Many thanks for all your expert opinions. Best R |
#2 |
City & State: Romania
Line Voltage: 230VAC 50Hz
I'm a: Hobbyist Tech
Can't tell from the angle... the camera flash makes it hard to determine how swollen they are.
Pictures made from slightly above the board and from the connectors side would be useful... to see the top of the capacitors. First impression is that the black ones right between those connectors with lots of wires are bad... same with the blue capacitor at the right end. Check the tops, they should be flat ... check the bottoms as well, if it looks like they're coming out the capacitors may be going bad. In the end, they could be bad even without showing signs. All capacitors are very close to that large heatsink which is going to be obviously hot while the tv runs. Heat eventually kills capacitors. |
#3 |
City & State: Canada
1) I going to say they all look flat to me with no obvious bulges.
2) What is the problem with the TV?
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#4 |
Unknown
My Country: Australia
Line Voltage: 240V 50Hz
It looks like ink to me, but as retiredcaps said, that doesn't necessarily mean they aren't bad.
I love putting bad caps and flat batteries in fire and watching them explode!! Main PC: Core i5 660 3.33GHz, Gigabyte GA-P55-UD3R, 4GB Kingston DDR3 1333, 750GB WD HDD, Sony Optiarc DVD RW, nVidia GTX295 1760MB, Antec 1200 Case, Delta DPS-750CB 750W PSU, Hauppauge TV Tuner, Windows XP Pro. Main Laptop: Lenovo Thinkpad T60: Core 2 T2500 2GHz, 2GB DDR2, 80GB HDD, DVD RW, Intel Graphics, Windows XP Pro. 2nd Laptop: Toshiba Satellite A200: Core Duo 1.73GHz, 2GB DDR2, 60GB HDD, DVD RW, nVidia GF Go 7300 Graphics, OpenSUSE 12.2, Fan Mod |
#5 |
404 Not Found
City & State: Fairfax, California
Line Voltage: 120VAC 60Hz
I'm a: Forum Junkie
They look fine to me.
#6 |
Warranty Voider
City & State: West Tennessee, USA
Ink markings.
However, I would yank off the caps on the right hand side of the board and check their ESR... they look a tiny bit bulged. Could be a sign that the ESR is slowly creeping up and the cap are just starting to go bad. Last edited by Evil Lurker; 06-11-2012 at 11:39 PM.. |
#7 |
Thanks to all for your responses. There is no evident bulging, as the accompanying photos suggest... so maybe it's not the capacitors.
Problem I'm trying to fix: Mintek LCD TV, connected to PC. Turns on and after several minutes, there is a loud POP, and the screen goes black, from outer edges towards center. Turning TV off then back on fixes situation, but only briefly then it pops back off again. Happens with both VGA and DVI connections, different cables, etc. Thought that sounded like bad capacitors so I took a look, but consensus seems to be they aren't the culprits. Any other ideas are welcome, and ... THANK YOU ALL! |
#8 |
1) It would help if you posted clear focused top down pictures of all your boards in the following picture composition
http://www.badcaps.net/forum/showpos...94&postcount=1 2) Do you own a multimeter and know how to use it to measure DC voltage? |
#9 |
Thanks for your reply
Here is the best I could do, sadly I only have an iphone camera. I do have a multimeter (recently purchased) and I suspect I could figure out how to read DC Again, all your help is appreciated! |
#10 |
1) On the left hand side of your picture are 3 white connectors. This is the "cold" side.
2) Each connector has legend. 3) Put your multimeter on DC voltage. 4) Put your black probe on the ground screw near the connector and leave it there for all readings. 5) Put your red probe on each pin of the connectors. Record all readings. 6) Report your readings like so CN100 pin 1 says 5V - I get 4.99V pin 2 says 12V - 11.88V 7) Record the readings BEFORE the TV pops and AFTER so we can compare. |
#11 |
GO BOLTS!
City & State: Temecula CA
Line Voltage: 110V 60Hz
I have recently come across a bad cap that showed no obvious signs of being bad, no visible leakage or bulging, I flipped the board over and found that it has leaked through the bottom, through the solder joint. It was really hard to tell, I had to use magnification and a slow roll across the board to find it. Just my two cents.
#12 | |
OK first of all a zillion apologies for only being able to get back to this now... it turned in to a busy summer. So I was able to do what you said
And here's what I got with the TV plugged in, turned on, and the white internal connectors plugged in. C204 GND: 0 BKON (?): 3.6 BKADJ: 1.7v GND: 0 GND: 0 GND: 0 GND: 0 GND: 0 +24V: 24v +24V: 24v +24V: 24v +24V: 24v +24V: 24v C205: +24: 24 +24V: 24 GND:0 GND:0 -5V: -5.5 GND:0 C206: BKAJD: 1.7 BKON: 3.6 STB (or ST8): 4.6 GND: 0 GND: 0 GND: 0 +5V: 5.9 +5V: 5.9 +5V: 5.9 +12V: 14.4 +12V: 14.4 Now for someone to interpret these results for me! Thanks again! Quote:
#13 | |
IGNORE ABOVE POST I COULDN'T EDIT IT-- BELOW IS ACCURATE
OK first of all a zillion apologies for only being able to get back to this now... it turned in to a busy summer. So I was able to do what you said And here's what I got with the TV plugged in, turned on, and the white internal connectors plugged in, both BEFORE the pop, and then a few minutes later, AFTER the pop. C204 GND: 0 BKON (?): 3.6 BKADJ: 1.7v GND: 0 GND: 0 GND: 0 GND: 0 GND: 0 +24V: 24v +24V: 24v +24V: 24v +24V: 24v +24V: 24v C205: +24: 24 +24V: 24 GND:0 GND:0 -5V: -5.5 GND:0 C206: BKAJD: 1.7 BKON: 3.6 STB (or ST8): 4.6 GND: 0 GND: 0 GND: 0 +5V: 5.9 +5V: 5.9 +5V: 5.9 GND: 0 GND: 0 +12V: 14.7 +12V: 14.7 Now for someone to interpret these results for me! Thanks again! Quote:
#14 |
So I asked for readings before and after. I only see one set of readings in the above post. Are you saying that the readings are identical before and after?
#15 |
Yes readings are the same. A little more detail on the problem: the "pop" comes from the speakers. The screen goes blank, but the green light stays on, which leads me to think that in fact the TV is still on, just the screen (backlight?) is going out? Don't know if this helps. Thanks for sticking with me.
#16 | |
2) What type of multimeter do you have? Post a picture of it. 3) Where does this connector go to? |
#17 |
Thanks for your reply... I have a Radio Shack Cat.No.: 22-172
The third connector goes to the largest board (the one where the VGA DVI inputs are), at a plug labeled P20 |
| Thread Tools | |
| Display Modes | |
