Go Back   Badcaps Forums > General Topics > General Computer Discussion
Old 05-28-2012, 08:36 AM   #1
stevo1210
FD Civic Driver
stevo1210's Avatar
City & State: Eastern coast
My Country: Australia
Line Voltage: 240V 50Hz
I'm a: Student Tech
Default Testing computers
How do you guys test computers and laptops for stability issues etc? As in what method or burn in software do you use?
I personally just pop memtest86+ overnight and if it doesn't crash I'll call it a day... Open to suggestions.
...You're speaking to a Honda enthusiast.
stevo1210 is offline   Reply With Quote
Old 05-28-2012, 09:14 AM   #2
Koda
Koda's Avatar
City & State: Prilep
My Country: Macedonia
Line Voltage: 220v AC
Default Re: Testing computers
If system is suspected to have stability issues or a mobo is recapped I usually run prime95 for 36 hours, if memory is suspected memtest for 36 hours and if gpu is suspected furmark for 6-10 hours. That's only for extreme cases. If other non critical work is being done on the system 5 hours of testing.
Guns don't solve problems. I'll take 12
Koda is offline   Reply With Quote
Old 05-28-2012, 09:58 AM   #3
ratdude747
Black Sheep
ratdude747's Avatar
City & State: Madison, IN
Line Voltage: 120VAC 60Hz
memtest86.
(Insert witty quote here)
ratdude747 is offline   Reply With Quote
Old 05-28-2012, 03:13 PM   #4
c_hegge
c_hegge's Avatar
Memtest86+ for 24 hours, followed by IntelBurnTest for 24 hours.
c_hegge is offline   Reply With Quote
Old 05-28-2012, 09:25 PM   #5
Topcat
The Boss Stooge
Topcat's Avatar
City & State: Salem, MO
My Country: United States
a program called 'the troubleshooter' and/or memtest
<--- Badcaps.net Founder & Owner
Badcaps.net Services:
Premade Capacitor Kits
Badcaps.net Capacitor Master List
Motherboard Repair Services
If you've come here in search of replacement capacitors or repair services, please use the links above.
http://folding.stanford.edu/
Team : 49813
Join in!!
Team Stats
Topcat is offline   Reply With Quote
Old 05-28-2012, 10:41 PM   #6
stevo1210
FD Civic Driver
stevo1210's Avatar
I'm a: Student Tech
I use the troubleshooter sometimes. Only issue is that it doesn't work on laptops like IBM Thinkpads? or did I get a screwed up CD?
Old 05-29-2012, 05:07 AM   #7
Th3_uN1Qu3
Believe in
City & State: Bucharest
My Country: Romania
Line Voltage: 230VAC 50Hz
The Troubleshooter is an old piece of software, it won't work with everything nowadays. IntelBurnTest and Furmark, and Victoria (a russian software, from Hiren's Boot CD) for the HDD.
Originally Posted by PeteS in CA View Post
A working TV? How boring!
Th3_uN1Qu3 is offline   Reply With Quote
Old 05-30-2012, 12:16 PM   #8
lti
lti's Avatar
City & State: Windsor, Colorado
I'm a: Hobbyist Tech
Toshiba tests computers by starting Windows, opening Internet Explorer, and then shutting the computer off as soon as the home page loads.
lti is offline   Reply With Quote
Old 05-30-2012, 07:08 PM   #9
ncovert
ncovert's Avatar
City & State: Pennsylvania
Line Voltage: 120V 60Hz 200A
I'm a: Forum Junkie
LOL. How do you know that, or did you make it up?
As for testing, usually Memtest86+ or Prime95. I also test the PSU voltages with a DMM and make sure everything else works.
ncovert is offline   Reply With Quote
Old 05-30-2012, 07:46 PM   #10
lti
lti's Avatar
I saw the event logs and browser history on my laptop after it was returned from its first two warranty repairs. They actually do run testing software when they first receive the computer, but I don't think they perform any tests to see if the part they replaced fixed the problem.
Old 05-30-2012, 07:47 PM   #11
c_hegge
c_hegge's Avatar
Really? I've had nothing but good experiences with Toshiba support.
Old 05-30-2012, 11:27 PM   #12
larrymoencurly
larrymoencurly's Avatar
Was that Toshiba factory service or a local independent authorized repair center? Because I've heard the latter vary widely in quality, but the one in NW Phoenix, AZ is decent. Also Toshiba factory tech support for software seems good, but hardware tech support is among the worst I've experienced:
1st level tech: knows nothing about computers (What's the maximum memory capacity of model XYZ? "One-six-zero-G.B."), just types your inquiries into the same Ask Iris search engine that the public has to use.
2nd level tech: knows the very basics of computers in general, still has no access to non-public information.
3rd level tech: may understand specifics of Toshiba computers, can access non-public information. May be crabby and not let you speak to a supervisor or manager ("I'm the top of the top, baby!").
larrymoencurly is offline   Reply With Quote
Old 05-31-2012, 06:38 AM   #13
Krendoshazin
City & State: London
My Country: England
  1. Memtest86 is good for testing the stability of the CPU, RAM, and any components related to that system.
  2. I use a DOS version of Hard Disk Sentinel for testing hard drives in a system; this allows me to see if there are any problems with the disk itself, or with communication between the disk and the controller.
  3. I have a device for testing power supplies that checks all of the voltage rails and tells me if any of them are out of spec. However, this doesn't test the supply under stress and I'll figure out how to test it under a load at some point.
  4. I have Slax on a USB drive with a few tools loaded on it. One of these is 'System Stability Tester' which makes the system run at 100% by calculating pi to a specified amount of places (the more digits, the more resource intensive). If it can handle a full load for several hours, then I consider it stable.
That pretty much covers my toolkit.
Krendoshazin is offline   Reply With Quote
Old 05-31-2012, 11:41 AM   #14
lti
lti's Avatar
This computer went to Louisville, Kentucky.
