Old 06-09-2012, 05:23 PM   #101
Jahson
City & State: London
My Country: UK
Line Voltage: 230Vac 50hz
Default Re: 42lg3000-za No Picture but got sound
Cheers Budm yea i have come across a similar repair kit. Im not at the set, will be there on monday. I cant remember if i did check those 3 points.
Jahson is offline   Reply With Quote
Old 06-12-2012, 01:01 PM   #102
Jahson
My Country: UK
yesday i was doing some probing on the mainboard, & i came across a zener diode that was reading .000, i double check.
ZD503 is the one giving me this reading ive circled it in blue.
The zener diode was still on the board when i took the reading.
Old 06-12-2012, 01:04 PM   #103
Jahson
My Country: UK
Yesday i was doing some probing on the mainboard, & i came across a zener diode that was reading .000, i double check.
Old 06-12-2012, 01:06 PM   #104
tom66
Savin' for TSLA
tom66's Avatar
City & State: Leeds & B'Stoke
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Check on ohms too. Do you have a picture of the underside of the board where the diode came from?
Old 06-12-2012, 01:28 PM   #105
Jahson
My Country: UK
Okay just check it on 200ohms it reads 01.0 in both directions.
Old 06-14-2012, 04:13 PM   #106
Jahson
My Country: UK
Got hold of a next 42LG3000-ZA tried the inverter boards, no joy also tried the AV board no joy, changed the mainboard no joy?
The T-Con was different so could not change it.
Whots the chances its the T-con the problem?
Old 06-14-2012, 04:59 PM   #107
selldoor
Slow Learner
selldoor's Avatar
City & State: Lancashire UK
Hi - is this another non-working set?
By the way I have been looking back and still cannot see that we sorted out testing the
inverter transformers. Perhaps you can do comparison tests with the second lot.
Try and do all the pins - like 1 to 1 1to2..........1 to12 then 2 to3 ......2 to12 and so on.
Just record those in the 300 -2000 range. Tomorrow if I remember I will try and hunt down those transformers -
selldoor is offline   Reply With Quote
Old 06-14-2012, 05:21 PM   #108
tom66
Savin' for TSLA
tom66's Avatar
My Country: UK
I'm a: Student Tech
What was the panel in the other TV? The problem could still be in the main board, because the other main board may be configured for the wrong panel, causing no display.
Old 06-16-2012, 06:21 AM   #109
Jahson
My Country: UK
The other set had a broken screen, tell the truth i was in a hurry an changed the inverters, av board, mainboard. This was like 12am
The mainboard and av board part numbers are the same.
The inverters had a different model number ended .50 (not at set cant remember full details) mines ended 54 & 55.
So i was going try test again but with my old inverters back in set.
I thought it be a good idea to buy the smashed set, so i could test an see if things are the same.
I try get the T-Con part numbers later when my friend gets back, The T-con from the smash set was twiced the size of my original T-con.
Old 06-18-2012, 11:54 AM   #110
Jahson
My Country: UK
I put back the original inverters still no joy, with the replacement mainboard.
I notice iT gives 3 red pulsing flashes before it switches to the blue colour to say its on? if thats any help.
original inverters master = vit71053.54 logah rev:0
original slave = vit71053.55 logah rev:0
Replacement master = vit71053.50 logah rev:3
Replacement slave = vit71053.51 logah rev:3
Original T-con p/n - T370XW02 VC CTRL BD
Replacement T-con p/n - T420XW01 CTRL BD
Old 06-18-2012, 02:03 PM   #111
Jahson
My Country: UK
It seems confusing in preview mode? didnt write it like that. Everything to the far right is T2.
Also stated when (meter set to 2k)
Meter set to 200 ohms
Master Inverter Test
Transformer T1 Transformer T2
1-2 = 00.6 same
1-3 = 00.6 same
1-4 = 00.6 same
1-5 = 00.6 same
1-6 = 00.6 same
1-7 = .519 (meter set 2k) .521
1-8 = .519 (meter set 2k) .521
1-9 = .536 (meter set 2k) 1 left side all settings
1-10= .536 (meter set 2k) 1 left side all settings
1-11= .536 (meter set 2k) .539
1-12= .519 (meter set 2k) .539
2-3 = 00.6 same
2-4 = 00.6 same
2-5 = 00.6 same
2-6 = 00.6 same
2-7 = .518 (meter set 2k) .522
2-8 = .518 (meter set 2k) .522
2-9 = .536 (meter set 2k) 1 left side all settings
2-10=.536 (meter set 2k) 1 left side all settings
2-11=.536 (meter set 2k) .540
2-12=.536 (meter set 2k) .540
3-4= 00.6 same
3-5= 00.6 same
3-6= 00.6 same
3-7= .519 (meter set 2k) .522
3-8= .519 (meter set 2k) .522
3-9= .537 (meter set 2k) 1 left side all settings
3-10=.537 (meter set 2k) 1 left side all settings
3-11=.537 (meter set 2k) .540
3-12=.537 (meter set 2k) .540
4-5= 00.7 same
4-6= 00.7 same
4-7=.519 (meter set 2k) .523
4-8=.519 (meter set 2k) .523
4-9=.537 (meter set 2k) 1 on left side all settings
4-10=.537 (meter set 2k) 1 on left side all settings
4-11=.537 (meter set 2k) .539
4-12=.537 (meter set 2k) .539
5-6= 00.7 same
5-7=.520 (meter set 2k) .522
5-8=.520 (meter set 2k) .522
5-9=.538 (meter set 2k) 1 on left side all settings
5-10=.538 (meter set 2k) 1 on left side all settings
5-11=.538 (meter set 2k) .540
5-12=.538 (meter set 2k) .540
6-7=.520 (meter set 2k) .522
6-8=.520 (meter set 2k) .522
6-9=.538 (meter set 2k) 1 on left side all settings
6-10=.538 (meter set 2k) 1 on left side all settings
6-11=.538 (meter set 2k) .540
6-12=.538 (meter set 2k) .540
7-8=00.7 same
7-9=15.4 1 on left side all settings
7-10=15.4 1 on left side all settings
7-11=15.4 15.2
7-12=15.4 15.2
8-9=15.4 1 on left side all settings
8-10=15.4 1 on left side all settings
8-11=15.4 15.2
8-12=15.4 15.2
9-10=00.6 same
9-11=00.6 1 on left side all settings
9-12=00.6 1 on left side all settings
10-11=00.6 1 on left side all settings
10-12=00.6 1 on left side all settings
11-12=00.6 same
Same=T2 same as T1, also i did try separate the readings,
Now i go do the slave transformer.
