#41 |
City & State: coventry
My Country: uk
a thermistor maybe? do those diodes test ok next to it?
#42 |
City & State: University of Leeds (MEng ElecEng undergrad)
My Country: UK
Line Voltage: 230Vac 50Hz
I'm a: Student Tech
Inrush limiting thermistor. Almost any ~10A capable device will be fine to replace it. It's quite likely that the NTC acted as a fuse there and isn't the cause of the fault - I suspect a controller IC somewhere has been "wounded" and is malfunctioning.
** Begin Signature ** I fix TVs and electronics as a hobby and to save nice things from the dump. 40 LCD TVs, 4 monitors, 13 plasma TVs, and a 6.1 system! Free service manuals database: http://www.tgohome.com/ServiceManuals - Have a manual? Need a manual? Please PM me. I have successfully fixed (from best --> worst build quality): 3 Panasonic Plasmas, 1 Yamaha HTS, 1 NEC Plasma, 2 Sharp LCDs, 2 Toshiba LCDs, 5 Philips Plasma/LCD, 1 Hitachi Plasma, 5 LG LCD/Plasma, 10 Samsung LCD/Plasma, 1 Thomson Plasma, 1 Atec LCD, 1 Hanspree LCD, 1 Xerox LCD, 1 Harwa LCD, 2 Proview LCD, 2 Hyundai LCD, 1 "Onn" LCD, 1 Dell LCD, 1 iiyama LCD, 1 Logik LCD, 5 Bush LCD, 9 Vestel LCDs [Please do not PM me for help: I am a busy student, and we prefer input from all sides on this forum.] |
#43 |
City & State: Melbourne
My Country: Australia
Line Voltage: 240vac 50Hz
I'm a: Hobbyist Tech
A non linear resistor is the closes symbol match I can find. I have packed up for the evening so I'll do some measurements tomorrow.
Edit: Ok yes I am an idiot, and a thermistor is a non linear resistor. Last edited by nickdablack; 05-18-2012 at 03:24 AM.. |
#44 |
OK so its an NTC. Now to work out the Value.
SCK20206LSY |
#45 |
http://www.thinking.com.tw/documents/en-sck.pdf
SCK - Brand 20 - 20mm 206 - 206ohm L - 15% tollerance S - Straight Lead Y - RoHS & HF Compliant |
#46 |
Ok now to find the malfunctioning IC. Am I going to need an oscilloscope?
#47 |
#48 |
My Country: UK
I'm a: Student Tech
#49 |
OK my new shopping list is:
Replace IC - UCC28060 Replace Diode - 1N4007S Replace Thermistor - SCK20206LSY |
#50 |
My Country: UK
I'm a: Student Tech
Where is DB803 on the board?
#51 |
Its in the correct area. Looking at the original photo I didn't see it had cracked. Oh well that's an easy fix. Still think I need to replace the IC? (as much as i love surface mount soldering)
#52 |
My Country: UK
I'm a: Student Tech
By it's position, I'm guessing it would be better replaced by a UF4007 because it's going to be involved in the switching part and needs to be fast. 1N4007's are really slow parts - fine for rectifying mains but not much more!
I'm not certain about the IC. When you replaced the fet... 1.) what replacement did you use? 2.) did you re-apply thermal paste? 3.) did the TV display anything sensible? Last edited by tom66; 05-19-2012 at 04:17 PM.. |
#53 | |
2) The Fet didn't have thermal paste, just thermal pad. 3) The tv displayed static, but I did not have an antenna in. I presume it was on analog input. I am also struggling to find a suitable replacement thermistor. I'm looking at www.jaycar.com.au (the only shop open today). Cant find a 10A thermistor. Is a lower amp just going to blow again? Last edited by nickdablack; 05-19-2012 at 05:17 PM.. Reason: extra info. |
#54 |
My Country: UK
I'm a: Student Tech
Ah, okay - hmm. Strange that it would just blow like that.
As a precaution, it may be a good idea to replace the 450V capacitors on the primary as it has been seen that these can kill the PFC fets if they go bad. (Maybe the burn mark did more than damage the label of the cap.) For the NTC... you might be able to use a 3-5 amp device as this unit would probably pull less from a 240V AC input. |
#55 |
Sounds good. I'll have to go back to farnels. The other guys dont cary all of those items.
#56 | |
http://au.element14.com/jsp/search/p...sp?sku=9008187 |
#57 |
My Country: UK
I'm a: Student Tech
It says in the datasheet
Maximum Capacitance @ 240 VAC: 2,170 µf So I think you'll be fine. |
#58 |
Thanks again. Parts ordered. Round 2 later this week.
#59 |
Thought I would be thorough before firing it up again. found a short across pins 1 and 3 of DP802. I wish I saw that before I ordered parts. Oh well off shopping I go again.
#60 |
My Country: UK
I'm a: Student Tech
| Thread Tools | |
| Display Modes | |
