Old 06-06-2012, 06:43 AM   #1
alecjahn
Dumb enthusiast
alecjahn's Avatar
City & State: Wichita, Kansas
My Country: United States
Line Voltage: 120VAC 60Hz
Default Insignia NS L42Q 10A
The latest mini-head scratcher for my week is the unit described in the title.
The TV turns on, blacklight kicks on, but no picture. Sound works. Typical problem.
My reservations - no blown capacitors, that I can see. And there's plenty of them. Previous owner stated the "video card" was dead. I could believe that... though I also know I've fixed LCDs with the same problem that had bad caps in the PSU, not the logic board.
Is there a good first stop for testing? Front (or side) buttons connect to the mainboard.
I'd post pictures but there isn't much to see unless one wants them for reference. No scorch marks, no popped caps, nothing out of the ordinary. I scoured over it pretty well, I thought. I will at first request.
alecjahn is offline   Reply With Quote
Old 06-06-2012, 07:29 AM   #2
vinceroger69
City & State: Nuneaton Warwickshire
My Country: uk
I'm a: Hobbyist Tech
Default Re: Insignia NS L42Q 10A
fuse on t con board? pictures will help us a lot with help finding your fault
vinceroger69 is offline   Reply With Quote
Old 06-06-2012, 08:24 AM   #3
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
Hi yes we will need pictures for reference- they also help future viewers who encounter similar problems or even want to know the colour banding on a popped resistor.
When you say the back light comes on does it stay on so you have a totally white screen?
What is the power led doing during start up to stable position.
Have you tried different sources?
Does the OSD come on?
We can help a lot more if you please post good clear pictures of the whole chassis, and then pictures of each board, front and back and close up of connectors, (max resolution 2000x2000 and 2MB) using the manage attachments button, which is found by clicking "go advanced" under quick reply.
Examples of what is needed
http://www.badcaps.net/forum/attachm...1&d=1290283049
http://www.badcaps.net/forum/attachm...7&d=1280167246
It will be useful if you can say a bit about yourself - skills tools etc.
selldoor is offline   Reply With Quote
Old 06-07-2012, 02:59 PM   #4
alecjahn
Dumb enthusiast
alecjahn's Avatar
Thanks for your understanding and diplomacy. It means a lot.
No OSD. I assume buttons are doing things behind the blank, -BLACK- backlit screen but I wouldn't know for sure, of course.
The power LED does nothing out of the ordinary. Red when in standby, then promptly a solid blue (where it stays) upon hitting the power button. Then a standard number of seconds later, the backlight kicks on to the black screen.
Pardon the use of a flash on the mainboard, I couldn't get a steady shot otherwise (darn this dark house!) I hope that suffices.
The third picture/board is hidden under the metal shield at the top of the fourth picture, which I supplied so you all can see the wiring/layout.
Old 06-07-2012, 03:35 PM   #5
budm
budm's Avatar
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Please see the test point as shown in the picture.
Can you also get the LCD panel model number as printed on the sticker?
By the way, I wish the pictures are brighter and in focus.
budm is online now   Reply With Quote
Old 06-07-2012, 03:42 PM   #6
mr.sky
Budm, not a related question, but I need to know what software
do you use to make the yellow squares and arrows. Very Nice.
mr.sky is offline   Reply With Quote
Old 06-07-2012, 04:01 PM   #7
budm
budm's Avatar
I use PDF pro (old version 6, which is really cheap to get) to convert the original jpeg to PDF format so I can put in notes, then I can save it as PDF and also save it as JPEG.
Old 06-07-2012, 04:29 PM   #8
selldoor
Slow Learner
selldoor's Avatar
I didnt think pics were too bad compared to some we see - I hope its just the fuse. If not can you do pics of the long inverter board either in 2 or 3 shots.
Also can you check the bottom hdmi connector it has reflected oddly in the picture - just check its not a crumpled pin/sheath or whatever bits inside those are called.
Old 06-07-2012, 05:13 PM   #9
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Why on earth did the manufacturer use mostly high quality Chemicons on the main board, and then use some crummy Elite and CrapXon on the PSU?! It would work far better the other way around!
Sometimes I wonder what the purchasing people are doing and who put them in charge.
Old 06-07-2012, 11:08 PM   #10
alecjahn
Dumb enthusiast
alecjahn's Avatar
The "Main fuse for T-CON" measured a minute resistance when I set my multimeter on 20k ohms. The [capacitor?] measured something when tested on the same range.
Old 06-07-2012, 11:33 PM   #11
budm
budm's Avatar
" measured a minute resistance" ??
Try 200 Ohm scale to see what you read, I expect to see less than one Ohm on the fuse.
Old 06-08-2012, 12:17 PM   #12
alecjahn
Dumb enthusiast
alecjahn's Avatar
It definitely did not read anything on the lower settings like the 200ohm scale.
Is it going to be easy to figure out the replacement part? Is it likely that CP5 is also toast?
Old 06-08-2012, 12:59 PM   #13
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
Yeah, anything more than about 3 ohms on a general purpose DMM is probably bad. Use 200 ohms, if it does not read anything, it is bad. On the other hand, if CP5 measures more than 200 ohms, it is probably good.
Old 06-08-2012, 01:10 PM   #14
budm
budm's Avatar
So the fuse show no reading, it is open.
@test points 1 & 2 (Capacitor CP5, there are other 4 caps that are in parallel with CP5) should also show very high resistance, I have you check the test point just to be sure that it is not shorted circuits.
So basically, the fuse should read like shorted circuits (less than one Ohm).
The capacitor should read like open circuits or very high resistance since it can have other circuits in parallel with the caps.
Old 06-08-2012, 01:12 PM   #15
alecjahn
Dumb enthusiast
alecjahn's Avatar
Alright. Looks like a fuse, so far, then?
Old 06-08-2012, 01:17 PM   #16
budm
budm's Avatar
Next thing we need is to find out the value of that fuse, I usually get the spec sheet of the LCD panel and look at the current draw of the T-CON board, you need to look at the sticker on the LCD panel, it should have model number and the revision number on that sticker.
Old 06-08-2012, 03:57 PM   #17
alecjahn
Dumb enthusiast
alecjahn's Avatar
Is that sticker likely the one on the top right-center of my fourth picture?
It says E42RMZNKW3BYNN
The T-CON board has V420H1-C12 printed on the board. Seems like a common piece, and not too pricey, however a fuse replacement would be nearly free in comparison.
The fuse, of course, says nothing to me - "UD".
Upon some searching, I find this TV may, MAY, perhaps be the same as a Hitachi L42A403.
Old 06-08-2012, 04:09 PM   #18
budm
budm's Avatar
Oh boy, your chassis completely cover the whole LCD panel, I will use the T-CON number to find out more info.
OK, I found out what panel is used in your TV:
http://www.shopjimmy.com/cmo-35-d033150-t-con-board.htm
Old 06-08-2012, 04:14 PM   #19
alecjahn
Dumb enthusiast
alecjahn's Avatar
http://www.go-gddq.com/upload/2011-0...2109492115.pdf
If it helps, I found a PDF for the Hitachi sister unit, as confirmed in your link. The exploded views look to be identical. I assume just a re-branding.
Though for some reason... they don't identify the T-CON.
Old 06-08-2012, 04:19 PM   #20
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
That is because they will use whatever LCD panel they can get the cheapest on the day.