Old 09-16-2012, 12:00 PM   #112
Jahson
My Country: UK
Did someone find the fix, how do i test the ccfl's
Old 09-16-2012, 03:39 PM   #113
cadiman
City & State: chesterland Ohio
I was able to tell just by looking at them. You will see burn marks on the inside.
There are a few types pending panel maker. The ones you have should clip in. I prefer soldered myself. Thats what I do when replacing them.
I always have panels around so I just use what I have from other 42" panels.
The main issue with different models is the lcd panel including the t-con needs to stay with that mainboard. The backlight may be similar and the power supply will normally be the same with these since all inverters run on 24v and use the same control system for the most part. You just need to remember the lcd display, t-con and mainboard must stay together as far as L/G 42lg20.30.50 You can swap the mainboards only within the model families like all 26,32,37,42,lg 30-ua models can use the same mainboard The 26 will need a modified plug (it is missing from the larger models) but the board pinout is still there.
cadiman is offline   Reply With Quote
Old 01-04-2013, 03:33 PM   #114
fantoma
City & State: 8700
My Country: romania
Did you repair that lcd?
Maibe i can help you.
i just fix a master inverte board for 42lg3000 lcd.
fantoma is offline   Reply With Quote
Old 01-04-2013, 04:02 PM   #115
fantoma
City & State: 8700
My Country: romania
Assemble all parts together.
Plug in all connectors.
Power on the lcd. Whith your multimeter set on DC , check between pins 1,2,3,4 or 5, and 6,7,8,9 or 10 ,on master inverter power plug CN1, if there is 24Vdc, if so, check between pins 6,7,8,9 or 10 and pin 12, if there apear 5Vdc on pin 12 when you power up your lcd, and dissapears when you power down yor lcd from remote control. If all are ok, there is an defective master inverter board.
Now, on the master inverter board find U1, located betwen connectors CN1 and CN2, this in an 5Vdc regulator (78M05), on pin 1 you must find 24Vdc , on pin 3 5Vdc, pin 2 is chassis and is grounded.
If you don't have 24Vdc on pin 1, check fuse. The fuse is F1, located near pin 1 of CN1 power connector, is black an marked 2.0 . Unplug LCD from mains, replace fuse F1 (short it just for test), and you got a fully working LCD.
Please post here your results to see if this helped you.
Best regards...
Old 03-09-2013, 09:40 AM   #116
Alessio
City & State: Pescara
My Country: iTALIA
Best regards...
Hello
I have 7vdc on Pin 3
22,5Vdc on Pin 1
Help?
Alessio is offline   Reply With Quote
Old 03-10-2013, 12:13 PM   #117
Alessio
My Country: iTALIA
F1 > 24v
F2 > 0v
How to replace F2?
KOAC 8A FUSE
Old 02-14-2015, 05:42 AM   #118
cosmindaniel
City & State: bucharest
My Country: Romania
So, yesterday i was to LG service. I have a 42LG3000 television, with this simptoms white screen but good sound. Actually i try to change T-con Module, i bought a new one, i replace all condensators, finally from service sad me this: YOUR DISPLAY IS DEAD, ACTUALLY , the matrix from this is broken, its necessary to buy a new one, but may be you need to buy a new tv.
So if you have this problem, don't try to change some parts from inside, because 99% the display is broken............
Good Luck.
cosmindaniel is offline   Reply With Quote
Old 01-22-2017, 07:13 AM   #119
majterix
City & State: thessaloniki
My Country: greece
hello my friends...i have the same tv 42LG3000 i have the this same problem. first i try to open the tv and i was in three times flash the power led that seems to try to open and then close..i check the volt from power suply and it is ok . for the inverters 24 volt 5 volt and 3,3 volt . next i check one by one the inverters and i find that the one of this doesnt work the half transistor caled nikos .......... i try and put off only the inverters and try to open the tv... now i have only sound. this is good .. for one reason.but i need to power on the screen. i bought from internet the same inverters..i put them and now do this... open normaly with sound. but give me only one secont of view.. then black screen again with sound.. i have check the screen with bright lamp and i can see something but i need to work the backlight. can you help me what i have to check?? i repeat that now open normaly with backlight but only one secont then black screen again but i have sound.
majterix is offline   Reply With Quote
Old 01-22-2017, 07:31 AM   #120
dick_barton
dick_barton's Avatar
City & State: Cardiff
My Country: Wales
Line Voltage: 230V AC, 50Hz
I'm a: Hobbyist Tech
Can you give the name and voltages on the two connectors shown.
Photo courtesy of Shopjimmy
dick_barton is offline   Reply With Quote
