Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops, Portable, and Mobile Devices
Old 06-09-2012, 08:48 PM   #1
thesloc
Banned
City & State: Seattle
Default Toshiba Satellite L355D...STILL NO VIDEO!!!
Toshiba Laptop L355D. Switched board TWICE, and still NO VIDEO. I'm guessing I got sent a defective one two times.
Everything boots up, lights come up, but nothing on display. NOTHING. Nothing shows up while connected to the VGA port on an external monitor either.
I'm guessing:
-Bad GPU (on both boards)
-Bad VGA connector (not physically on board, but a cable that runs to it)
Bad inverter/lcd???
Gonna send it back again, I guess..
thesloc is offline   Reply With Quote
Old 06-10-2012, 09:42 PM   #2
thesloc
Banned
Default Re: Toshiba Satellite L355D...STILL NO VIDEO!!!
Anyone???
Old 06-11-2012, 02:25 AM   #3
pctek
City & State: athens
My Country: Greece
Can you hear a windows intro sound ? Hdd activity led ? If yes it means it passes the boot procedure and there is another problem (lcd connector ,cable etc ) . If not , the motherboard is faulty
pctek is offline   Reply With Quote
Old 06-11-2012, 03:02 AM   #4
primoz1
My Country: Italy-Slovenia
Line Voltage: 230
Are you push FN and F5 when tested with external monitor ? If primary screen is not connected on motherboard then lapptop self detected external monitor, otherwise it is necessary to press buttons for switch to external lcd.
primoz1 is offline   Reply With Quote
Old 06-11-2012, 03:03 AM   #5
thesloc
Banned
Good question. I have not heard a windows sound because I don't have a harddrive for it (well, there's nothing on it, it's clean). I should probably check for HD activity. Anyway, nothing shows up when connected to external monitor.
Old 06-11-2012, 03:03 AM   #6
thesloc
Banned
yes sir, i pres FN and F5 to toggle between monitors. Nothing happens on external monitor.
Old 06-11-2012, 03:24 AM   #7
primoz1
Line Voltage: 230
I see now, you get defected board two times 110% Where you buy this ? I got bad experience with IPMART anf TOTOBAY and some sellers from ebay too. If not work on first try, send it back immediately. Just make shure if is memory moduls and processor OK and check if is power voltage stable, must not waste-drop any voltage
Old 06-11-2012, 06:44 AM   #8
artois7
Have you kept any components the same, ie CPU, ram etc? Possibly a bad CPU?
artois7 is offline   Reply With Quote
Old 06-11-2012, 07:07 AM   #9
johnwafu
City & State: manila
My Country: philippines
check if you have a netokin below the proc, replace it with 2x 330uf capacitor.that should work,can you post screen shots on below and bottom of the mobo?near proc.
johnwafu is offline   Reply With Quote
Old 06-11-2012, 07:38 AM   #10
primoz1
Line Voltage: 230
This laptop is without nectokin element.
Old 06-11-2012, 01:47 PM   #11
thesloc
Banned
I switched the ram, but not the CPU.
Old 06-12-2012, 07:03 AM   #12
johnwafu
is your proc heating up upon booting?
Old 06-12-2012, 01:21 PM   #13
thesloc
Banned
hmmm it does not. i just sent the board back and should get an exchange.
if this doesn't work i'm not sure what could work
Old 06-12-2012, 01:35 PM   #14
artois7
Try a different cpu.
Old 06-14-2012, 02:43 PM   #15
thesloc
Banned
Alright, tried it again with a different board = still no video! wtf!!
Skeptical that it's the CPU, or I'm gonna give up on it all together.
Old 06-14-2012, 09:04 PM   #16
thesloc
Banned
JUST replaced new CPU, and NOTHING. GRRR.
Anyway to test the mobo by itself? When I connect the dvd-drive it spins it and 'reads' it, so I get sounds. There is no HD led activity, only the sound of the hd spinning somewhat (faintly).
Is there a linux distribution that will play a sound upon boot up?
I can't see anything on the video, the proc has been replaced (it gets warm), RAM modules switched, etc.
If this is a bad mobo, then I have been fucked three times already.
How do I test the lcd screen by itself to rule that out?
The VGA out on the mobo is also connected/dependent on cable that runs to the casing, so it's not integrated in the mobo (cable). I'm going to replace that too.
Old 06-14-2012, 11:06 PM   #17
b700029
Banned
That's autonomous behaviour it'll do as long as it gets power, you can disconnect the signal cable and it'll still do that. The same with the HDD spinning.
You can see if the CPU is getting Vcore and check for a clock signal on the FSB. Probe the BIOS's data pin with an oscilloscope and you should see activity as it initially loads the boot code. The same goes for checking for signals on the video out and LCD connector. Even if your scope's bandwidth isn't high enough, just seeing something other than background noise is enough to confirm that things are happening.
The OEM model should be Inventec PS10AP. Schematic:
http://lqv77.com/download/652/
Don't blindly replace trivial parts like cables without testing for continuity first.
b700029 is offline   Reply With Quote
Old 06-15-2012, 02:28 AM   #18
thesloc
Banned
Someone at technibble has the SAME problem (he swapped out pretty much every part)
http://www.technibble.com/forums/sho...ighlight=l355d
IS THIS REAL LIFE??
Old 06-21-2012, 12:52 PM   #19
kiranfocuz
i can help you - give your laptop part number .
kiranfocuz is offline   Reply With Quote
Old 09-09-2014, 03:14 PM   #20
Bl4ckw1d0w
City & State: Blaine
My Country: United States
I had all the symptoms described and had been searching forever for a solution. I tried pulling everything out one by one to see if any external parts were the issue, then it came down to the motherboard. I was so frustrated, I wanted to throw it all out the window. Then I remembered an old trick of baking graphics cards in an oven to re flow loose not very concrete solder joints. Granted I wasn't about to stick a motherboard in my oven. So Picked up a heat-gun off eBay with an adjustable temp and wide nozzle set it at 480 and low enough pressure not move anything out of place and evenly heat up the board on one side. Left the processor in socket and the heat sink still on. You want to be careful not to bump it or even move the board a little bit because parts are so small they can easily be displaced. After a good 15 mins I could see the solder liquefy a tad and let the board cool off for a good 4 hours at-least to be safe. Flipped the board over and did the same thing on the other side after it was cool. To my amazement the laptop fired right up after I left it overnight too cool. The screen on an everything like the day I bought it. I hope this helps someone.
Bl4ckw1d0w is offline   Reply With Quote
