Go Back   Badcaps Forums > Electronics Theory and Troubleshooting > Troubleshooting Laptops & Notebooks
Old 05-20-2012, 11:24 AM   #1
mrfree
City & State: Abruzzo
My Country: Italy
Default Acer Aspire 1300 doesn't switch on at all
I'm trying to repair an Acer Aspire 1300 series, when I press the power button nothing happens... no fan, any led, nothing.
I disassembled it and removed all removable devices: battery, hdd, floppy, cdrom, ram but nothing changes I also tried to remove cpu too, still no changes
The power supply output is ok, I checked the power button dipswitch on the mb and it works too... I'd like to test the standby power anywhere, it uses a Maxim 1632... any suggestion?
mrfree is offline   Reply With Quote
Old 05-20-2012, 11:39 AM   #2
mrfree
My Country: Italy
Default Re: Acer Aspire 1300 doesn't switch on at all
Reading some useful threads on this forum I can add the mobo is probably a Quanta "T2A" rev E... I'm starting searching for the battery charger circuit on it
Old 05-23-2012, 11:40 AM   #3
mrfree
My Country: Italy
checking the battery circuit I've found on the battery + line (without battery attached) I've 5,45v just after insert the power plug, that voltage lowering constantly to about 0,6v after few seconds... could it be normal?
Old 05-23-2012, 08:04 PM   #4
fddizon
City & State: Philippines
My Country: Philippines
Line Voltage: 220v 60Hz
Send a message via Yahoo to fddizon
looks like the circuit is draining the power. check for any shorted mosfets, capacitors on board
fddizon is offline   Reply With Quote
Old 05-25-2012, 02:42 AM   #5
leopold1112
City & State: Ladigin
My Country: UA
To check tension on duty on MAX1632.
leopold1112 is offline   Reply With Quote
