#1 |
ivtec
City & State: Fall River, Mas,
Line Voltage: 120-60hz
I'm a: Hobbyist Tech
Hi Guys; My Sony Vaio laptop keeps shutting off by it self and restart again every 5 minutes or so,i did recovery and during installing disc 2 it does same thing it goes off with a blue screen with some error,but can't reed cause it stays blue for a second, not enough time for me to reed the error. any help would be apreciated.
#2 |
City & State: Prilep
My Country: Macedonia
Line Voltage: 220v AC
Probably a driver issue, do a reinstall if windows and that should d the trick...
Guns don't solve problems. I'll take 12
#3 |
The Boss Stooge
go to system properties, advanced tab, then click the settings button for startup and recovery. uncheck the 'automatically reboot' box....that will stop it from rebooting after the BSoD, you can then read the error.
<--- Badcaps.net Owner & Forum Administrator!! Badcaps.net Services: Premade Capacitor Kits Badcaps.net Capacitor Master List Motherboard Repair Services If you've come here in search of replacement capacitors or repair services, please use the links above. ![]() ---------------------------------------------- Badcaps.net Forum Members Folding Team http://folding.stanford.edu/ Team : 49813 Join in!! Team Stats |
#4 |
City & State: wonk ab
My Country: canada
what kind of surface is laptop on! smoker?> pets? might just need a little tlc! when on is fan revved right up an kicken hard?
#5 |
Radioactive
City & State: tehas
My Country: US
Line Voltage: 120VAC 60Hz
bad ram can cause this kind of thing too
#6 |
ivtec
Thanks guys.I Findley went through with all recovery cd#2 and installed all updates sp1,sp2 updates,installed the free malwarebytes free,although the malwarebytes scaning tool says that it cleaned 100 errors and there are 400 to clean but i need first pay,so far is standing its ground ,meaning it's not shutting off anymore for a few hours now, cross my fingers,
thanks anyway. |
#7 |
ivtec
It's me again it started doing samething,i did recovery but it wont pass the regional languages and shuts down and restart but don't let me intall the #2 recovery with utilities,i got stuck.
#8 |
My Country: canada
would still check fan for dust bunnies(clean it if needed) an redo thermal paste on cpu!
#9 | |
ivtec
------------------------------------------------------------------------- A problem has been detected and windows has been shut down to prevent damage to your computer. DRIVER_IRQL_NOT_LESS_OR_EQUAL if this is the first time you've seen this stop error screen' restart you computer. If this sreen apears again, followthis steps: Check to make sure any new Hardware or software is properly installed. if this is a new installation,ask your hardware or software manufacturer for any windows updates you might need. If problems continue, disble or remove any newly installed hardware or software. Disable BIOS memrie options such as caching or shadowiong. If you need to use safe mode to remove or disable components, restart your computer, press f8 to select advanced startup options,and then select safe mode. Technical information: *** STOP: 0x000000D1 (0x0000077B,0x00000001,0xF741CF0F) *** NDIS.SYS-Address F741CF0F base at F7404000, DateStamp 41107ec3 Beginning dump of phisical memory phisical memory dump complete. contact your system admnistrator o technical support group for further assistance ------------------------------------------------------------------------- as you see i'm very acknowelege on software but i'm presistent and with your help i might achive success on this mater, also i tried to opened the back to rich the fan, took out all screws but still don't open maybe need to take some screw by taking the keyboard out?i would apreciate any assistance. |
#10 |
City & State: Windsor, Colorado
My Country: United States
#11 |
Moved to Laptop troubleshooting.
(Insert signature here) |
#12 |
My Country: canada
watch youtube vid on vaio disassemble! will show ya all the screw that need to be taken out an yes need to get at ones under keyboard! when ya look at where the fan blows out an then the other vents in comp! do they look dusty?
#13 |
ivtec
What you guys think of this bellow massage shown on the blue screen ?
------------------------------------------------------------------------------------ problem has been detected and windows has been shut down to prevent damage to your computer. DRIVER_IRQL_NOT_LESS_OR_EQUAL if this is the first time you've seen this stop error screen' restart you computer. If this sreen apears again, followthis steps: Check to make sure any new Hardware or software is properly installed. if this is a new installation,ask your hardware or software manufacturer for any windows updates you might need. If problems continue, disble or remove any newly installed hardware or software. Disable BIOS memrie options such as caching or shadowiong. If you need to use safe mode to remove or disable components, restart your computer, press f8 to select advanced startup options,and then select safe mode. Technical information: *** STOP: 0x000000D1 (0x0000077B,0x00000001,0xF741CF0F) *** NDIS.SYS-Address F741CF0F base at F7404000, DateStamp 41107ec3 Beginning dump of phisical memory phisical memory dump complete. contact your system admnistrator o technical support group for further assistance ------------------------------------------------------------------------- as you see i'm very acknowelege on software but i'm presistent and with your help i might achive success on this mater, ------------------------------------------------------------------------------------- |
#14 |
My Country: canada
01d error is caused by software! http://support.microsoft.com/kb/818326
says update service packs! |
#15 |
City & State: manila
My Country: philippines
possible ram or hdd
also can you check your fan if its turning or if it is full of dust, have you tried cleaning it,it may also the cause of auto shutdown of your sony |
#16 |
Probably a driver conflict with some of the software you are using, but also can be caused by bad stick of ram or bad sectors on your HDD.
Here's what you need to do 1. Check your lpatop's temperatures using SIW or Everest Ultimate 2. Check your ram by using memtest 3. Check your HDD by using HD Tune Pro (trial) Also tell us what software you are installing after windows reload. Post back here with results |
| Thread Tools | |
| Display Modes | |
