#1 |
City & State: Kentucky
Line Voltage: 120VAC 60HZ
I got this TV as dead from a friend. There were no lights showing on Vizio label on the front of the TV. I checked the power board for power. The blue wire from the AC Input shows 59V. The brown wire shows 63V. The main fuse shows 63V with common on ground screw at AC connector. The large cap shows 0V with common to screw and red probe to positive side of cap. With both black and red probes on cap I get a reading of 10V.
On the main board there are two smd fuses. Both show 0.1ohm. On Inverter board there are two fuses. The first is small 0.75A / 63V. It reads 0.7ohms. The second is larger and is rated at 6.3A / 125V. It reads 0.1ohms. I am at a loss as to why I am not getting the correct power to the fuse and the large cap. Is is possible or likely that the power cord is bad? Are the two readings taken from the AC connector on the power board what are expected? I replaced all the Electrolytic Caps on the power board including the large one. I also found 3 diodes that read funny when I tested them. So I replaced those 3. I also found one Zener Diode and a 1/4W resistor that I thought were bad and replaced those. One of the diodes, the Zener and the Resistor were all together near the heat sink on the right side of the power board picture. The other two diodes that I replaced were large. One of them you can see in the picture on the top side of the board near the two tall E.Caps. Any thoughts will be appreciated. ![]()
Have you ever stopped to think and then forget to start thinking again? |
#2 | |
City & State: Canada
2) What is the resistance reading of the main fuse on the power board?
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- Last edited by retiredcaps; 06-01-2012 at 05:58 PM.. |
#3 |
Slow Learner
City & State: Lancashire UK
I would be inclined to start again.
First check your meter - on Ohms - touch the probes together - should read nil or very close. Next Meter on volts DC test a couple of batteries/cells. Next with meter on Volts AC Care - High voltage test- Black probe on Blue cable Red probe on Brown Cable should be 120VAC. Black probe on Blue cable red probe on fuse should still be 120VAC If that is OK then Set Meter on 600vDC and put the black probe on the negative leg of the big cap and the red probe on the positive leg of the big cap should be around 170VDC |
#4 | |
At AC connector on Power Board with AC set on DMM I now get 124.4V. On the Main Fuse I get 0.1ohms and with AC setting checking Fuse with Black Probe on grounding screw and Red Probe on leg of Fuse I get 62.9V. Retiredcaps check post #5. Last edited by killian6pk; 06-02-2012 at 12:36 PM.. Reason: Added info |
#5 | |
Checked meter with batteries: Used (but almost new) AAA tested 1.405v; New AA tested 1.63V Checked AC imput connecter got 124.3V AC With Black Probe on Blue wire and Red Probe on Main Fuse got 124.1V AC. Set Meter on DC checked Large Filter Cap with Black on Negative and Red on Positive side got 0.0 V. So at least I now have power going thru the Fuse. What should I check now since power is not getting to the Large Filter Cap (New)? Also at the same time I changed the caps I pulled the Bridge Rectifier since I had read on another post that it sometimes causes a problem. I checked it. It checked out ok so I soldered it back onto the board. Same with the 2 TO220 packaged Schottky Diodes on one of the Heat Sinks. |
#6 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Check your solder joints for the caps. Did you touch up the soldering around the bridge? If not, do this. Seems like there's an open circuit somewhere.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 9 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#7 |
City & State: Gaffney, SC
My Country: america
Line Voltage: 120vac 60hz
I'm a: Hobbyist Tech
look around the power cord where it plugs in some sets have a fuse on one leg of ac coming in. if it goes you wont get full voltage. i have two sets here with fuses in the connector. a small plastic insert with a fuse underneath, look closely there is a fuse pic etched onto the plastic.all vizios don't have them but some do.i found the first one accidently by removing the plug assy, voltage was right at cord fell at the inside connector.when i had it in my hand i saw the fuse.
#8 |
Thanks guys will check both of those suggestions and get back to you with results.
#9 |
Slow Learner
I should have said check ac voltage on BOTH end of the fuse to the blue cable
Can you post a pic of the bottom of the board? Last edited by selldoor; 06-02-2012 at 02:39 PM.. |
#10 | |
I will get pictures of the bottom of the Board ASAP however it will have to be tomorrow as I have a birthday party for a family member to go to. |
#11 | |
Does anyone know what rt stands for on the board it looks like a resistor also what does rv stand for this looks like a glass enclosed Zener Diode but is not the same coloration. Thanks for the help will be back on tomorrow. |
#12 | |
#13 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
Can we see good picture of the bottom side of the power board?
Never stop learning or per Greek Pro "when you will update your ID from Knowledge Seeker to a Pro (in 10 years) , then I will take you more seriously, for now you are just a kid playing with it keyboard" Baisc LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#14 |
#15 |
"I also found 3 diodes that read funny when I tested them. So I replaced those 3. I also found one Zener Diode and a 1/4W resistor that I thought were bad and replaced those. One of the diodes, the Zener and the Resistor"
Did you replace those parts with same P/N, rating? A lot of parts to replace at one time. |
#16 |
City & State: Harrogate UK
#17 |
My Country: UK
I'm a: Student Tech
[Post error... please ignore.]
#18 |
Here is the picture of the bottom of the board. There are two places where I messed up the pads when I removed components for testing. I scraped off the green carefully and soldered the legs to the copper trace on those two components. I think they are solid. There is also a scratch I made with my iron on the right side of the board. Check that out to see if that might be causing my problem.
#19 | |
#20 |
My Country: america
try replacing the startup cap somewhere close to the 8 pin ic. they dont always read bad esr when in circuit.
| Thread Tools | |
| Display Modes | |
