#1 |
City & State: Kent
My Country: UK
Line Voltage: 240v AC 50Hz
Model: Dell E173fpf
Fault: No power led comes on and nothing is displayed on the screen at all. Observations: constant ticking noise heard from T850 and I get a constant 131v from the primary capacitor (using mains earthing point) I have changed cap C506 (4.7uf 16v) as the ESR was slightly high - 2.1 I have also changed D854 (SRF 10-10) as I had seen on another post that this part was faulty and before I replaced it the solder points looked slightly different compared to the rest, maybe due to it running hot?. I have checked the board and cannot see any burn mark at all. I have checked the larger resisters and these are fine. D850 which I think is known as a bridge rectifier tested fine. Questions: If I put my negative lead only from the DMM on the primary negative I get some fluctuations in voltage normally between 0.5 to 6v's so what could I do to get an accurate reading from the pins on U850? Could someone please confirm what Q850 does and how I might test this component? Many thanks Ps: I am aware that there is some excess flux which I didn't wipe off prior to taking the photo's.
Fixed so far: GNR TS902W monitor |
#2 | ||
City & State: Canada
2) Ticking suggests a) bad startup cap (likely C857 - 47uF 50V cap?) b) bad SMPS IC U850 c) shorted component like a diode (check D851, D852, and D853) Quote:
4) See if Q850 VCC is shorted to GND. 5) Measure the DC voltage across C857. It should be steady. 6) Those are excellent clear focused photos. Easily in the top 5 best photos this year.
--- begin sig file --- If you are new to this forum, we can help a lot more if you please post clear focused pictures (max resolution 2000x2000 and 2MB) of your boards using the manage attachments button so they are hosted here. Information and picture clarity compositions should look like this post. We respectfully ask that you make some time and effort to read some of the guides available for basic troubleshooting. After you have read through them, then ask clarification questions or report your findings. Please do not post inline and offsite as they slow down the loading of pages. --- end sig file --- |
#3 | |
Q850 is your power mosfet (3 pin IC mounted on heatsink). You can see if the power mosfet is shorted by measuring the resistance between D-S, D-G, G-S. Last edited by retiredcaps; 05-09-2012 at 09:20 PM.. |
#4 |
City & State: Kent
My Country: UK
Retiredcaps - that to do list has really helped, here's what I've got:
1) The 131v was DC on the primary cap. Measuring from the legs (solder side) I get 340v dc steady. 2a) C857 is a 10uf 50v - tested at 0.87esr 9.72uf, live test has dc voltage fluctuating up and down between 13-19v b) diode / continuity test of U850 pins 1 to 7 gave a reading of 477 on the DMM - I am assuming this is ok? c) diode / continuity test : D851 - 494 D852 - 472 D853 - 498 3) U850 has these part no's (used a DSLR sensor loupe for reading - very handy!!) on it SG6841S & KA126690501E I have located the datasheet and included some diagrams. datasheet specs: Min Typical Max U850 - startup threshold voltage 15 16 17 - minimum operating voltage 9 10 11 I tested the resistance on Q850. I get 94K between G&S but testing S-D or D-G the resistance keeps changing normally increasing past the 200k mark. What do you recommend next? |
#5 | ||||||
#6 | ||||
City & State: Kent
My Country: UK
#7 | |
Measure the resistance between pin 1 (GND) and other pins. That is, 1-2, 1-3, 1-4, 1-5, 1-6 and 1-8. Report all readings. 2) If none of them are shorted, my best *guess* is that SMPS IC is bad even though it is not shorted. If you search this forum for SG6841, you will see similiar cases where this IC is bad. If you have to order a new SMPS IC, I suggest replacing the startup cap with a Panasonic FC even though it tested fine with your ESR meter. SG6841 is available on ebay for $2.50 + $1.00 shipping. |
#8 |
#9 | ||
City & State: Kent
My Country: UK
1-3 = 30K-->130K+ 1-4 = 26K 1-5 = open 1-6 = 41ohm 1-7 = 90ohm --> open 1-8 = 172ohm -->open Quote:
#10 |
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
You may want to download one of these service manuals:
http://elektrotanya.com/?q=showresul...oria=&kat2=all
Never stop learning Baisc LCD TV and Monitor troubleshooting guides. http://www.badcaps.net/forum/showthr...956#post305956 Voltage Regulator (LDO) testing: http://www.badcaps.net/forum/showthr...999#post300999 Inverter testing using old CFL: http://www.badcaps.net/forum/showthr...er+testing+cfl Tear down pictures : Hit the ">" Show Albums and stories" on the left side http://s807.photobucket.com/user/budm/library/ TV Factory reset codes listing: http://www.badcaps.net/forum/showthread.php?t=24809 |
#11 |
Please see the notes in the pictures, see what happen when you lift one end of the resistor and let us know what happen.
What I am trying to do is try to remove one load at a time to find out if the loads are causing the power supply to go into shutdown, or the power supply itself is having the problem. |
#12 |
#13 | |
City & State: Kent
My Country: UK
#14 |
OK, the shorted circuit is not in the logic circuits side, you will have to remove the round inductor and see if the problem goes away next, you have to use good 40watts or more with large tip (2.5~3mm wide tip) soldering tool to work on this double sided circuit board, otherwise you will be damaging the traces on the board.
#15 | |
City & State: Kent
My Country: UK
#16 | |
OK, I see that the R861 is 470 Ohms, so you are reading 41 Ohms, it must have an internal short inside the IC as retiredcaps has suspected. You can try lifting pin six and measure the resistance between PIN 6 and Pin 1 again. Last edited by budm; 05-11-2012 at 02:26 PM.. Reason: Found the value of R861 |
#17 | |
City & State: Kent
My Country: UK
#18 |
47 ohms is correct, I thought I saw 471 as printed but not sure if I was seeing it right.
I do not belive you will be reading 41 Ohm between pin6 and Pin 1 if the resistor is 47 Ohms. |
#19 | |
City & State: Kent
My Country: UK
#20 |
OK pin 6 is good.
| Thread Tools | |
| Display Modes | |
