#1 |
City & State: ABIDJAN
My Country: COTE D'IVOIRE
when it starts, it stays on moin one minute and turns off. he does it restart only
#2 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Do you have a camera... can you take pictures of the inside of your TV?
Notice you live in Cote D'iovre, so how easy will it be to get parts? Do you have many electronics shops/distributors?
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 10 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#3 |
City & State: Nebraska
"when it starts, it stays on moin one minute and turns off. he does it restart only" look like the digital mainboard is bad (its control on/off and TV function)
open the TV & take picture and pot this thread |
#4 |
It is true that I am in Ivory Coast, but we have the possibility to have the parts. as you ask here are photos of the card. thank you
#5 |
Slow Learner
City & State: Lancashire UK
Hi- Pictures need to be a bit sharper
Examples of what is needed http://www.badcaps.net/forum/attachm...1&d=1290283049 http://www.badcaps.net/forum/attachm...7&d=1280167246 It will be useful if you can say a bit about yourself - skills tools etc Do you have a multimeter and can you use it?. Can you do a picture of the inverter board - one down left side in pic 1 Do it in 2 halves - overlap When you switch on does the screen light up then go off. What do the LEDs do - stay on/ flash/ change colour "he does it restart only" what do you mean? Does it try to restart after it goes off. Service manual - here: http://elektrotanya.com/sony_klv-26s.../download.html Last edited by selldoor; 05-14-2012 at 07:25 AM.. Reason: add sm |
#6 |
in fact I am a technician and I'm used to depanner.Mais it is now that I work on LCD, PLASMA. Also I have a multimeter that I know and use lots of other equipment. I want to distinguish from other technician here because they do nothing but tinker. Otherwise when you turn on the screen, it stays on for a miniute to moin and he died. and after two minutes, it turns back on then back off. no flashing LED to assert an error code. thank you
#7 |
Slow Learner
Do it in 2 halves - overlap |
#8 |
I'm not too bright in English so that I have a little trouble following you but thank you for help.
#9 |
City & State: Monrovia, CA
Line Voltage: 120VAC 60Hz
I had a 40W4150 which restarted like three times and then it gave me a 10 blink code. I have reset to factory, did a firmware update and stopped doing that.
#10 |
OK. thank for a suggestion
#11 |
City & State: Brno
My Country: Česko
Hi. I have LCD Sony Bravia KDL-40W5710 and the same problem. Can you tell me, please, how shall I do the reset to the fastory and the firmware update? There is no time. The TV turn after 3 seconds off. Thak you wery much! Miloš
#12 |
Slow Learner
@Mady - I think I was on holiday and missed following this up. On the inverter board
there is at least one fuse that I can see - did you test it? |
#13 |
City & State: Brno
My Country: Česko
I have no fuse on the inverter, bud the inverter is OK. I need to know, how can I do the reset and the firmware update. Do you know it? Miloš
#14 |
My Country: UK
I'm a: Student Tech
It might be done with the USB port. Maybe Sony has firmware on their website.
#15 |
City & State: Brno
My Country: Česko
Bud the TV can't turn on! I need to do reset first! My question is: How to do? Miloš
#16 |
Slow Learner
@milha My post was directed at MADY but if you look at MADY's picture 3 there is a small white fuse just above the connector. It is at F4 which might suggest there are other fuses on that board. Do you have a different board?
#17 |
City & State: Brno
My Country: Česko
@selldor Yes, I heve a different board and a different fault. I need to reset the TV. Miloš
#18 |
On the model that I have worked I had to hold the arrow up from the remote while I turned the TV on from the TV's power button and then let go the arrow up button.
#19 |
City & State: Brno
My Country: Česko
I am sorry, I didn't succeed to do reset bei the model LCD Sony Bravia KDL-40W5710 by this way. Good luck to you! Miloš
#20 |
Seeldoor. thank you. but I gave the TV to the owner because he was too impatient.
| Thread Tools | |
| Display Modes | |
