Old 05-22-2012, 05:17 PM   #61
nickdablack
City & State: Melbourne
My Country: Australia
Line Voltage: 240vac 50Hz
I'm a: Hobbyist Tech
Default Re: Samsung PS50a410
Originally Posted by tom66 View Post
Where is DP802 on the PSU? Seems like that FET took out a few other things with it.
Its right next to the fet. Short across the fet as well so it might be the fet not the rectifier. Will look tonight.
nickdablack is offline   Reply With Quote
Old 05-23-2012, 06:51 PM   #62
nickdablack
Pulling out components 1 at a time but there is still a short on the board somewhere. Oddly enough no short across the bridge rectifier. I'll find it eventually.
Old 05-24-2012, 12:04 AM   #63
tom66
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
If you can get hold of a computer power supply, you can smoke out the fault with 20 amps of 12V.
** Begin Signature **
I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system!
Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me.
I have successfully fixed (from best --> worst build quality):
3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 9 Vestel LCDs
[Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.]
tom66 is online now   Reply With Quote
Old 05-28-2012, 03:50 AM   #64
nickdablack
Bah, kids sick. Haven't had time to get back to it. Hopefully will get a chance in a day or 2.
Old 06-02-2012, 01:13 AM   #65
nickdablack
Back finally. Let see:
Pulled out QS801 and QS802. Both of them have shorted across all pins. However there is still a short across pins 1-3 even with the components removed.
Bit worried if I try to smoke out the short I'll fry something thats currently fine. Is it really safe?
Old 06-02-2012, 01:43 AM   #66
tom66
My Country: UK
I'm a: Student Tech
Can you post a pic under where pins 1 and 3 are?
Old 06-02-2012, 04:12 PM   #67
nickdablack
Here you go. It's doing my head in a bit. But I'll keep on trying. (as time permits)
Old 06-02-2012, 04:16 PM   #68
tom66
My Country: UK
I'm a: Student Tech
This short between 1 and 3 indicates a short between source and gate.
However looking closely at the arrangement it looks like Samsung use a small pulse transformer to drive the upper MOSFET - this is fairly common and will read as a short circuit. One thing to check is the small SMD diode near the gate - if there were a gate-drain short this poor little diode will have taken the brunt of it and is probably shorted - this might be why your new FET went bang as this diode is intended to prevent gate ringing (which wastes power in the FET... makes it get hot quickly.)
This pulse transformer is good news in a way because it limits the damaging surge which can go into the controller IC. So the IC may be okay.
Do you have a way of wiring in a 100W incandescent light bulb in series with your TV? This will stop the TV from blowing up more components if there's still a fault.
Old 06-02-2012, 11:19 PM   #69
nickdablack
DS804 is measuring .019v both ways. Yes i would say an ISS355 diode should not be measuring like that. However it doesnt look damaged and is paralel to a resistor. Iv'e taken an image up close.
Old 06-02-2012, 11:28 PM   #70
budm
City & State: S.F. Bay area
Line Voltage: 120V 60Hz
I would suggest to take out the MOSFET, check and see if Gate to Source is shorted, since the resistor is in parallel with the Diode, then either take out the Diode or the resistor out and take the reading and see what is shorted out. It is always more accurate to check the parts out off the board.
Never stop learning.
Baisc LCD TV and Monitor troubleshooting guides.
SMD Resistor codes:
http://www.hobby-hour.com/electronics/smdcalc.php
Old 08-21-2012, 12:39 AM   #71
nickdablack
I got the tv going. I wish I could say I found the short and replaced the component. But I took the easy option and sourced a cheap replacement board. On the plus side I have a very happy wife so I am going to take that as a win. Now to move on to the other 2 dead plasma's in my garage.
Many thanks to all the advice everyone gave me. If anything it's brushed up my rusty electronics knowledge.
